BIMMERPOST Universal Forums Off-Topic Discussions Board Electrical Question
      02-13-2020, 01:26 PM   #1
dreamingat30fps
5330
Drives: Miata, Cayenne, Model 3, F350
Electrical Question
Ok so not sure where else to ask but you guys are always doing home renovations and what not so one of you probably know.
Backstory: So when I bought my house it has a big hottub in the screened in patio. That huttub ran on 220v. There is a 50 amp breaker in the main fuse box for the hottub, however there is also another box in the patio with another 50 amp breaker (which I believe is GFCI) and some big pull out fuse or something before the outside box that kills power to that. Ok so at some point we removed the hottub from the patio and put it outside in the yard. Ran the cable from the patio box underground to the area where the hottub is now. Anyways we now go rid of that tub and I have a ghetto inflatable one which runs on 110v. I would like to convert that 220v to a 110v outlet.
Here is my understanding of what I have to do. Replace the 50 amp breaker with a smaller breaker 15-20amp and I believe I only use 3 of the 4 wires to bring it down to 110v. Some things I'm unsure of are.
- Do I need to replace the breaker in both the patio and main panels or just patio?
- I would like the option of going back to 220v if needed in the future so do I just cap off the extra cable?
- Would the new breaker need to be GFCI or just the new 110 outlet I install.
Anyways I've done basic electrical stuff like replacing outlets, installing fans etc. However it's mainly just replacing stuff so its much easier when I'm just matching the old stuff to the new.
MKSixer34184.50
      02-13-2020, 02:12 PM   #2
TheWatchGuy
TheWatchGuy's Avatar
3905
Drives: 335xi
youre exterior breaker is the safety disconnect which is required by code for 220v direct wired equipment.
You can install a 110v breaker in your main panel, and put a gfci receptacle in your existing outside box. Or you can put 110v breakers in both the main panel and the exterior box and install a new outlet.
Another thing that you should do is figure out your load and distance and make sure your current wiring is adequate.
Are you getting it inspected? or just doing it? you can just cap the wire at both ends if the latter.
@drunkcowatches on ig
Am I a watch guy, or do i watch guys?
      02-13-2020, 02:13 PM   #3
upstatedoc
I'll get back to you
upstatedoc's Avatar
7562
Drives: blue streak
sounds like a perfect scenario for electrocution
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
Appreciate 4
MKSixer34184.50
Salty Dog3574.50
RickFLM410981.00
Dang3r12512.00
      02-13-2020, 02:19 PM   #4
TheWatchGuy
3905
Drives: 335xi
also this.
just get a pro to come do it. if youre asking these types of questions on a car forum, youre already fucked.
Appreciate 5
MKSixer34184.50
Salty Dog3574.50
RickFLM410981.00
Maynard3848.00
      02-13-2020, 02:25 PM   #5
dreamingat30fps
5330
also this.
Yeah I'm looking into pros also but that's another cluster fuck, most of the ones I call fall into 3 categories.
1. Wont quote me a price want me to pay a service call fee for them to come look at it and then tell me how much.
2. Don't want to do it because I ran the line outside myself and I guess they don't want the liability or what not.
3. Sound like they know less than me
What will probably end up happening is I never install shit and just keep running an extension cord from my existing 110 outlet.
Salty Dog3574.50
      02-13-2020, 02:27 PM   #6
TheWatchGuy
3905
Drives: 335xi
1. fairly typical but most will work that into the final price.
2. legally they would have to remove and reinstall that line
3. doubtful
Appreciate 3
MKSixer34184.50
Salty Dog3574.50
      02-13-2020, 04:07 PM   #7
Kolyan2k
922
Drives: 2006 S2000
Yeah not something you want to do yourself if you have those questions.....
But anyway, 1. You need to replace breaker at panel and get rid off the disconnect outside and install proper outside fitting and a box that supposed to take 110v outlet (and need bubble cover). 2. Yes, just cap it. 3. I would install GFCI breaker at panel and regular outlet outside. You also need to reduce the wire size ends, I doubt you can get 50amp wire properly secure at outlet and at the breaker.
The cable that you ran underground also need to be made for underground, you cant just run any cable.
Rmtt8211.00
      02-13-2020, 04:18 PM   #8
zx10guy
5150
Drives: 2013 135i
Or put in a conduit.
Rmtt8211.00
      02-13-2020, 04:20 PM   #9
dreamingat30fps
5330
Yeah I figured I would have to mess with the main panel, I don't really want to mess with that so will either disconnect the cables going out of the box in the patio (just for added safety it's obviously switched off at both breakers and the disconnect removed) and keep my extension cord setup, or get a pro to check it out. At this point I guess my main concern is the pros not wanting to work on it without digging up the cables we ran which I have no desire to do, that was a big project.
