10-06-2015, 02:05 PM | #67 | |
153
Rep 412
RWD is fine in the winters I'm used to with good winter tires and common sense, not sure about in Wisconsin though. |
10-08-2015, 03:19 PM | #68 | |
Rep 24
I've driven my e46 M3 a few of the winters I had it and that worked well so I think I'm going to plan to pickup the BMW tire set for the M4. |
10-26-2015, 09:02 AM | #69 |
363
Rep 880
Does anyone know?
If you purchased the tire and wheel protection from your dealer when you first leased/bought your car, then you got the BMW winter wheels and tires (either 640m or 641m); does that protection also cover the winter package or no? |
11-13-2015, 07:01 AM | #70 |
28
Rep 75
Yes it does. From my dealer. I purchased the 19" OEM set with Nokian R2 winter tires.
2015 911 Carrera 4S 7MT 2018 911 GT3 6MT 2019 BMW M5 Comp |
11-20-2015, 07:46 PM | #71 |
(Sold) '00 M Roadster '06 M Coupe '16 M3 '20 X3MC
1573
Rep 2,592
So has anyone gone for the 8.5X18 square setup?
running the wheel offset calculator here is what happens on the rear going from 9" 29 offset to 8.5" 27 offset Inner Clearance: actually 8mm MORE Position: retracts by 4mm so it seems the only downside is that its retracted by 4mm which is 0.16 inches, I would think no one would notice that. |
11-23-2015, 01:30 PM | #72 | |
111
Rep 656
I did previously order Blizzaks LM-32s in 255/45/18 squared setup. I'm hoping these fit. Can anyone confirm that 255/45/18 fit on the f80 with a 8.5x18 squared wheel setup? That'd be greatly appreciated! |
11-26-2015, 02:49 PM | #73 |
Rep 54
Just ordered the 640M and continental tires. I have the 19" OEM wheels currently. Does anyone know if the change in tires will have a reasonable impact on the speedometer reading? By reasonable, I mean 0.5 mph or more difference?
12-19-2016, 04:56 PM | #77 |
1274
Rep 4,703
12-19-2016, 05:01 PM | #78 |
90
Rep 220
I drive A LOT in MT winter...which means lots of snow. Currently driving 335 but getting M3 as a DD. While I recognize many may cringe at the thought of taking our your M3 in snow, I for one, look forward to it.
For serious winter driving, a square set up is the best followed by the narrowest tire possible. Ive driven all sorts of winter tires and found the Nokian Hakkapeliitta R2s to be, by far, the best. Has anyone tried the F30 rims such as the 8.5x18" 400M or 441 running 225/50 on their M3? PS - Im not concerned how they may look. Im just after the best winter snow traction performance and dont want to go to the common 255 square setup if I can avoid it. |
Dackelone10627.50 |
12-20-2016, 06:09 PM | #80 | |
General
21132
Rep 20,742
Drives: 2021 911 turbo
Pressures do vary depending on setup. According to the M3/4 owner's manual (for speeds below 160km/h / 100mph): Summer 255/275 on either 18 or 19: 31psi front / 31psi rear Winter 255/255 on 18" wheels: 31psi front / 33psi rear Winter 255/255 on 19" wheels: 34psi front / 37psi rear
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
TouringM3619.50 |
12-20-2016, 11:18 PM | #81 | |
89
Rep 302
But here on this forum I found topic about them. They don't clear M brakes. So no.. I ended up ordering BBS RS wheels from tirerack + 245/45/18 tires |
12-21-2016, 12:33 AM | #82 | ||
14
Rep 54
12-21-2016, 02:58 PM | #83 | |
1274
Rep 4,703
I checked my 255 square winter setup and the pressure is in-deed 34/37 at the tires. Last edited by 2kaccordocoupe; 12-21-2016 at 03:17 PM.. |
12-21-2016, 04:27 PM | #84 | |
General
21132
Rep 20,742
My point was more about adapting pressure depending on setup
11-11-2017, 11:40 AM | #85 |
3881
Rep 1,678
Drives: M2 CS | M135i
@ my dealer today. 18inches. Impressive how they are quiet in comparison of 666M & PSS.
2020 M2 CS DCT
2021 M135i xDrive ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe |
11-11-2017, 11:43 AM | #86 |
3881
Rep 1,678
Here is a pic:
2020 M2 CS DCT
11-11-2017, 12:47 PM | #87 |
3881
Rep 1,678
Did someone know where you can see the width (and offset) of 640M rear wheel please? I just read that rear and front arn't the same wheel...
thx in advance!
2020 M2 CS DCT
11-13-2017, 12:29 AM | #88 | |
#savethemanuals
2463
Rep 1,987
- 640M (8,5x18 + 9x18) OR - 641M (8,5x19 + 9x19) The front wheel is 8.5" and rear is wheel 9" minor difference, both run the same tires. Great pic, BTW ! |
Hedoniste3880.50 |
