03-11-2017, 04:36 PM | #309 | |
Save the manuals!
6020
Rep 6,750
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
03-13-2017, 12:29 AM | #311 |
17
Rep 45
My X1 F48 Coding Sheet
Dear all
I am a beginner for BMW coding. On last three months, I study many document to learn the coding and also have get many support and help from other expert coming from worldwide. Now I coded what I want and learned some function of the relative program like E-sys, Launcher, ISTA+ and NCDCAFD tools. Those program are complicated and hard for me and I will taken more time to study later (So I will have more question to ask you expert). I know all of the expert have spent many many time to study and investigate those program, so I would like to take this opportunity to thank all of them like Shawsheridan; Almaretto; oreoOozZz, E90Fleet, SimonCHS (from my country), Tokenmaster, Reclaimer and other. Although, there have many many coding sheet for other BMW model on the worldwide, I just want to share my coding sheet to other coding beginner especially F48 for reference only. And some of the module have not been coded and tested by myself, and some of them is just copy from other coding sheet, so if you have coded and tested them, please update me and let other beginner to enjoy. Here is the link, enjoy https://mega.nz/#!pgtEHZhB!2B1kbhR-b...Iz2Shm_1rPnUSs Disclaimer: Code at your own risk. We are not to be held responsible to any damage or warranty voidance that may be caused by it. Ask for help if you are unsure. Importance: That coding sheet is suitable for my car only, may not yours. ANY QUESTION, ASK ASK ASK to expert. Not me |
03-14-2017, 06:29 PM | #312 |
Save the manuals!
6020
Rep 6,750
CAFD_000017BE_052_010_039.ncd
I-STEP F056-17-03-502
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc Last edited by 6ixSpd; 03-14-2017 at 06:36 PM.. |
03-14-2017, 06:59 PM | #313 |
2374
Rep 8,364
03-14-2017, 07:05 PM | #314 | |
Save the manuals!
6020
Rep 6,750
Also, the BFD coding gives a Light Control error when the BFD is triggered. The brake lights do flash but it gives that error on the iDrive and Kombi, then goes away. The unlock all doors when engine stop doesn't work either in CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING even though it's set to aktiv. VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK doesn't even give me an option to change to aktiv, it only has nicht_aktiv.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc Last edited by 6ixSpd; 03-14-2017 at 07:12 PM.. |
03-14-2017, 07:28 PM | #315 | |
2374
Rep 8,364
View post on imgur.com There are two things that make a difference:
CLI_DEFAULT_UNLOCK_AFTER_END_OF_DRIVING:
03-14-2017, 07:33 PM | #316 | |
Save the manuals!
6020
Rep 6,750
What do you suggest I update? This is the first time I'm having an issue coding a F series vehicle. For BFD I only changed ESS_AKTIVIERBARER_AUSGANG. What other parameters need to be changed?
03-14-2017, 07:43 PM | #317 | |
2374
Rep 8,364
You will get errors if you only change that one BFD value. There are two-four others that you need to change. |
03-20-2017, 04:30 PM | #320 |
2374
Rep 8,364
03-28-2017, 10:15 AM | #323 |
Rep 39
Drives: X1 F48 25i
I went for some coding this afternoon.
THANKS to all of you guys for your help. I changed Start & Stop to last setting position OK Door handle light in reverse OK Turn signal set to 5 time OK Driving mode set to "sport mode" OK I wanted to set it to last setting position but Ididn't find ICMQL for memory. If anyone can help me it could be nice. And I have a new coding question. On my car, I have adaptive light with windshield camera. So High beam to Low beam is automatic when I push the button on the left side of the steering wheel to have the green light on on the dashboard. I think it could be better to have it automatic without having to push the button. So, my question, is there any coding to reverse the default function. Hope I am clear enough.... Cheers JP
oreoOozZz126.00 |
03-30-2017, 06:20 AM | #324 |
117
Rep 212
I am wondering if all this coding could give ground to any authorized BMW service point to deem your car out of warranty!
Has it ever occurred? |
03-30-2017, 12:06 PM | #325 | ||
2374
Rep 8,364
VO coding reverts ECU's to factory values. |
03-30-2017, 12:26 PM | #326 |
Rep 39
Drives: X1 F48 25i
Thanks Almaretto and do you know for driving mode, I want to set to last memory setting and didn't find ICMQL
03-30-2017, 02:29 PM | #327 | |
2374
Rep 8,364
I need to post update through 3.61.1, but here is CAFD_ID's PDF. Last edited by Almaretto; 04-03-2017 at 05:17 PM.. |
AUS_Tin_Pusher23.00 Mr Carrots766.50 |
03-30-2017, 04:12 PM | #328 | |
Rep 39
Drives: X1 F48 25i
