proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      05-09-2024, 08:02 PM   #1
M4ston
Drives: 2019 M4 CS
M4CS low oil
After taking my 2019 M4cs to the shop to have the pcv valve and oil pan gasket replaced I checked the oil level and it said it was at minimum and to add a quart. I looked at the invoice and it said they added 7 quarts and the CS takes 8 quarts so I added .6 quarts to see if it would change the reading and it is still at minimum. Should I be scared to add anymore? Thanks for the help
      05-09-2024, 10:13 PM   #2
b_w.
439
Drives: F80 M3
drive it more then recheck.
M4ston0.00
      05-10-2024, 09:16 AM   #3
Wanted_M
Wanted_M's Avatar
773
Drives: Frozen Blue M4CS
Is either low on oil or your sensor is bad. Sensor goes bad, it has happened here and there. If you keep adding oil and says it's still low, the sensor is the culprit. Sensor is mounted on oil pan.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf
M4ston0.00
      05-10-2024, 09:23 AM   #4
Yuille36
Yuille36's Avatar
471
Drives: BMW X5M, M3 ZCP, MB E63 AMG
2015 BMW X5M  [0.00]
I suggest taken the car on a 20 minute drive to get the oil nice and hot, then remeasure it, then measure it again to truly verify that the level is correct.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
M4ston0.00
      05-10-2024, 11:01 AM   #5
Nyc911
205
Drives: Porsche 997.1
Check if the spacer is installed it’s goes between the the oil sensor. If the spacer isn’t installed it shows low.
I wouldn’t add more oil if you don’t have any oil leaks.
If you’re missing the spacer you can order it from Bimmerworld
M4ston0.00
      05-10-2024, 12:52 PM   #6
jfritz27
jfritz27's Avatar
1127
Drives: 2018 F80 CS
Also, the OE fill spec for the CS is 7 L (an additional 0.5 from the base/ZCP 6.5), not 8
M4ston0.00
      05-10-2024, 01:29 PM   #7
N1rve
Racecar Driver
N1rve's Avatar
No_Country
1323
Drives: BMW M4
2019 BMW M4  [9.63]
Take it back to the shop. They seemed to have messed something up so it's their responsibility to fix it.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
M4ston0.00
      05-10-2024, 05:05 PM   #8
Colinv6
Colinv6's Avatar
4054
Drives: 2020 M4 comp, Mexico / Opal
As has been said many times, if only someone would invent something like a metal rod, perhaps with a minimum and maximum marker on it, that you could quickly pull out and see exactly how much oil was in your car. Probably could call it a dipstick or something.
Honestly it boggles my mind that BMW have gone all electric for measuring oil
2020 M4 competition Mexico Blue / Opal white ultimate pack, full M perf carbon kit, MP HAS, Carbon Ceramics, 763M with cup2’s.
Instagram c1_cdg
Appreciate 3
Huck5011.50
M4ston0.00
Wanted_M772.50
f80post
