05-03-2024, 09:22 PM | #1 |
10
Rep 49
Tire size/spacer help!
Looking for information regarding tire size and wheel fitment.
New wheels are: 19x9.5 et27 front 19x11 et15 rear What is the best tire to run on these and will I need to run a spacer for flush fitment? Currently on stock ZCP suspension but subject to change in the near future. Thanks in advance! |
05-03-2024, 11:12 PM | #2 |
2485
Rep 5,974
19x11et15 will NOT fit even with -4 deg of rear camber. An 11et25 is an aggressive setup. 11et15 not possible unless you run 5-6 deg of neg camber and a super stretched 245 mm tire, even then it still probably won’t work. Where did the 11et15 spec come from? That’s a g8x wheel fitment.
Front would be a 275 with an 8 mm spacer (would require a hub extender) or a 10 mm spacer (3-5 mm more aggressive than the common 9.5et20-22). |
05-04-2024, 02:54 AM | #3 | |
10
Rep 49
These wheels: https://www.m3post.com/forums/showthread.php?t=2100573 |
05-04-2024, 06:17 AM | #4 |
2485
Rep 5,974
Are you sure the wheels aren’t 11et25? An 11et15 would stick out 0.393” more than 11et25 with 295/30 tires is already extremely flush fitment. Also 10.5et22 is a very flush fitment with 295s.
Do you know the tire sizes that were on the wheels in single pic in the FS thread? Really need to see a side shoot to see how well they fit and how much negative camber was used. |
05-04-2024, 06:28 AM | #5 | |
10
Rep 49
They said 245/35 front and 285/30 rear. Hopefully it's a typo or something. |
05-04-2024, 09:45 AM | #6 | |
2485
Rep 5,974
I have four setups for my two e92 M3s - HRE R43 “Fall line” F 18x9.5et20 with 275s + R 18x10et17 with 285s & HRE R43 “Fall Line” F 18x9.5et20 with 275s + R 18x9.5et20 with 275s & HRE R40 F 18x9.5et20 with 275s + R 18x10et17 with 285s & HRE 446R F 19x9et18 with 245s + R 19x9.5et15 with 265s & Team Dynamics Pro Race (winter setup) F 18x8et20 with 235s and 18x9et20 with 255s. I also have f8x wheels that will fit the e9x M with |
