08-13-2022, 05:48 AM | #133 | |
Rep 41
08-19-2022, 06:50 PM | #134 | |
623
Rep 527
I have a Canadian M550i with 5AT and 5DN and a build date in October 2017. The paper manual does not show lane change assist. I have E-Sys 3.30.1, launcher pro 2.8.1 and PSdZData lite 4.36.22. I don’t see Spurwechselassistent in HU_NBT2 nor C_SWA_Vorhanden in SAS2. I’m guessing this is because I have esys setup wrong (my first time if it isn’t obvious), or would it mean my car has no chance to get this to work?
2018 M550 with all the goodies
08-20-2022, 12:38 AM | #135 | |
2374
Rep 8,364
08-26-2022, 01:53 PM | #136 |
623
Rep 527
I purchased bimmerutility and coded the 3 values. Worked on the first shot. Nothing new shows up in Idrive, but the car changes lanes automatically when the signal is on. (Don’t need to hold down the lever) My software was updated by the dealer in April ‘22.
Like most features of this nature, it’s mostly a party trick, with some utility, and also a little bit scary to experience the first time. |
01-16-2023, 08:07 AM | #137 |
81
Rep 179
UPDATE - While I was driving abroad these days it crossed my mind that I should try this function when driving assistants are all ON and voila - IT WORKS. Then I've crossed several countries and in all of them it worked with no issue.
However, it is not working in my own country(Serbia). Here SLI also doesn't work by default, but I've coded it and it now does. Not sure if anything else could be done so that lane change assistant starts working too. C_SWA_Land_Aktiv was set to "FF, FF, FF, FF". It is certainly a gimmick, but my OCD wants this to work. |
01-16-2023, 09:50 AM | #138 | |
227
Rep 469
01-16-2023, 11:58 AM | #139 |
623
Rep 527
01-16-2023, 06:04 PM | #141 |
623
Rep 527
Same as everyone else-
The 3 codes to be changed are: HU_NBT: Spurwechselassistent - Change this to Aktiv SAS Module: C_SWA_Vorhanden - Change this to True C_SWA_Land_Aktiv - You will have to edit the Werte values to "FF, FF, FF, FF" |
01-30-2023, 12:01 PM | #142 | |
Rep 2
I though find quite a lot of *_Land_Aktiv for RGA etc ... |
03-01-2023, 03:41 PM | #143 |
Rep 3
Help coding
I have tried to code this three values with E-Sys, but I am not able to find it. Where do I have to look? Can anybody explain the way to get to these values?
I have a 2022 G30 and I use the PSdZ_lite files. |
03-02-2023, 12:43 AM | #144 |
2854
Rep 5,148
My new g30 built feb 2023 for the U.K. has it disabled which is odd as it was enabled for my July 2017 g30
( has legislation changed?) I also notice from vin decode that I have option 8TR which I believe removes it. I could be wrong but thought that was for cars with individual paint. My car does have it I will ask the bmw genius today although don’t hold hold up much hope they will be able to answer anything remotely technically detailed! |
03-03-2023, 02:18 AM | #145 |
2374
Rep 8,364
All Psdzdata files are unmapped. You need to use new solution like Bimmer Utility to be able to find values.
03-03-2023, 06:56 PM | #146 |
Rep 3
03-03-2023, 06:57 PM | #147 |
Rep 3
07-10-2023, 07:16 PM | #148 |
Rep 10
07-12-2023, 05:12 PM | #150 |
Rep 10
So no luck? I really don't know what to do next, can't find any solution, or reason as why I don't have the codes present there.
12-22-2023, 02:20 PM | #151 | |
17
Rep 30
Hi mate! How did you code it? I really would like to have it on my G30. I already have looked around in protool but, can't make it work. Thanks in advance |
02-09-2024, 04:24 PM | #152 |
4552
Rep 5,406
What does the brain-trust think of this?
https://www.aliexpress.us/item/32568...usa#nav-review I think it looks like it eliminates the need to constantly touch the wheel. |