      02-13-2020, 04:21 PM   #10
MKSixer
MKSixer's Avatar
34185
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Call electricians until you get a few that are willing to bid the job and decide from there. Don't mess with jack-legged electrical set-ups. ESPECIALLY around hot tubs. WTF am I reading here?!?!!
Safety first!!
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
Rmtt8211.00
      02-13-2020, 04:23 PM   #11
dreamingat30fps
5330
I don't remember what cables we used, I think we matched what was there before, some pretty thick stuff. When it comes out of the ground we used some flexible conduit, but for the under ground run I do recall we used a hard conduit of some kind.
      02-13-2020, 04:30 PM   #12
Salty Dog
Salty Dog's Avatar
3575
Drives: Austin Mini,MBGLK, Porsche 993
Safety first!!
Safety Third my friend, safety third.
Appreciate 3
MKSixer34184.50
upstatedoc7561.50
      02-13-2020, 05:17 PM   #13
Kolyan2k
922
Drives: 2006 S2000
There isn't that much to bid on, sounds like $300-400 job max plus parts
      02-13-2020, 05:31 PM   #14
dreamingat30fps
5330
See if they could at least say that. I'm obviously not an electrician and I've actually never needed to hire an electrician so I have no idea what something like that would cost. Yet when I call and ask they are surprised I want to know how much it costs. The stuff I have needed done (not electrical) they usually either give me a quote over the phone or come out to look at it and give me a quote then. I can then decide if it's worth the $$ to me and pick whoever has the best price and/or seems the most knowledgable.
The only other people I know of that charge by the hour and have no idea how long it's going to take are hookers.
Anyways I did find one company that said they would come take a look and did not charge a service fee for it. So we'll see what they say, if it's like under $300 I would do it, more than that... I dunno... I'll hide the extension cord behind some plants or something.
      02-13-2020, 05:40 PM   #15
Rmtt
Rmtt's Avatar
8211
Drives: 2011 BMW 128i, 2008 LS3 C6
I'm an Electrical Engineer so just that you know I'm not guessing here, but my advice is what I tell anyone else who has come to me with these types of questions.
Have someone who is licensed and insured do the work. If something goes wrong, improper wire size for the current load, wrong breaker, wrong direct burial cable, etc.....and something such as a fire breaks out....your homeowners insurance will hang you out to dry as they will investigate every possible scenario.
They can be as picky as distinguishing between a "grounding" conductor and a "grounded" conductor.
It's a simple thing you are wanting to do and the general gist of it is laid out by other posters here, but doing it yourself is a liability once you open the circuit panel.
Maybe not what you want to hear, but someone licensed so you are covered can easily do this so it won't be that expensive.
Everybody has a gameplan....until they get punched in the mouth.
Appreciate 7
RickFLM410981.00
zx10guy5149.50
MKSixer34184.50
nyalpine907433.00
      02-13-2020, 08:57 PM   #16
RickFLM4
RickFLM4's Avatar
10981
Drives: M4
If you are in PB County I have used a good electrician I can refer. Just PM me. He’s on his own, not a big outfit, so I’m not sure how far he would travel. (We are in Wellington and he is in this area.)
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
Rmtt8211.00
      02-14-2020, 07:35 AM   #17
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
+1
if something was done incorrect, correct it right away. one less thing to worry about if something goes wrong. Alot of people do DIY, but its wrong, not up to code and its becomes $$ and dangerous.
Rmtt8211.00
      02-14-2020, 10:04 AM   #18
UncleWede
UncleWede's Avatar
18028
Drives: G01 X3 M40i Dark Graphite
This new hot tub is for your future deceased wife? IS the insurance paid up, and are you the single beneficiary?
I wouldn't even hire my IBEW son to do this, I'd get a 3rd party that has insurance. My son wired in the doorbell, and it still rings funny SOMETIMES.
      02-14-2020, 10:16 AM   #19
Kolyan2k
922
Drives: 2006 S2000
Now he is definitely not hiring an electrician
UncleWede18028.00
      02-14-2020, 10:59 AM   #20
dreamingat30fps
5330
Please I'm not an idiot! I would have certainly tested it before letting her get in!
I believe my mother in law loves hottubs....
Appreciate 4
upstatedoc7561.50
UncleWede18028.00
Rmtt8211.00
vreihen1615280.00
      02-14-2020, 01:05 PM   #21
UncleWede
UncleWede's Avatar
18028
Test subject: selected
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
      02-14-2020, 01:27 PM   #22
MADBMWX5MC
MADBMWX5MC's Avatar
743
Drives: 2023 BMW X5MC
You are a better man that I am ...I just don't mess with electricity--other than changing a light bulb.
2021 Jeep Grand Cherokee SRT Black
2006 Ford Mustang GT Convertible (car-show car)
