E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > RPM, Fuel and MPG Gauges Malfunctions After Coding
Reply
      05-02-2011, 01:58 AM   #1
jea
Drives: 330i Sparkling Graphite
2006 330i  [0.00]
Finally coded windows to roll up with key fob. Worked and no issue. The next day I coded bc_digital_v in the KOMBI module. Digital speed display worked, but now my fuel, mpg and rpm gauge are not functional when the engine is started. Only the speedometer works. l tried to restore setting to default, the digital speed display would be removed after coding, but the fuel, mpg and rpm gauge are still not functional after the car start. When I start the car the fuel and rpm gauge would function then the rpm gauge would flat line first follow by the fuel gauge. Anybody have this issue after coding? Any help would be appreciated. Thanks.
      05-02-2011, 05:01 PM   #2
Motastic
Motastic's Avatar
85
Drives: E92 335!
you need to help ur daten files
check this out http://www.e90post.com/forums/showthread.php?t=523305
happened to me last week
      05-04-2011, 07:57 PM   #3
jea
2006 330i  [0.00]
Thanks Motastic. After searching for the updated daten files and reading how to update the files. I finally have my fuel,rpm and mpg gauge working again.
      05-06-2011, 10:41 AM   #4
Motastic
Motastic's Avatar
85
Drives: E92 335!
glad that everything is working again
      06-22-2011, 10:01 PM   #5
S1000RR
Drives: ZCP M3
Having the same issue. Can you please post instructions on how you fixed it. I would greatly appreciate it.
      06-24-2011, 09:24 AM   #6
justa3series
Drives: 2010 328xi
Update daten files, you expertprofile and reflash KOMBI.
      06-24-2011, 11:38 PM   #7
xxxjecxxx
xxxjecxxx's Avatar
247
Drives: F30 335i M sport
2013 BMW 335i  [0.00]
2006 BMW 325i  [0.00]
The reason this happens is because the dealer has updated the software on your car and the files you are using with NCS expert at older causing the conflict.
Update your daten files and code the module (KOMBI) with a blank .MAN file that will reset everything for you, then you can code the digital speed.
      07-05-2011, 12:24 PM   #8
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
Exactly this.
      09-03-2011, 09:10 PM   #9
BRAISKI
BRAISKI's Avatar
135
Drives: '11 335xi e92 M-Pak
2011 BMW 335xi  [7.00]
After I did my digital spedo, most of my stuff got reset and the fuel gauge is not working and I have a "display speedometer malfunction". I revert it back and removed the digital spedo and still got the error.
      09-03-2011, 10:19 PM   #10
._.
74
Drives: BMW
As said before, you need the newer daten files. The solution is posted right before your post.
      09-03-2011, 11:55 PM   #11
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
+1
Update your daten to the latest files and revert to stock on your kombi (expertmode)
      09-04-2011, 10:57 PM   #12
HaZe_X
HaZe_X's Avatar
24
Drives: 2011 335is
Originally Posted by DESI4life10 View Post
+1
Listen to these guys, I had a similar problem, I had to also update my Daten files(v42), reverted the modules back to stock and my problems were fixed.
2011 335is Le Mans Blue l Black Interior l Convenience Package l iDrive l Heated Seats l Manual Trans l PROcede V5 l BMS DCI l ETS ChargePipe l Synapse BOV l
Order Date: 4/12/11
Delivery: 5/30/11
      09-06-2011, 08:17 PM   #13
BRAISKI
BRAISKI's Avatar
135
+1
Exactly what I did
Didn't need to use a .MAN blank file...
      10-09-2011, 10:01 AM   #14
Pete Schweaty
Pete Schweaty's Avatar
39
Drives: 2014 750li
Ok, for a second lets pretend I coded my digital speedometer and now I dont have any analog gauges. After I update my daten files, how do I revert to stock??? Do I use the FSW_PSW backup I made before I coded???
      10-09-2011, 10:54 AM   #15
DESI4life10
201
No..You use Expertmode profile instead of the FSW PSW profile.
Read the module and then change the job (f2) to Sg_Coderin (sp?) and then code the module. All functions in that module return to default.
Don't need to do anything with the. man files etc in this profile mode.
      10-09-2011, 11:37 AM   #16
Pete Schweaty
39
Drives: 2014 750li
Thanks ill give it a try
      10-09-2011, 12:50 PM   #17
Pete Schweaty
39
Drives: 2014 750li
WORKED PERFECT!!!
Thanks for the help. That was the scariest 4 hours of my life. Was even able to re-code the digital speedometer, no error codes, and gauges are back online. Thanks again.
      10-09-2011, 01:08 PM   #18
nineofspades
45
Drives: SSII F80 M3
Hi,
I have the exact same issue. I just did exactly as OP said, and scrwed up my fuel gauge, rpm etc.
I see from your posts above that i need to update my "daten" files.. a couple of questions --
1. Are the files i need 9GB? I've been searching for the daten files, and it looks like that may be what i need.
2. Do i want the v41, 42 or v43?
3. Any ideas where i can find them? I've tried googling a bit -- but all i can find is that 9GB file, and that seems like more than i need.
Thanks!
      10-09-2011, 01:14 PM   #19
Pete Schweaty
39
Drives: 2014 750li
Originally Posted by nineofspades View Post
Hi,
Thanks!
PM'd you. The daten files I found are for an E9X only so they are much smaller. They dont include all the other chassis.
      10-12-2011, 01:52 PM   #20
E91_schoolbus
Drives: E91
Hi,
Another noob saved by the forum! I had the same speedometer malfunction and after updating the v.42 daten files, it's all good.
After the update, anyone have problems accessing NFRM module? It throws out an error whenever it tries to read the NFRM module.
Thanks all!
      10-12-2011, 01:57 PM   #21
Pete Schweaty
39
Drives: 2014 750li
http://www.e90post.com/forums/showth...51145&page=154
Read the last 10 or so posts. Same thing happened to me, this fixed it. Props to JPHUGHAN
      10-13-2011, 08:17 PM   #22
E91_schoolbus
Drives: E91
Thanks! Let me try that out!!!
UPDATE: It worked like a charm! Thanks Pete_Schweaty and JPHUGHAN.
Reply
e90post
