BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Wheel Spacers for the X1 (F48)
      08-14-2017, 04:32 PM   #23
BombaE90
BombaE90's Avatar
Drives: 2011 E90 M3
Lots of good info in this thread. Thanks.
      08-16-2017, 04:50 AM   #24
vince1288
33
Drives: F48 Sdrive 20i
exwon
BBS LM F/R 8.5J ET32
      08-16-2017, 11:19 AM   #25
mr_lab_rat
mr_lab_rat's Avatar
566
Drives: 2017 M2, 2018 X1
Nice, do you have a shot straight along the side of the car to show how flush the rims are to the fender? I have my eyes on some 8.5 ET35 so that would confirm my fittment
      08-16-2017, 01:13 PM   #26
808X1
80
Drives: F48 X1 M-Sport
Nicely done
Originally Posted by vince1288 View Post
exwon
      08-17-2017, 10:05 PM   #27
exwon
Drives: 2017 BMW X1
exwon
      08-21-2017, 12:33 AM   #28
vince1288
33
mr_lab_rat
FYI
you'd better go 235-40-19 or 225-45-19 otherwies tire will scratch the wheel arch. (Crurrenty mine rear tire is 245-40-19, I will need adjust camber or replace them)
      08-21-2017, 11:39 AM   #29
mr_lab_rat
mr_lab_rat's Avatar
566
Thanks, I'm gonna do 18s, likely with 235/50. The wheels I want are available as ET35 and ET45.
      08-21-2017, 12:56 PM   #30
Encanto
Encanto's Avatar
1166
Drives: 2021 X3 M40i
Offsets without wheel depth are meaningless.
      08-21-2017, 05:09 PM   #31
mr_lab_rat
mr_lab_rat's Avatar
566
Oh, I was just following up on a conversation with Vince. They are 8.5 like his, just smaller diameter (18 vs 19).
      09-18-2017, 11:26 AM   #32
808X1
80
15mm Front and 20mm rear on stock 18"
Front
Attachment 1691643
Rear
Attachment 1691644
Front/Rear from Afar
Attachment 1691645
Rear/Front 3/4 View
Attachment 1691646
DARKMTTR229.00
Will Pwr748.50
      09-18-2017, 11:58 AM   #33
mr_lab_rat
mr_lab_rat's Avatar
566
That's just about perfect. What brand spacers, are they hub-centric?
      09-18-2017, 12:35 PM   #34
808X1
80
They're ECS Tuning spacers made for the F48 X1 and Mini Cooper. They're also hubcentric 👍🏻
      09-18-2017, 03:27 PM   #35
mr_lab_rat
mr_lab_rat's Avatar
566
Cool, thanks. I'll probably get those for the winter setup. Summer wheels will have the right width and offset without spacers.
I'm also looking at the H&R DRA spacers (I have them on my e46 and much prefer them). But they don't make them for Mini. They have 5x112 CB 66.5 for Audi though. That could work with maybe small modification.
      09-18-2017, 04:17 PM   #36
808X1
80
Sounds good. If the H&R spacers are 5x112 and CB 66.5, then they should fit the F48, no probs, even if they're for AUDI, unless the holes are misaligned.
      09-18-2017, 05:51 PM   #37
mr_lab_rat
mr_lab_rat's Avatar
566
The Mini/F48 is sometimes listed as 66.6 or even 66.7 center bore. That has me slightly worried but I can get them shaved if I have to.
I love the DRA type as it doesn't require longer bolts (the spacer bolts onto the hub and the wheels bolt onto the spacer)
      10-04-2017, 11:46 AM   #38
mr_lab_rat
mr_lab_rat's Avatar
566
A quick update on the Audi DRA spacers. They won't work because the bolt thread pitch is different (M14x1.5 vs M14x1.25). Technically I could get them, modify my BMW bolts (shave heads) and use them to secure the spacer to the hub. Then use Audi bolts to secure the wheel to the spacer.
Looks like too much work while still facing potential hub bore issues.
ECS tuning has hubcentric spacers specifically for the Mini and F48.
      10-04-2017, 12:45 PM   #39
808X1
80
Bummers about the H&R ones. ECS ones for the Mini and F48 fit well and has performed flawlessly thus far.
      10-04-2017, 01:51 PM   #40
Pnorth
Sweden
23
Drives: M235i & X1 2.0d
it was BBS CHR 19" F8.5J ET40 235-40-19, R9.5J ET45 245-40-19.
Hi Vince,
Great looking car!
It looks like you’ve adjusted camber in the rear or is that a result of the drop from the KW?
Brgds,
Paul
      01-26-2018, 06:19 PM   #41
TSiSPY007
70
Drives: 13 335i xDrive;16 X1;96 4G63T
Anyone with updates or headsup re: the H&R DRA 20mm spacers? Definitely getting spacers this Spring and hoping not to have too many diff sets of bolts around... the hub-centric spacers by ECS would require longer bolts, correct?
Thanks!
Fred
      01-26-2018, 07:27 PM   #42
808X1
80
Yes, they require longer bolts. You can get them as a Kit.
Thanks!
Fred
      04-20-2018, 12:46 AM   #43
DARKMTTR
DARKMTTR's Avatar
229
Drives: '20 M2 Competition & '18 X1
Front
Attachment 1691643
Rear
Attachment 1691644
Attachment 1691645
Rear/Front 3/4 View
Attachment 1691646
Hey 808X1,
I just ordered these spacers in the exact same spec 15mm F, 20mm R... how are you liking them? Have you noticed any drastic changes in handling?
Thanks!
2020 BSM M2 Competition | Blue Stitching | 6MT | Sunroof | My M2C European Delivery Story! | AA EL Midpipe | TMS Skid Plate
      04-20-2018, 02:22 AM   #44
808X1
80
I like the ECS Spacers . I now run 15F and 15R. When I was running 20R, there were no drastic changes that I could discern for every day driving, but there was more understeer at 7/10 during cornering; however, when I went to 15R, cornering was a bit more neutral and less understeering than the prior set up. Despite this, the car was more stable in the corners with either set ups due to the wider stance, I suppose.
Originally Posted by MSport X1 View Post
Hey 808X1,
Thanks!
DARKMTTR229.00
