BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Constant Issues
      04-02-2019, 04:41 PM   #1
Big Al Australia
Drives: 2017 X1 25i
Constant Issues
Hi all,
New to the forum. I have had the 25i for about a year now.
I had the transmission replaced earlier this year too. I was experiencing a severe thrust when downshifting in low speed. It would feel like the car had been hit from behind.
Then they had to replace the castor bushes on the RHS control arm.
I can hear an intermittent knocking sound at low speed when turning the steering wheel.
And now I'm receiving multiple warnings for oil and servicing which was completed in Jan 2019.
It currently with the dealership for diagnosis. I'm getting a bit sick of the constant issues.
Is any one else experieincing anything similar?
      04-03-2019, 04:01 AM   #2
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Where are you located, Big Al
Sounds like a poor dealer experience, among other things!
The transmission does need to be reset from time to time, because it does get a tad laggy and/or shunty. There's a process:
Steps...
1) hit start button once to turn on power (Don't start the engine)
2) then press the accelerator down to the floor for 5 sec
3) then hit start button once to turn off power
4) then remove foot from accelerator
5) then wait for 2 minutes
4) then start the engine like normal and see if that helps with the jerk and acceleration hesitation
There was also a technical service bulletin about the wishbones — I had mine replaced last year based on this (April 2016 delivery)
Here are my notes and references:
"TSB for knocking noise from engine compartment. Cause is a damaged right side engine mount. Service bulletin #B22 02 17.
And there another TSB for creaking noise when cornering. Cause is the rubber transmission mount rubs on the aluminum housing. Service #B22 01 17.
Third TSB (ref unknown) says to change both front left and right control arms with a revised control arm for certain production dates — original parts both defective from factory
414 234 668"
As for the service lights, well, either the service was done and they weren't reset, or it wasn't done, they were reset, and BMW's condition-based servicing sensors have caught them out. Or the system is stuffed!
I can understand your frustration but keep on it, escalate it to the Dealer Principal and BMW Australia. It's hard to ignore persistence!
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
Appreciate 3
iceman7117.00
gnx759.50
MJE60678.00
