TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      05-12-2020, 02:16 PM   #441
Arekux
Drives: X5, 550i
Originally Posted by dtkw969 View Post
The burble settings aren't 100% consistent on mine either. I set mine at 3000rpm and sometimes it comes on, sometimes it doesn't.
My standing burbles work, however.
Thanks for reply, what’s your burble settings? Soft/medium?
      07-10-2020, 05:45 PM   #442
ryansbmw
181
Drives: 2013 X5 35i M-Sport, 2010 535x
VRSF downpipe installed. Flashed up to Stage 2+. Just need this damn tropical storm to pass so I can see what she can really do
VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
Need coding or modules reset? PM me
      07-23-2020, 11:22 AM   #443
drummr8
6MT FTMFW
61
Drives: 11 E90 335xi E91 6MT 12 X5 35i
How's 2+ on the E70?
Originally Posted by Twisted Tuning View Post
Sorry guys, been swamped and haven't even had a chance to view the logs some people have sent me in reference to towing. I'll re-visit this soon. as I free up some time
Any update regarding a towing map?
2011 LMB E90 335xi 6MT: Wagner EvoII FMIC, Catless DP, PE Mod, Cobb CP, BMC Filter, ST Coilovers, Strongflex TSB's, Whiteline RSFB Inserts, CDV Delete, Hawk Talon Rotors & PC Pads
2011 SGM E91 328xi 6MT: 3-Stage Intake Manifold, ST coilovers, 335i brake kit, drilled/slotted rotors, CDV Delete, Charcoal Filter Delete
      07-23-2020, 01:21 PM   #444
ryansbmw
181
I’ve always had the wife in the car with me so I still haven’t had a real chance to test it, but I like it a lot. I need to get the 3.5 bar MAP sensor installed so the engine can properly read boost levels. Stage 2+ is pushes boost right to the limit of what the stock sensor can read. I’m also really interested in getting xHP trans tune to go with this tune.
      07-23-2020, 11:21 PM   #445
ayaxe60
Drives: BMW E60'05 525i E70'12 X5 35i
Let us know!
I'm at Stage 1+ with just the burger tuning charge pipe right now and I'm about to put in an aftermarket oil cooler and sport thermostat housing as well as get the Wagner intercooler and probably a 200cell catted downpipe before I go to Stage2+
I live in perpetual hot and humid 90 degree weather and I just want to make sure the cooling is in check.
This is the first I read about going with the 3.5 Map boost sensor, this is an OEM part from the N20 right?
All the stories I hear about xHP is that it really transforms the car, going to look at getting this too.
*edit so I went thru the flashing options again and there it is clear as day.. N20 3.5 map sensor option. I completely missed it before*
      09-13-2020, 01:19 PM   #446
iank20
Kenya
Drives: 2012 BMW E70 X5 35i
Red face MHD Tune on my E70 X5 35i
hey guys, the first time i flashed MHD was with the normal 91oct & it run great for a while before i began noticing the power dropping slightly after a number of pulls & a lot of timing corrections
in my country the fuel is poor & being a newbie to the tuning world, i figured the normal 91 is the one, but unfortunately it wasn't the case. it was running a bit poorly and i got worried.
i switched to acn91 to see whether it would be better. i had initially installed the tune with very old ignition coils & plugs, which affected the performance greatly. so i replaced them all & also got a vrsf catless downpipe fitted. the car feels much more alive. the downpipe gives it an aggressive exhaust note and even louder farts in gear changes
for now i am in stage 1 because of the high iat's, just to be safe.
i will be upgrading the Intercooler and Cold Air Intake, then jump into stage 2 / 2+
it is recommended to replace the ignition coils & spark plugs before tuning, install supporting modifications & also choosing the right fueling
all in all, MHD is awesome
E70'1193.50
      04-15-2021, 01:42 PM   #447
papasolsol
papasolsol's Avatar
Drives: BMW X5
Originally Posted by Arekux View Post
Anyone had issues with burble tune not working in standstill, I have 2011 e70 X5 35i, settings are base 1.5s, sport 2s, soft, 0mph, 1800rpm. I tried parked and neutral position. Works fine I’m DS mode. Other than that, engine pulls hard, very smooth tune.
- Stage 1+ Bone stock N55
- Delphi Coils and spark plugs changed recently.
- 102k miles on the motor
We have almost the exact same car and miles lol I'm at 106k. Getting my MHD hopefully this weekend
      02-04-2022, 03:21 PM   #448
E-Novo
Drives: 2013 BMW X5 xDrive35i Premiuim
Anyone hear anything on when MHD may roll out the "Adjust Throttle Sensitivity" option that they gave the N54 guys in Sept - for the N55?? Sounds like it will solve the dreaded throttle lag issue.
Hate the lag - dying for a solution!!!!
