05-05-2021, 03:37 AM | #1 |
Rep 1
6.5" CID Centre Information Display
Hi I currently own a 2016 BMW X1 M SPORT (F48) and want to change the standard BMW 6.5" CID Centre Information Display part number 9322123 to a glass fronted one I believe it's part number 8798222. Does anybody know if this would just be a straight swap or would there be other processes required to make it work?
Thanks in advance |
05-05-2021, 06:23 PM | #2 | |
189
Rep 754
https://www.realoem.com/bmw/enUS/partxref?q=9322123 You may need 65508803369 which appears to be exchangeable with your current screen, however, you'd need to make sure this isn't a touchscreen as this won't work with your current HU. If you're going with the same size (6.5), nothing special is required - would just be a simply p-n-p. You may want to upgrade to 8.8 cid from 2016/17 as that comes with the glass screen but would require the code change. |
MJE60678.00 |
