07-22-2016, 03:10 PM | #1 |
136
Rep 1,592
How to code "Office" into 2016 340i without enhanced BT?
I just ordered the cable required to do coding on my new 2016 340i. The main purpose will be to code out the stupid warning screen at start up and have the doors unlock at engine off. (I'm sick of explaining to passengers they have to pull twice) However I'd also like to get the "Office" option on my nav system so I can see texts when they come in. A lot of the info I'm finding on these forums seems to mixed based on the year of the car. I don't want to screw it up so I'm wondering if anyone could explain exactly what needs to be done on a 2016 340i to enable that feature?
07-22-2016, 06:02 PM | #2 |
BMW Aficionado
1363
Rep 1,827
Code the following to werte = 01 within the HU_NBT2 (Evo) ... same coding is true for the NBT unit:
SINGLE_OR_MULTILINK CONTACT_BOOK_PICTURES BLUETOOTH_2ND_HFP MACRO_PIM PIM_SPEECH_TO_TEXT PIM_NEW_ELEMENT_VOICE_EMAIL PIM_BILDER_EIN_AUS CALENDAR_EIN_AUS TASK_EIN_AUS REMINDER_EIN_AUS TEXT_NOTES_EIN_AUS AUDIO_NOTES_EIN_AUS SMS_EIN_AUS EMAIL_EIN_AUS PIM_NEW_ELEMENT_EMAIL PIM_NEW_ELEMENT_SMS PIM_NEW_ELEMENT_AUDIO_NOTE API_USB_VIDEO ... werte = 03 These lines above are everything that the 6NS enhanced bluetooth adds |
07-23-2016, 12:47 AM | #3 |
2374
Rep 8,364
07-23-2016, 12:19 PM | #4 |
BMW Aficionado
1363
Rep 1,827
07-23-2016, 01:00 PM | #5 |
2374
Rep 8,364
07-23-2016, 01:13 PM | #6 | |
284
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
07-25-2016, 11:18 AM | #7 |
136
Rep 1,592
I was a little lost too. But found this post on another forum that explains VO and FDL...
http://www.bimmerfest.com/forums/sho...d.php?t=837221 |
07-25-2016, 01:14 PM | #8 | |
284
Rep 703
07-25-2016, 02:11 PM | #9 | |
2374
Rep 8,364
07-25-2016, 06:25 PM | #10 | |
136
Rep 1,592
I just got the cable in the mail. Wont have time to play with it until probably Sunday though. |
07-25-2016, 07:24 PM | #11 | |
2374
Rep 8,364
Both processes may begin by selecting "Read" FA, which includes things like VINlong, chassis, upholstery type and color, exterior color, and production date as well as a list of standard and other options. An unmodified FA read from the Vehicle Configuration Management (VCM) would essentially contain the identical information of a decoded VIN. If you read "E-sys - Getting Started Supplement - Part 3" AKA "How to change FA in F-series car," Steps 8-10 (Pg 8-9) outline how to write modified FA to vehicle. If followed, then next time you connect and "Read" FA, it will show your changes. Alternatively, you could "Load" a FA, modified using E-sys FA-Editor (Step 6, Page 6). This way, you can make VO changes without writing to VCM. There are various reasons to consider both ways, but see ShawnSheridan's rules on retrofits. I also can send you a collection of getting started documents if you like. Material would be very similar to the above linked, but include an overall summary sheet to serve as sort of a study guide as well as cheat sheets and potentially other helpful documents. |
07-26-2016, 03:22 AM | #13 | |
2374
Rep 8,364
Re warranty: it has been asked many times and you will get mixed opinions, but the general dogma is no and there are ways to minimize risk. There are certain hardware modifications, which will and will not void warranty, but I will just share my thoughts on coding. First, it is a bit of a misnomer. For F-series and others that use E-sys, unlike the hacking and manipulating lines of codes portrayed in movies, it is little more than changing predetermined drop-down menus. Further, many of these changes are to enable factory options available in other countries but restricted in another due to outdated regulations like adding ability to close trunk with FOB or enable options now standard on later productions like phone & entertainment details in HUD. And, though you can still do real damage if you do not know what you are doing, there are checks in place, including TokenMaster's token solution, which maintains the security of files. Therefore, you will be fine if you stick to good cheat sheets, realising that they are ECU specific so not to change random parameters meant for different hardware like using Xenon values for coding welcome lights in LED headlamps resulting in premature burnout or messing with things like drivetrain. Moreover, the following also help minimize risk. Uncheck Update VCM and MSM in E-sys options so that you do not write coding logs to vehicle, which can be read at service and sent back to Munich. Also, it is up to you whether you revert changes back to factory before taking to service so that only thing that can be seen is last coded date. Some will completely code back to factory, while others may change only certain values like reverting folding mirrors or if they disabled auditory seat belt warnings. Service centers are not going to spend time looking for changes unless you give them one and flash programming will wipe coding anyways on any module with newer available software at the time of service for a known issue. Personally, I do not know anyone or read about anyone who has gotten in trouble for coding and I have turned in vehicles for regular service and at the end of a lease with and without coding in place without any issue. Lastly, I know individuals, including someone whose CPO I just re-coded last week because he realized and wanted back lost features, wiped at his first scheduled service due to firmware updating, the previous owner must have coded. |
07-30-2016, 05:04 PM | #15 |
2374
Rep 8,364
08-15-2016, 02:05 PM | #16 |
233
Rep 241
Drives: '19 330i xDrive M Sport
this may be a dumb question but what does enhanced Bluetooth get you? would it cause problems if I code it in my NBT evo that has connected drive active?
Current: MY2019 330i xDrive M-Sport w/Lasers - Portimao Blue
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey BMW CCA #522637 use me as a referral for BMW CCA |
08-17-2016, 04:52 PM | #17 | |
78
Rep 1,241
Drives: 2016 BMW 340i
If it will, and I prefer not to have to redo the previous coding, would it not be better to just make FDL changes listed in CaboM4's post above and not mess with VO/FA coding?
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
08-17-2016, 06:06 PM | #18 | |
2374
Rep 8,364
Yes, VO coding will set coded ECU's to factory values, overwriting any FDL coding previously done. |
