M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      01-08-2022, 11:19 PM   #1
M5_Raz
M5_Raz's Avatar
522
Drives: BMW M5
How To Fix Surging Idle On F10 M5 & S63TU Engines
Hey Guys,
Over the past 6 months my idle when first starting the car in the morning was surging by a couple hundred rpm usually and even up to 500 rpm on colder days.
I was thinking that it must be the cold start delete acting up. However I remembered reading about cleaning the MAF sensors and it helping.
It's super easy. Each air intake has one that's being held in by two screws.
I first unplugged the sensor. You wanna pull the little grey tab first, then while holding that down, you can unplug it. Next you can remove the two screws.
Once that's complete, you can pull out the sensor. As you can see, mine was very dirty with oil.
I used CRC Mass Air Flow Sensor Cleaner to clean it.
All you have to do is hold the sensor and spray it, don't wipe or touch it. I used quite a bit to get everything off. Here is the difference between a clean one and a dirty one.
The car is MUCH smoother now. Cold starts have no more problems and even driving it is so much better, especially when the oil is still cold. I definitely feel more power in the lower end too.
Took me 20 mins in total. Just filled it up and will report back with any MPG improvements, if any. Thanks!
Appreciate 3
M5Rick61734.50
BBHMM34.00
      01-09-2022, 11:15 AM   #2
ECB
102
Drives: e39 M5, e46 M3,f10 M5, 997.1tt
Looks better. Do you have stock air filters or oiled aftermarket ones? Thanks!
      01-09-2022, 11:24 AM   #3
careagax5m
94
Drives: BMW X5M
Great write up , I will do this next week.
Thanks
M5_Raz521.50
      01-09-2022, 12:20 PM   #4
M5_Raz
M5_Raz's Avatar
522
Drives: BMW M5
Thanks! Stock air boxes and filters with the charcoal filter removed.
      02-01-2022, 02:13 PM   #5
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
635
Drives: F06 M6
I ordered a pair of new sensors from FCP Euro and just use the lifetime warranty to swap on regular intervals.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
M5_Raz521.50
      02-05-2022, 10:53 AM   #6
M5_Raz
M5_Raz's Avatar
522
Drives: BMW M5
That's a good idea too. But it's more work and initial investment. How often do you change them?
      02-05-2022, 10:59 AM   #7
M5_Raz
M5_Raz's Avatar
522
Drives: BMW M5
Just wanted to report back for anyone that is curious. Drove about 1000 miles and I have noticed slight mpg gains, nothing too drastic to really make a difference (~0.5mpg). The car is still smooth at idle.
For 30 min and a few bucks, I recommend everyone to do it. Thanks!
Appreciate 2
      02-05-2022, 06:57 PM   #8
TinCanSailor
635
Drives: F06 M6
So far I have only swapped them twice. I didn't check the mileage but was just over 12 months and really only did it because I was replacing coils.
      02-22-2022, 10:47 AM   #9
M5Rick
General
M5Rick's Avatar
61735
Drives: M5 F10 DCT Gunmetal
Do that every 8 or so months on mine though have no oil spray on them yo
      05-17-2022, 11:00 AM   #10
BBHMM
34
Drives: 550i
hope it will fix my problem with idle
also had cold start removed (was blaming on it but will check this week)
      05-17-2022, 03:45 PM   #11
M5_Raz
M5_Raz's Avatar
522
Drives: BMW M5
Yep, same thing happened with mine. Catless and cold start removed.
1320racer137.50
      05-17-2022, 05:33 PM   #12
BBHMM
34
Drives: 550i
Damm in my case it worsen the problem I guess have to buy 2 new sensors
      05-17-2022, 06:04 PM   #13
M5_Raz
M5_Raz's Avatar
522
Drives: BMW M5
Did you wait for them to dry?
      05-18-2022, 10:45 PM   #14
BBHMM
34
Drives: 550i
Yes but I sprayed aloooot ) maybe that was my problem, also got check engine today (error code 102002), anyways Friday will know how good it runs with new sensors
      06-15-2022, 02:13 PM   #15
BBHMM
34
Drives: 550i
So far cold start is tuned back ON , new MAF sensors2x, litle surge, but now after car warm up no idle problem at all
      03-29-2023, 08:31 PM   #16
C-dub
35
Drives: Frozen White F10 M5 Comp
Thanks for the DIY Raz. $10 and 30 mins later, and my idle is buttery smooth again.
M5_Raz521.50
m5post
