BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Spare Tire
      11-20-2018, 04:34 AM   #1
jayely1
jayely1's Avatar
223
Drives: 335i
Spare Tire
I see the kit's they make for $350 or so. Couldn't you just buy a skinny tire/rim and a jack for $150 and call it good though? Or am I missing something?
      11-24-2018, 03:19 AM   #2
jayely1
jayely1's Avatar
223
Drives: 335i
Any help?
      11-24-2018, 03:54 AM   #3
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Originally Posted by jayely1 View Post
Any help?
If you can get a skinny rim with the correct pcd and offset, a compact spare tyre with the load rating, jack and wrench for $150, why not?
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      11-24-2018, 06:49 AM   #4
Beemerbuster
15
Drives: X1 2.5D
As far I am aware all BMWs that have the four plastic jack guide pads fitted to the chassis will accept the same jack irrespective of model it was produced for.
I have a jack bought via eBay that was produced for a X3 several years ago and it works perfectly.
Be cautious of third party jacks as often the orientation of their jack lift pad end, ie the part that connects to the vehicle, is set incorrect by being in line with the jacks lift arms whereas the BMW type the lift pad is set at 90 degrees to the lift arms.
Issue is if its not at 90 degrees you would need to be under the vehicle to crank the jack up and down.
      11-24-2018, 01:03 PM   #5
jayely1
jayely1's Avatar
223
Drives: 335i
Can you provide a link to the one you got? Thanks!!
      11-26-2018, 10:50 AM   #6
Beemerbuster
15
Drives: X1 2.5D
I purchased my jack via eBay.co.uk and the original listing has now dissappeared due to time.
I have found the following on ebay which might prove useful - one of these is located in the USA.
Happy hunting - try these links
https://www.ebay.co.uk/itm/BMW-X5-CA....c100506.m3226
https://www.ebay.co.uk/itm/2004-2005...oAAOSwzINbxAVS
      11-30-2018, 01:01 PM   #7
Ridin'Dirty
Ridin'Dirty's Avatar
60
Drives: '93 'Beemer' R100r, '17 X1(S)
I picked this one up at Harbor Freight to assist when I rotate the tires. Paid something around $20US.
ttimbo281.50
      12-01-2018, 03:52 AM   #8
jayely1
jayely1's Avatar
223
Drives: 335i
That's all you'd really need besides the tire right?? Seems easy enough!!
      12-12-2018, 11:07 AM   #9
spitpilot
64
Drives: 2023 230iX, 2017 X1 M sp X
Lug wrench and a wheel chock...
