05-07-2021, 10:21 AM | #1 | ||
4042
Rep 3,549
Drives: 328d Wagon, M2 Comp, i4 eD35
A Look into the DSC Brake Bleeding Routine
It's pretty commonly mentioned that there's a "DSC bleed" that's sometimes needed on these BMWs, but I didn't see any information out there actually showing the process. On the surface it sounds pretty simple, use a scanner device or ISTA to activate the DSC module and bleed fluid, but the routine is actually more complicated than that. I'll show you below what the routine looks like in ISTA.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-07-2021, 11:19 AM | #2 |
2432
Rep 2,526
Hah. So I was just going to do this (and post a video up) this weekend. Nice
05-08-2021, 08:11 PM | #3 |
234
Rep 350
Thanks for this, I had looked for something like this last March/April may when I switched out the brake lines but didn't find anything. I had started to try to figure out the process myself but then also turned out the USB network adapter I had was broken so I gave up (regular bleed process was good enough). I'll try out this process this year before my track season really starts up (sadly delayed cause of Canada's poor COVID-19 3rd wave).
Do you have a rough estimate of how much brake fluid is used during the DSC process? I.e. if you're just filling the reservoir with fluid and not putting fluid in the pressure bleeder are you likely to need to refill? I'd obviously refill as necessary during the pre-DSC bleed/flush, and it's easy enough to refill after the DSC process and before the final bleed (although I can't imagine that requires much since everything should be pretty clear). |
05-10-2021, 04:51 PM | #4 | |
4042
Rep 3,549
05-08-2024, 03:56 PM | #5 |
Rep 13
Drives: BMW M2
FaRKle! thanks for this. Do you know which side you bleed for right hand drive during this routine please?
Wasn’t sure and due to complete this tomorrow. Appreciate the effort to share this stuff 👍 |
05-09-2024, 08:53 PM | #6 |
180
Rep 376
Drives: 2020 M2C DCT
FaRKle! I'm a fan of your YouTube videos. I didn't know you were here until this thread came up when I was searching about bleeding the brakes and DSC.
If I undertand the ISTA procedure correctly, you are supposed to bleed all four corners, then bleed the DSC, then bleed all four corners again. Is my understanding correct? If so, what is the total required volume of brake fluid? In case it matters, my car has sport brakes.
2020 M2C DCT Hockenheim Silver Metallic
