03-21-2024, 08:53 AM | #1 |
2840
Rep 3,715
Differential Bushings Replacement
What's everyone doing for this?
My thought is I didn't want to go full Powerflex bc I've heard it can be a bit too harsh for a daily driver that sees track time, especially with a DCT: https://www.powerflexusa.com/shop/pr...ory=1779#attr= https://www.powerflexusa.com/shop/pr...=1779#attr=679 https://www.powerflexusa.com/shop/pr...1779#attr=2173 So instead, my thought is to get the PowerFlex dual mount bracket and use the OEM+ poly bushings for the rear: https://www.powerflexusa.com/shop/pr...ory=1779#attr= https://www.fcpeuro.com/products/bmw...mw-33178094690 As for the front bushings, wanted to stay rubber and can't seem to find the individual bushings, so was thinking to grab one of these: https://www.fcpeuro.com/products/bmw...nt-33172284774 Any thoughts on all this? |
03-21-2024, 11:44 AM | #2 |
778
Rep 607
I’m considering the street version of Millway’s dual mount lift kit as it utilizes OE bushings when the time comes for this.
https://www.millway.se/dual-mount-di...tomtabs_tabs_1 At 36k miles I’m going to hold off a bit longer. |
ZM22839.50 |
03-21-2024, 11:47 AM | #3 | |
2840
Rep 3,715
03-21-2024, 11:32 PM | #4 | |
449
Rep 557
Someone I know locally used a different bracket & with the oem solid dual mounts and has no noise. |
ZM22839.50 |
03-24-2024, 01:49 AM | #6 |
511
Rep 882
The lift itself is only a supporting mod to reduce axle wear. The small performance improvement is in the bushings. As for the front support you could always replace the inner bushings that's connected to the rear axle and leave the outer ones rubber.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
ZM22839.50 |
03-24-2024, 09:43 AM | #7 | |
2840
Rep 3,715
As noted in other posts, I'm compromising this car b/n street and track https://f87.bimmerpost.com/forums/sh...&postcount=472 and really don't want any additional diff whine or DCT jerkiness. Definitely would like everyone to keep chiming in tho, so we have a good list of options for everyone's use cases! |
Westersund511.00 |
03-24-2024, 09:59 AM | #8 |
511
Rep 882
Same here, haven't decided if I should go for the lift kit or not. But dual poly OEM at the back will be done. The positive part about changing the inner bushings on the front support for solid aluminium ones is that it won't really increase the whine because the outer ones that connects to the chassis are still rubber.
03-24-2024, 06:41 PM | #9 | |
1487
Rep 1,404
chris7197393.50 |
04-23-2024, 11:30 AM | #10 |
108
Rep 216
04-23-2024, 11:31 AM | #11 |
108
Rep 216
04-23-2024, 01:25 PM | #12 |
1487
Rep 1,404
