08-15-2022, 11:02 AM | #1 |
247
Rep 715
Drives: 2021 X3 M40i
iPhone Cradle Removal
OK, I've searched this M2 Forum and cannot find anything on removing the iPhone Cradle in the Center Armrest/Console. Does anyone have a link to the procedure on doing this? I performed this in my 2016 F30 and it came out OK. I didn't get to swap the cable from the headunit to provide a working USB in the glove box (the one that runs to the Cradle) but I got rid of the car before I made it happen. Is it the same procedure or is it different (the center console/armrest is not quite the same...).
If you have a link, that would be great. It not, then I'll figure it out and post up the instructions/pics when I make it happen.
08-15-2022, 11:18 AM | #2 |
73
Rep 115
This thread may be useful.
Wireless charger removal? https://f87.bimmerpost.com/forums/sh....php?t=1800009 Sounds like the steps are similar to removing in the f30. |
hybrid90246.50 |
08-15-2022, 11:53 AM | #3 | |
247
Rep 715
09-03-2022, 02:03 PM | #4 |
247
Rep 715
Finally done!
So it was almost exactly like the instructions for the F30, even using the same console mat (I guess I now know why I ordered two!). The only difference was there was absolutely NO room with the vent tube in there so had to pull that to be able to maneuver the cables so had to pull that. But other than that, it was exactly the same. Here is the post I used:
https://www.bimmerpost.com/forums/sh...php?p=18737915
///MPhatic14118.50 |
09-03-2022, 02:05 PM | #5 |
247
Rep 715
Here are the before & after pics:
MooMooM21843.50 ///MPhatic14118.50 |
02-21-2024, 09:11 AM | #6 |
The Seeker
14119
Rep 3,388
Just did this job the other day. Some guys go through the trouble of removing all the wires with the cradle, but it's not necessary so I didn't bother, just tucked them underneath.
This is literally a $41 dollar, 5 minute job to get more room in your center console. First you'll need to order the OE mat (PN: 51-16-9-227-902), which you can get from getbmwparts.com (screen cap included). The process itself is super simple. 1. Use a bent trim tool to wedge between the cradle and console creating a small space 2. Use a screwdriver in that space to hold it open 3. Use a pair of pliers to grab the cradle and yank upwards and pull it out 4. Pull off the one wire that has a connector 5. Cut the other wire that has no connector 6. Put a piece of black electrical tape on the wire you cut that stays with the car and tuck it down into the hole from whence it came. |
02-21-2024, 10:34 AM | #7 |
247
Rep 715
Great write up ///MPhatic!!! This is why I love this Forum!! Were all brothers & sisters here so always happy to share useful info!!
