04-26-2016, 11:51 PM | #23 |
1154
Rep 1,545
I still have to swap my diff fluid, too. Aside from the fluid/oil, you'll need replacement plugs (fill and drain) since the washers are part of them and are one time use.
Also, you'll want a stubby hex driver for the fill plug since it is a bit tight to get to.
- Jeff
bosstones' flickr |
04-27-2016, 12:37 AM | #24 |
2936
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Thanks! Any sources for ordering these parts? I'm hoping to source the diff fluid from Diffsonline.com
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
04-27-2016, 01:08 PM | #25 |
157
Rep 1,107
04-27-2016, 01:56 PM | #26 |
64
Rep 666
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Not a good idea to put 1/2 Redline D4ATF & 1/2 Redline 75w140NS Gear Lube in your transmission.
I suggest either Red Line D4ATK or MTL or 50/50 MTL and MT-90.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
04-29-2016, 06:07 PM | #27 | |
1154
Rep 1,545
For the fluid, I just went w/ the OE from a dealership + CCA discount. I ordered the plugs from Tischer when I ordered a few other parts. They still have stock, but Pelican has them for cheaper (not that they are uber expensive to begin with). I'd check what they cost at a local dealer. Since the parts aren't very expensive, paying for shipping might make it more expensive than get it from a dealership. http://www.pelicanparts.com/More_Inf...5-064-M58#tab5 I ordered my stubby hex driver from Snap-On.
- Jeff
bosstones' flickr |
04-29-2016, 10:26 PM | #28 | |
2936
Rep 3,286
05-09-2016, 12:24 AM | #29 |
2936
Rep 3,286
Ready to change the transmission and diff fluids!
05-09-2016, 04:43 PM | #30 |
28
Rep 204
You won't have to take turns to distribute the diff oil on these cars. That's only for cars with solid rear axles so the oil can get all the way down the tube to the wheel bearings. Z4s only came with IRS.
05-10-2016, 11:17 AM | #32 | |
Rennfahrer
49
Rep 200
Current- Jerez Black E92 M3 | Arctic Silver E36 M3/4/5 | Monaco Blue E90 325xi Past- AW Z4-M roadster| JB Z4-3.0si | '98 Accord V6 coupe |
05-24-2016, 07:06 PM | #33 |
Rep 26
http://www.automobile-catalog.com/ca...drive35is.html
other model info available on the same site |
05-25-2016, 03:35 PM | #34 |
191
Rep 453
Drives: 2007 Z4M Coupe
Got my 8 mm stubby from Amazon. Pretty cheap and worked well.
Williams 35608 3/8-Inch Drive Impact Hex Bit Stubby Driver, 8mm, 1-Piece https://www.amazon.com/dp/B007YRAORG..._LWGrxbXMNH76K |
05-27-2016, 08:13 AM | #35 |
126
Rep 355
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
06-01-2016, 11:05 PM | #36 |
60
Rep 932
Purchase a stubby hex socket for the transmission fill plug. The plug is aluminum and stripped easy if not seat completely in the plug.
I"vie been using Amsoil 75w-90 MTF and Liqui Moly oil for engine and diff with no issue. |
04-08-2024, 10:23 PM | #37 |
26
Rep 11
This thread is super helpful. Thank you!
Taking delivery of my 06 Z4MR this week (34K miles). PPI showed rear diff oil seal leak, so that will be the very first thing I will ask my indy shop to take care of, and top off new differential fluids. Would it make sense to do transmission fluid flush as well in one swoop? And besides engine oil change - which I plan to do myself - which of the following are high priority, while others can wait until next spring? (This will be a 3-season weekend car; will at most drive 3000 miles per year) Is there anything on this list that I can try to DIY? - Brake fluid flush - Power steering fluid flush - Coolant flush - Valve adjustment Many thanks! |
04-08-2024, 10:26 PM | #38 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Valves and brakes if no docs of inspection one being done
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
Zed4Em26.00 |
04-08-2024, 10:58 PM | #39 |
26
Rep 11
04-09-2024, 01:04 PM | #40 |
157
Rep 1,107
Adjusting the valves isn’t technically hard, but it’s rather time consuming and not for the faint of heart. There are videos out there that are very good. If you have a mechanic do it, go with a BMW specialist, someone that has done many of them (on S54 motors specifically) and can do it in their sleep.
Brake, transmission, and diff fluid swaps are easy DIY jobs. You’ll need a stubby 8mm hex socket for the transmission fill though. You should also check condition of the belts. If no records on when last changed you should DIY those as well, they’re relatively quick and easy. |
Zed4Em26.00 |
04-09-2024, 03:05 PM | #41 |
457
Rep 977
I would not let anyone but me touch the engine for something as simple as a valve adjustment ñ. There are more ignorants calling themselves specialists that would do more harm than any educated DIYer
