BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Transmission Error
      02-29-2020, 12:36 AM   #111
jamessfarnell
South Africa
20
Drives: F48 X1 SDrive18D 2020
Hi All, Has anyone seen the letter we are talking about? I have been contacted a few times, but I do not have the letter in question?
      03-02-2020, 08:24 AM   #112
Shipa
17
Drives: BMW X1 F48
Sorry for delay! I have sent the copy of our letter to everyone who shares their emails.
Wish you good luck!
      03-03-2020, 06:07 AM   #113
jamessfarnell
South Africa
20
Hi Guys,
Here is the letter with redacted VIN's. I am sending this to BWM RSA today.
      03-10-2020, 07:29 AM   #114
civciv
Drives: X1 F48 Med. Blue
I have contacted my local authorized service center about this issue and they asked Germany. Today they told me that Germany has offered %60 discount for the part's cost. The parts are 25168483098 and 18308631986 but I don't understand the function of the latter.
Plus I have to pay all the labor. This offer is neither good nor bad IMO.
      04-16-2020, 03:44 AM   #115
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
Hello Guys!
Does anyone repaired the gearshift lever with this problem?
I found some guys who told me that they repaired their gearshift, but they didn't want to disclose how did they do it.
I searched all over and what I found is that there is a spring who does not push the "P" sensor resulting then the error. If this spring is "fixed" then the problem is solved.
Can anyone confirm this, or other solution?
Regards,
Stefan
      04-29-2020, 08:07 AM   #116
celik
Drives: bmw x1 f48
guys, please have someone answer me about this gearbox problem. It happens to me, I have f48, 2016. When you sent the mail to bmw, after how long did they contact you and approve your repair through "goodwill". Likewise, if someone has a solution that someone has been able to repair, let them know. Authorized service refused me because my warranty had expired. Thank you.
      04-29-2020, 08:16 AM   #117
celik
Drives: bmw x1 f48
i also sent the mail to bmw as a complaint and i have been waiting for 9 days without reply, let someone confirm my mail address that i was not wrong. Thank you.
      05-03-2020, 03:55 AM   #118
celik
Drives: bmw x1 f48
guys, can anyone answer me
      05-04-2020, 05:34 AM   #119
jamessfarnell
South Africa
20
Hi Celik, I have not had any joy at all with BMW RSA. They pretty much said "tough luck" out of plan....
I am still looking for a fix.
      05-04-2020, 05:38 AM   #120
jamessfarnell
South Africa
20
Originally Posted by StefanJ View Post
Hello Guys!
Regards,
Stefan
If you are out of plan, what have you got to lose - may as well try? Mine is going in for a fuel leak this week, then I am thinking to pull the dash out myself and find this GOD DAM SPRING, I will document all steps and see if I can solve this problem once and for all, giving BMW the finger!!
      05-05-2020, 03:06 AM   #121
celik
Drives: bmw x1 f48
Thank you very much for your reply, can you just send me what is the bmw mail address, just to make sure I didn't send it wrong. Of course, if someone manages to solve the problem, let them know. good luck.
      05-07-2020, 01:07 PM   #122
Mike.x1
Drives: BMW x1
Spring
I have the same issue in my 2016 bmw x1. Found some info on the mini repair page. I can try this but may take a few days as work has been crazy. Let me know if any one has success.
StefanJ68.00
      05-07-2020, 01:34 PM   #123
StefanJ
StefanJ's Avatar
68
Great, keep us informed.
I agree with there finger 😁
      05-07-2020, 01:44 PM   #124
StefanJ
StefanJ's Avatar
68
Thanks for the info mike.x1
As for my problem, just two days ago I found someone in Romania who is selling repaired selectors for around 200 €. He didn't want to disclose how he did it, but he guaranteed that it will not have this problem again.
I've just bought one and received it today... bad timing.
Anyway, your info is more than useful for other owners.
      05-12-2020, 09:56 AM   #125
jamessfarnell
South Africa
20
Agreed - this is what I am currently attempting.. however, I don't have the available tools and lift to get to the underside of the vehicle.
To get the assembly out of the interior is surprisingly easy. Just a few Hex20 screws and some clips. 4 bolts hold the whole assembly in on the inside of the car. I got this far..
However, you need to remove part of the exhaust heatshield, and I cannot get to that point without a lift. Trying to find a friend that can assist. I pulled out the whole air intake system, battery and I can get to the actual gear selector on the topside of the steptronic. Thats as far as I can get...
Once the whole shifter assembly is out, it can be opened, and a tiny spring holds back a white lever that covers a sensor.. that's it.. the tiny little spring. Either replace, or you can rebend the bigger half of the spring to the right shape, and put it back in..
https://www.mini2.com/threads/shiftl...d-in-p.354119/
https://www.newtis.info/tisv2/a/en/f...xdrive20d-sav/
So.. Anyone in Johannesburg South Africa have a car lift?
Shipa17.00
      05-12-2020, 10:17 AM   #126
StefanJ
StefanJ's Avatar
68
Jamessfarnell, it's possible to take out the cables that enters into the gear selector and to take it out without lifting the carr. I've just did it last weekend.
On the front of the gear lever selector, where the cables are going in, there is a round hole, where you will see a black plastic clip moving when you change gears. You just have to rotate it with a flat screwdriver and it release the cables. Very easy.
Here is a picture.
Shipa17.00
      05-13-2020, 06:25 AM   #127
jamessfarnell
South Africa
20
Here is a picture.
THANKS!
Were you successful in changing your gear selector unit and did it need to be coded to your car?
Did you keep your broken one to see how it can be repaired?
Lastly, the blue connector for the iDrive control, is there anything special needed to get it off? I couldn't get it out at all and i was worried I was going to break the cable?
      05-14-2020, 02:39 PM   #128
StefanJ
StefanJ's Avatar
68
THANKS!
Yes, I changed it successfully. Coding was needed.
No I send it to the person who sold me a already repaired one, for getting a discount.
I don't know how to get it off because the replacement was made by a technician, a was just assisting. Sorry.
Good luck!
      05-24-2020, 02:19 AM   #129
jamessfarnell
South Africa
20
SUCCESS!! I have fixed my gear selector! Error code cleared!
I will be writing a guide on how I did it ASAP - give me a couple of days!
Cheers!
      05-25-2020, 08:15 AM   #130
jamessfarnell
South Africa
20
How to fix this issue, guide attached.
Good luck.
Appreciate 10
      05-25-2020, 08:26 AM   #131
Beagler
75
Good luck.
Amazing, every credit.
      05-25-2020, 11:44 AM   #132
jkont
23
Drives: BMW X1 F48
Good luck.
Amazing !!!
Well done my friend !!!
