09-26-2023, 09:55 AM | #1 |
Rep 18
dim headlight halo
Hey everyone,
Wondering if anyone knows of any diy solutions for a dim halo in the headlight? (Pic below) 2020 x3 m40i - 3.5 yrs old and 97k kms, so out of warranty. I found 1 YouTube vid with a similar problem for an x3 F25 (link below) and at least for those modules the light tube seems replaceable. https://youtu.be/30YMZmoPpSs?si=cxtoKyGlVIekQJGa Fyi, having called parts at my local bmw dealer in Oakville (Canada) I was advised to have it looked at by service. Apparently if the fault is just with the light module its $330 (for part only) but if it's a problem with the assembly then it's $4300. So yeah, am i SOL or is anyone aware of any DIY solutions? |
09-26-2023, 02:50 PM | #2 |
413
Rep 302
I had the same with my G01 18 months or so ago. Dealer said the whole light assembly had to be replaced at a cost of over £2K (the lights are the 'adaptive' LED ones). Luckily I had a BMW extended warranty which covered it.
One thing: When you bring it into your dealer, ask them about any outstanding BMW Technical Service Bulletins around this issue. I'm sure there was a TSB mentioned when I originally had this. So, if you're lucky, it might be a known issue with this model which they will still fix under warranty even though yours has expired. Good luck! |
09-26-2023, 04:43 PM | #3 | |
Rep 18
Thanks for the tip! |
09-26-2023, 08:07 PM | #4 |
331
Rep 1,560
Drives: 2022 X4M40i, retired ‘11 X3
Def a known issue with a tsb on it.
NoMoreVauxhalls412.50 |
