09-23-2023, 12:01 AM | #1 |
Rep 5
ACC retrofit help
Hi guys!
I successfully retrofitted acc and tja on my x1 2019. Everything works perfect accept buttons on steering wheel. Tja button works like changes Distance between cars, and distance works like tja. Any ideas? |
09-23-2023, 12:07 PM | #2 |
191
Rep 637
Did you VO-code everything correct? VO-code all affected ecus
09-24-2023, 03:43 AM | #4 |
191
Rep 637
Hmm I have no real clue then… did you buy the correct steering wheel buttons?
I mean after I searched I found that BMW x1 uses a bit unusual button layout compared to other BMW’s. TJA button is switched, if you look up my post in the Post your F48 photo there I have a working steering wheel photo after replacement of the cruise control knob. |
09-24-2023, 04:29 AM | #5 |
Rep 5
My steering wheel and szl from f45, I think it's same.
Maybe wire loom in bdc from sas affect to that behavior, but I'm not sure Here video https://youtu.be/rm1zeRuVV8s?si=sLlb7lf_8fnJKDZj Last edited by Cooler; 09-24-2023 at 05:44 AM.. |
09-24-2023, 07:52 AM | #6 |
191
Rep 637
Which version of buttons do you have?
Look here, TJA should be Top-left https://www.realoem.com/bmw/enUS/sho...diagId=61_5068 |
09-24-2023, 08:57 AM | #7 |
Rep 5
Hi!
You are right I have this onehttps://www.realoem.com/bmw/enUS/sho...diagId=61_4172 What is it mean strng wheel, maybe I just need change vo. At present I have in vo 0248 Steering wheel heating 0249 Multifucrion for steering wheel 0255 Sport leather steering wheel New wheel with heating, vibrating motor and touch detection Last edited by Cooler; 09-24-2023 at 09:09 AM.. |
09-24-2023, 03:47 PM | #8 |
191
Rep 637
I think you don’t have the right buttons hardwire wise….
Which year the F45 was from? As you can see realoem should you have part no https://www.realoem.com/bmw/enUS/par...&q=61319326475 but this is only in production since 01/2016 so if the wheel comes off a pre 2016 F45 then this might be nonexchangeable retrospectively. Do you happen to know part number of the buttons? Did you also add 5AR and 5AT to VO? |
