11-27-2022, 01:48 PM | #1 |
Rep 7
Looking ways to improve ride quality on X2 m35i
Hi there -
I have had my X2 m35i for almost a year, and there are a lot of things I love about it, but... I find the suspension super jarring and my head bounces around way too much. Perhaps if the roads here in California were as perfect as they are in Germany, this would be the perfect car. Would changing the springs help? Any other ways to make the ride quality smoother? thank you! |
11-27-2022, 09:42 PM | #3 |
2025
Rep 2,805
Drives: F33 430 and F39 M35i
As soon as the factory tires got down to 4mm, I replaced them with goflats. I have to deal with winter so I got Michelin All Season Pilot 4S tires. I also made a temporary spare tire in case of flat.
11-28-2022, 02:02 PM | #4 |
66
Rep 214
Might be sacrilegious to say this about a M-variant automobile but if dropping psi a bit doesn't help out your heartburn with the car's ride then your next step should be to look at putting more rubber on a different wheel. Going to a 19" wheel would probably help you out. You've not next to zero tire cushion with a 20" wheel & with the tires being run-flat types.
‘22 X2 S-Drive. Running 13mm Wheel Spacers & 255-wide 'go-flat' tires.
Former Owner '11 X5 35d w/Sport Package Former Owner '86 528 |
11-28-2022, 02:46 PM | #5 | |
161
Rep 179
11-28-2022, 07:40 PM | #6 | |
Rep 7
11-29-2022, 03:31 PM | #7 |
66
Rep 214
Sounds like a good plan & you're poised to be able to give it a go with stuff in your posession.
12-01-2022, 07:54 PM | #9 | |
Driver
465
Rep 1,002
