BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > Canada Classifieds Section > Custom F30 Sub box, made by Musicar Northwest
      07-04-2019, 05:01 AM   #1
gsr519
Drives: 2011 335i SE
I have purchased this enclosure from them for both my E90 and my f30.
Amazing fitment and no issues with quality or movement from position.
Fitted over the battery it leaves your trunk with max functionality and looks oem, barely noticeable. Quality is amazing.
No sub or amp included, box does have pre-installed wiring thst can be reused.
Sells on website for $495 usd plus shipping and duties to Canada, roughly $700 after all said and done.
Selling for $350, I'm located in Waterloo, ON
Description from website
Musicar OE-Look Subwoofer Enclosure for BMW F30 3-Series, F80 M3 Sedans
Musicar’s OE-Look enclosures are the highest-performance subwoofer enclosures available for your BMW.
Triple-Thickness composite fiberglass walls – three times thicker than any other enclosure
Proper performance comes from appropriate interior volume and corner-loading
The “OE-Look” upholstery has been hand-dyed to match your BMW trunk
As a Musicar design element, the woofer is recessed 19mm from the outer edge
All mounting hardware and wiring is included
Our corner-loading technique gets you added sub-bass performance compared to traditional “box-on-the-floor” enclosures. To get equivalent results with a “box”, you would need two woofers – and twice the power – to reach similar SPL levels. Corner loading gets you 3-6dB at various frequencies, and you get only 3dB more by adding a second woofer, OR by doubling your amplifier power – so it’s a solid and material difference.
$495.00Quantity
ADD TO CARTCategory: OE-Look Enclosures
Description
Description
Application Notes
This enclosure does not fit the F34 3-Series GT or the F31 touring – F30 and F80 sedans only!
It is prewired with 16/4 jacketed and insulated speaker wire. Unless otherwise requested, it will be wired for a single voice coil with dual 16-gauge leads, for a functional 12-gauge capability.
The enclosure mounts with a single bolt through the inside of the enclosure, to a receiver we provide which bolts to an existing bracket.
This enclosure is validated to fit these drivers, which we recommend
JL 10W1 v3
JL 10W3 v3
JL Audio 10W6 v3 D2
Audiofrog G10
Audiofrog GS10
Audiofrog GB10
Arc Audio Arc Series 10 (no grille solution off the shelf)
Morel Ultimo SC10
Image Dynamics ID10v3 (no grille solution off the shelf)
The following woofers do NOT fit:
JL Audio 10W7
JL Audio 10TW1
JL Audio 10TW3
Image Dynamics IDQ10v3
Image Dynamics IDMAX
2011 335i SE - Ruby Black - M Sport
H&R Springs/19" 313 OEM Rims
Lux H8 v5
Individual Audio Sound/Musicar 10" JL10w6v3/JL XD600/1
M3 Lip, Roof Spoiler
      10-20-2023, 10:18 AM   #2
chrisvjs
Drives: BMW 2018 340i xDrive
Still available?
Any chance you still have this?
