E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 335i - Engine Warning
Reply
      05-19-2008, 02:23 AM   #1
1stKnight
1stKnight's Avatar
Drives: BMW Z4M Roadster
Hiya,
This morning my beloved 335i startled me into thinking something might be broken...I started the car as usual and the big yellow 'engine has a problem' warning indicator came on and a message that there was reduced power.
I turned the engine off and waited a minute. Upon restarting the engine sputtered a bit, revs danced around between 500 and 1200 rpm and then it settled to normal.
I tentatively drove it to work - 26 miles - and it appears to be fine.
Should I be worried? Is this simply a blip or would it be wise to have it checked by the Dealer? The car has done 22000 miles.
Cheers,
S
Current cars:
1. BMW E85 Z4M 2008
2. BMW E91 325i SE Auto 2007
Previous car:
BMW E92 335i SE Manual 2006
      05-19-2008, 02:26 AM   #2
NFS
NFS's Avatar
275
Drives: M340i
Originally Posted by 1stKnight View Post
Hiya,
Cheers,
S
If it happens again - take it to the dealer. If not - don't worry.
      05-19-2008, 11:24 AM   #3
Serjames
Serjames's Avatar
128
Drives: E93 335i M-sport
The car will have logged the error..
I can check it for you if it's an OBDII code.
Where do you live ?
PM me
      05-19-2008, 02:29 PM   #4
1stKnight
1stKnight's Avatar
Where do you live ?
PM me
Thank you - most kind, but it seems to be okay now The car has been fine all day - spent an hour in London traffic with no probs at all.
Would you believe, while I was driving to a Meeting in the afternoon the salesperson from the Dealer called me as a courtesy to see how I was getting on after 12 months ownership. I told him about the event and he said it is most likely a sensor-related issue whereby a code wasn't interpreted properly the first time around causing the warning - and that it was unlikely to be a persistent problem.
Current cars:
1. BMW E85 Z4M 2008
Previous car:
      05-19-2008, 03:11 PM   #5
weez
272
Drives: 2021 X3M Competition
Not high pressure fuel pump failure? I know they go into limp mode once that fails.
      05-19-2008, 03:29 PM   #6
Welshman
Drives: BMW 535d Touring
FWIW I had the yellow EM Warning light come on just over a week ago. I stopped and checked the manual which said I could get home under reduced power. Power was definitely down but it seemed to run smoothly enough. I called BMW Emergency Assistance who came round and diagnosed that there was some problem with the VANOS system. He reset it and advised me to book it into the dealer - Sytner in Birmingham. I drove it in today without the problem reoccuring - 25 miles. When I called in later they said that the problem was with the camshaft controlling the inlet valves and it would need a new camshaft, a camshaft carrier and assorted other parts. Apparently the problem was that there was insufficient oil pressure being generated to cause the VANOS system to work properly. So, if I was you I'd take it into the dealer and get it checked over properly. In my case it isn't the first time this problem had manifested itself as the service chap told me that two fault codes were coming up and BMW know from prior experience what the problem is.
      12-05-2008, 01:28 PM   #7
johnc_22
johnc_22's Avatar
Drives: 2007 E90 335i
My car was just diagnosed with this same issue.
E90 335i: TiAg, black leather, burl walnut, 6MT, Sport, Premium, Cold Weather, PDC, Sirius, Comfort Access, Nav
ED: 3/30/2007 Redelivered! 5/15/2007.
      12-29-2008, 01:02 AM   #8
tracfour
tracfour's Avatar
Drives: 2014 550. 2015 x328d
You may have a problem with the Vanos system working correctly. The first time the dealer changed the high pressure fuel pump but then I had the same issue two days after the new pump was put on, took it back to the dealer and discovered that it was a problem with the Vanos system.
      12-29-2008, 02:25 AM   #9
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
949
Drives: 997.2 GT3
surely if there is low oil pressure issue, then other problems could arise.
997.2 GT3
Reply
e90post
