02-22-2024, 07:31 AM | #23 |
3327
Rep 1,799
Drives: 2022 X3 M40i
for those of you who plan to install a new bolt or upgrade, here's how.
02-23-2024, 09:45 PM | #24 |
710
Rep 562
Does anyone know the P/N of this bolt for our cars (the M40i, not X3M)?
Is it 33326775040? I'm kinda thinking of just replacing it as a fatigue measure.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
02-23-2024, 11:56 PM | #25 |
3327
Rep 1,799
Thats what I see. 33326775040
03-06-2024, 06:49 PM | #26 |
192
Rep 90
So I just wanted to touch base because my driveshaft broke awhile back and I upgraded to a carbon driveshaft which was recommended from Joe who I’m sure many people have heard of.
I never noticed anything wrong with bushings at the time of installation or the bolt for that matter. But fast forward 6 months and the two front mounts are broken, rear main bolt is broken as well. Took over two weeks to receive front bushings from Germany and I’m currently waiting to see if the VTT inserts work for fronts because I contacted VTT and they said we’re sure if they would fit and they would have to research it. I also asked if I could help expedite that process and try and they said I could purchase them and try it but would be a restocking fee if I returned them. I also want to get the Einhorn for the rear but since the X3M diff bushings and M40 bushings are different parts numbers I am not sure it will fit I guess I’m waiting to see what anyone else finds out. |
Burr0013327.00 |
03-06-2024, 07:14 PM | #27 | |
192
Rep 90
Burr0013327.00 |
03-06-2024, 07:23 PM | #28 |
Cowboy Astronaut Millionaire
2320
Rep 2,887
Dang. This thread make me sad.
How much is a stock replacement?
03-06-2024, 07:38 PM | #30 |
192
Rep 90
03-07-2024, 04:30 PM | #31 |
BM3 Tuner
316
Rep 291
Yes x3m bushing will fix as they share the same subframe most BMWs share the same subframe aswell
2019 BMW X3M40I - VRSF Downpipe, XHP Stage 3, Nostrum Stage 1 Injectors, VTT PCV and Oil cap.
Paul Johnson Tunes Shop/Development Car |
03-24-2024, 02:37 AM | #32 |
Rep 11
https://www.fjmotorwerkes.net/produc...fj-motorwerkes
We are aware solid bushings causes vibrations and unwanted sounds from testing. We also offer end bushing for extra piece of mind at only £59 extra plus bolt collar kit £199 = £259. Instagram Fjmotorwerkes All the best |
04-16-2024, 12:38 PM | #34 |
3327
Rep 1,799
I will have it installed this weekend and will update the thread.
04-24-2024, 11:41 AM | #36 |
3327
Rep 1,799
The metal insert does not fit good on our bushing and it is loose all around it. So vtt does not work unfortunately.
04-24-2024, 07:17 PM | #37 | |
486
Rep 274
Drives: 2023 M3 Comp
Got the rear lower and mid installed and it’s pretty nice! Definitely stiffens up the ride in a good way! |
04-24-2024, 10:53 PM | #38 |
3327
Rep 1,799
Correct only x3m/x4m fitment for VTT diff kit.
04-26-2024, 11:29 AM | #39 |
23
Rep 104
I would assume that the bushing diameter is the same from M40i to M. We could replace ours with the factory M bushing and then add the vargas kit if we wanted.
I thought I read someone else had installed the solid full bushing replacement from the M to the M40i and it fit. Which is why I expect that outer diameter of the bushings are the same. Thanks for trying and letting us know! |
blackops23486.00 |
04-26-2024, 11:33 AM | #40 | |
BM3 Tuner
316
Rep 291
