12-29-2021, 02:44 PM | #1 |
18
Rep 104
Stop/Stop Function quit working
Good Day, Season Greeting to all.
The Start/Stop Function on my wife's 2016 X1 stopped working. Does cold weather and or snow have anything to do with its operation. Typical causes of failure |
12-29-2021, 02:53 PM | #2 |
22
Rep 81
Did you/she push the button next to the ignition start button? My wife did that and it turned on the start/stop feature. Ours is turned off as it's beyond annoying.
12-29-2021, 03:05 PM | #3 | |
120
Rep 595
No reason to have the engine off when you are blasting heat into the cabin due to cold weather. Everyone wants to be climate friendly until they are cold.
2022 Nissan Armada (big couch)
2017 Camaro SS 1LE - Gone 2008 SSII E90 6MT - Gone 2009 SG E92 DCT - Gone |
12-29-2021, 05:49 PM | #4 |
Air Vice Marshall
256
Rep 1,639
All stop/start functions reset the next time you turn the ignition off and on again. So it is on by default when you start the vehicle.
Also in Sport mode the start/stop is disabled. One point to remember, if your battery condition is low, then stop/start is also disabled.
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium |
12-29-2021, 06:17 PM | #5 | |
18
Rep 104
The Start/Stop is On as the Symbol in the guage cluster come up when you come to a stop but the engine continues to run and the revs do not drop as they would have normally. |
12-29-2021, 11:33 PM | #7 |
Retired from BMWNA
198
Rep 184
Start start functions actually pretty smart. There are 21 things conditions that have to be met before it will negate the start stop. Low battery condition, is one, another is if the cabin is not above or below the temperature set in the climate system it will not shut off, so in the summer if it it hasn’t reached the optimum temperature with AC, it won’t shut off, converse is true in the winter.
Glen
Ft Lauderdale '23 228i GC |
12-30-2021, 10:07 AM | #8 | |
120
Rep 595
It's -30c here now and even with start/stop enabled, cabin set to auto at 21c and vehicle temp warm, it won't shut off at a stop or light. I wouldn't want it to anyway as these vehicles cool off very quickly if not driven under load in these temperatures.
12-31-2021, 11:15 AM | #9 | |
13
Rep 53
HNY to you all. |
12-31-2021, 11:29 AM | #10 | |
120
Rep 595
Our lease is done this summer and the X1 will be gone for a real SUV with a V8. My Camaro has zero issues in this weather when I drive it and the big engine warms everything up 100x faster than the turbo 4 in the X1. Murica!
12-31-2021, 11:54 AM | #11 |
13
Rep 53
Don't like finicky either but I only got my X1 in September so I'm going to figure it out or struggle. It's sat outside plugged in it's -27 and I plan to start it on Sunday when the temp is expected to get near zero here!!! Love the X1 otherwise.
12-31-2021, 09:49 PM | #12 |
4486
Rep 7,528
Some BMW Stop/Start operational parameters:
Some reasons why the engine does not auto-stop:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
01-01-2022, 12:22 AM | #13 | |
55
Rep 277
Any idea what the DPF is? |
01-01-2022, 08:45 AM | #14 | |
Air Vice Marshall
256
Rep 1,639
https://en.wikipedia.org/wiki/Diesel_particulate_filter https://www.onlineautomotive.co.uk/c...0aAm07EALw_wcB
02-07-2022, 12:59 PM | #16 |
52
Rep 105
Have your battery checked, mine stopped working but the car never indicated the battery needed to be replaced. The dealership said I needed a new one, sure enough it started working after a replacement battery.
02-28-2022, 09:32 AM | #17 | |
Rep 6
Thanks.
Regards,
Jack |
03-03-2022, 02:20 PM | #19 | |
1606
Rep 1,480
Drives: 2022 M440xi GC
03-04-2022, 05:43 AM | #20 | |
Air Vice Marshall
256
Rep 1,639
Note.1 The statement I made is a fact.
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium Last edited by Peter_R; 03-04-2022 at 05:52 AM.. |
03-04-2022, 12:22 PM | #21 |
1606
Rep 1,480
If you turn off ASS in any mode on 2016 x1 the button stays off and does not reset.
This changed in my 2019 x2 where I had to code it off. |
