E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Southwest > HELP!!!
Reply
      07-19-2011, 06:36 PM   #1
Thicccboi
Drives: Bmw m6 coupe
HELP!!!
So i just got a 335i and the other day i was went full throttle on the car and in 3rd gear around 6500 rpms a yellow check engine light came one but when i turned it of the light went away,so i tried it again full throttle and it came back on!!! I took it to the shop but what does it mean????
      07-19-2011, 06:56 PM   #2
kymedic25
40
Drives: '10 535 Platinum Grey
The 335 has a lot of problems with kinked turbo hoses. Don't know if that is what is wrong with yours. When mine had a problem, I got the "Engine Malfunction, you are running at reduced power" message.
Jason
Premium, Sport, Stage 1 Eurocharged, OEM M-tech kit, DD CSL trunk lid, Smoked Blacklines, , Cyba 4 inch black chrome exhaust tips, Eibach Pro Springs, Koni FSD, Morr VS8.2
      07-19-2011, 08:44 PM   #3
Thicccboi
the only thing that came up was the half yellow engine light
      07-19-2011, 09:11 PM   #4
kymedic25
40
Mine has never come up with the engine light, so I don't know. See what the shop tells ya.
Jason
      07-20-2011, 12:41 AM   #5
GE
Drives: 2011 335i
Just curious, what year?
      07-20-2011, 01:00 AM   #6
Thicccboi
07 coupe
      07-20-2011, 01:11 AM   #7
gindajatt1
26
Drives: Like a criminal!
HPFP failure
      07-20-2011, 08:27 AM   #8
michael1284
michael1284's Avatar
213
Drives: 2018 M3 Comp
Could also be a boost leak somewhere.
e92, e90, f30 #DieselLife, e46, f80
      07-20-2011, 09:27 AM   #9
PaiNFuLSeDaTiVe
PaiNFuLSeDaTiVe's Avatar
10
Drives: 2008 BMS E90 335i AT
2008 e90 335i  [0.00]
when mine had the same issue, they replaced some VANOS sensors to fix it. If you do a search, you'll find my post with all the info (it's in this forum section) and symptoms that I had. Depending on your situation, could be the same thing, but most people default with HPFP.
2007 JB e90 retired!
2008 BMS e90 stock for now
      07-20-2011, 09:47 AM   #10
Naptime
#Hashtag
Naptime's Avatar
10
Drives: around in circles
Do you have any way to read codes?
      07-20-2011, 09:53 AM   #11
Thicccboi
Thanks man
      07-20-2011, 09:54 AM   #12
Thicccboi
No but I can probably call the shop and ask them
      07-20-2011, 10:01 AM   #13
Thicccboi
He didnt really tell.me the code but he saids something about the turbo is not getting enough pressureor losing pressure
      07-20-2011, 10:11 AM   #14
Naptime
#Hashtag
Naptime's Avatar
10
Sounds like a wastegate issue.
I wouldn't be too worried, you can adjust the wategate actuator pretty easily.
      07-20-2011, 10:20 AM   #15
Thicccboi
Thanks man they r going call me later on and tell me wuz up but if anything ill ask u how to do that !
      07-20-2011, 05:31 PM   #16
Thicccboi
well they havent figured it out yet so can i adjust the wastegate my self??
      07-20-2011, 07:40 PM   #17
bmertek
Drives: 2011 328
2011 E90 328i  [0.00]
If the high pressure fuel system is setting a fault (like a failed hpfp), the wastegates are held open so no boost can build up, therefore the engine wont go too lean. Probably something in the high pressure system due to being at higher rpm's
      07-20-2011, 07:42 PM   #18
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
I smell boost leak somewhere.. might be wastegate, maybe blew off a boot or pipe somewhere down the line. happens to my friend all the time
ERnie
2016 BSM/f80/ZCP
      07-20-2011, 08:46 PM   #19
Litos
220
Drives: 2012 Challenger RT Junk
i'll go all in with hpfp failure
      07-20-2011, 11:07 PM   #20
Thicccboi
i appreciated all the help guy ill see what the shop says tomorrow!! so is it a big deal or should i not worry about it
      07-21-2011, 09:35 AM   #21
PaiNFuLSeDaTiVe
10
I"m sure it's fixable, nothing too serious. What shop did you take it to?
      07-21-2011, 09:57 AM   #22
Thicccboi
Well I got it from Toyota of plano and they took it to some BMW shop don't really know where
Reply
e90post
