04-20-2019, 01:31 AM | #1 |
22
Rep 21
Driving assistant plus & Active cruise control upgrade
Hi guys,
Does anyone know if it is possible to do a "simple upgrade" to 5AT/5DF if you have 544 cruise control with braking function and 5AS driving assistant currently installed in you car? The main request is actually the Active cruise control and making the car stay in the lane. Look forward to your answers Cheers |
04-20-2019, 02:26 AM | #2 | |
Rep 910
1. New steering wheel switch 2. Wiring loom patch/modification for SAS ecu. I see no repair part listed by BMW so you will need to find an experienced BMW auto electrician to make this wiring link. 3. SAS Ecu 4. Replacement DSC unit (from car with 5DF) plus wiring from pressure sensor to loom 5. E-sys- so you can VO code the car , remove S544 and add 5DF. (Or pay someone to code for you) Imo, you would probably need to find auto disassembler who break up cars for parts and get them to pull the SAS Ecu plus loom connection, modified DSC and wiring for you as a special order from an X1 Which had 5DF fitted at the factory. Last edited by MJE60; 04-20-2019 at 02:37 AM.. |
NJDK21.50 |
04-20-2019, 05:24 AM | #3 | |
22
Rep 21
I have 223 Adaptive suspension but not active as you mention. So unless its the same it sounds like a rather big deal to implement? |
04-20-2019, 07:57 AM | #4 | |
Rep 910
http://bmwfans.info/parts-catalog/F4...option?s=S223A Last edited by MJE60; 04-20-2019 at 08:05 AM.. |
NJDK21.50 |
