01-17-2018, 10:44 AM | #1 |
Rep 17
Bmw x1 2017
Hi guys .
how long does is take a brand new Bmw to warm up ? i mean i live in quebec canada temperature is cold here but i also have three other cars but is seem that the bmw take ever to warm up. i have try different settings AUTO CLIMATE CONTROL,RECIRCULATE THE INSIDE AIR i have tried every settings.it seem like there a constant cold air blowing in from the ouside into my feet. i brought it back to the dealer they found nothing wrong with it??? any of you guys have any suggestions??? or any idea why is like this. |
01-17-2018, 11:38 AM | #2 |
44
Rep 138
I'm down in NYC and it's probably not as cold as up by you, but we have had about 2 weeks of temps under 15 degrees F. With that being said I never found it to be long at all but I do usually turn on the seat warmers along with the heated steering wheel which I'm sure add to the feeling that it's warm. (side note the heated steering wheel actually gets borderline hot after a while).
I generally don't blast the fan but rather just turn the temp to say 75F to get heated up and i would say in about 2 minutes the car is comfortable already. |
01-17-2018, 12:49 PM | #3 |
Rep 17
bmw x1 2017
thanks Yeezy
personally i tkink the problem is a bad thermostsat (stuck open )but the dealer check it out and said everything is good.it "s a brand new car with 2000miles lolbut anything is possible right??? |
01-17-2018, 01:03 PM | #4 |
64
Rep 261
Or your X1 was built on a Friday afternoon and in the rush to get to the beer haus...they forgot to put a thermostat in the housing!
04-13-2019, 01:46 AM | #5 | |
Rep 1
04-13-2019, 02:14 AM | #6 | ||
282
Rep 1,491
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
MJE60678.00 |
04-18-2019, 04:16 PM | #7 |
52
Rep 105
I have a 2017 X1 and haven't had this issue.. Mind you it doesn't get as cold here but typically I feel warm air within a few minutes of driving.
04-18-2019, 05:22 PM | #8 |
56
Rep 191
With the cold weather in the UK, my diesel would take up to 20mins to reach full temp. but lots of hot air within 5 mins. Worse when new oil is in it too, however we have the whole kidney grille blocked for efficiency which helps it warm up and stay warm.
04-18-2019, 07:14 PM | #9 |
1365
Rep 1,031
Drives: Like a bat out of hell.
The steering wheel heater has 2 settings. OFF and Scalding hot
04-18-2019, 08:41 PM | #10 | |
171
Rep 313
