View Poll Results: Do you change your own tires? | |||
Yes | 30 | 62.50% | |
No | 17 | 35.42% | |
Sometimes/Depends | 1 | 2.08% | |
Voters: 48. You may not vote on this poll |
10-29-2022, 05:23 AM | #24 | ||
1240
Rep 1,446
10-29-2022, 05:35 AM | #25 | |
1240
Rep 1,446
tranquility3244.50 |
10-29-2022, 06:23 AM | #26 | |
952
Rep 781
The threads slide easier so you end up with a higher torque value than you would with a dry torque. 120NM or 85ftlbs may not seem like much but the 20 lug bolts/nuts are arguably the most important bolts on the car and their torqueing should be precise, by hand with a torque wrench. I rarely take my vehicles in to a shop for work unless it is something I can't handle, but when I do the first thing I do when I get it back home is loosen the lug nuts and retorque them by hand. They are almost always over torqued.
2008 E86 M coupe
10-29-2022, 07:24 AM | #27 |
General
17315
Rep 18,737
OP, you need a better impact gun. I have that plug-in electric impact wrench, which I bought 30 years ago when I had a different workshop location (out in front of my house on the street with jackstands - LOL). It was a Sears Craftsman model made by Black and decker. It worked ok, but it is old tech compared to modern battery-powered 1/2-drive impacts.
I've since switched to air tools mostly, but recently picked up a Milwaukee M12 impact for lighter to mid impact needs. It won't remove BMW wheel bolts even though it is rated at 250 pound-foot reverse torque. Removing wheel bolts, or any type of bolt takes much more torque than the torque-set spec, which is why all impact guns are rated for reverse-torque. And that is your impact's problem, it's weak on reverse torque. Find a 1/2-drive battery-powered torque gun that is 18V - 24V and specifically meant for removing wheel nuts/bolts.
10-29-2022, 07:44 AM | #28 | |
General
17315
Rep 18,737
Anyway, long story short, the left rear wheel had to be removed to replace the hose. A few months later on my lift for a tire rotation, one of the wheel bolts would not come off. I have a decent-sized Ingersol-Rand 2130 air impact gun, which never has problems with removing anything. I kept hammering at it. Nothing. I then went to my trusted, tried and true 24" breaker bar. Nope. Then the pipe extension on the breaker bar. Snapped the impact socket in half. I guess the torque stick the BMW tech used didn't get the torque right.
________4158.50 |
10-29-2022, 08:05 AM | #29 | ||
1240
Rep 1,446
10-29-2022, 08:09 AM | #30 | ||
1240
Rep 1,446
10-29-2022, 08:11 AM | #31 | |
General
17315
Rep 18,737
Back when I was driving 35,000/year just in one car, my E90, I rotated tires every 5,000 miles, so 6 times a year. When I set the torque at 88.5 pound-foot, I never had removal issues. It was just this one time when the tech over-torqued just the one wheel bolt. What I noticed more was the excessive hammering of the bolt flats wore both the hex head of the bolt AND the impact socket to the point where the bolts would get stuck in the socket. I replaced all 20 wheel bolts eventually and buy a new 17MM impact socket every few years.
________4158.50 |
10-29-2022, 09:05 AM | #32 | |
1240
Rep 1,446
10-29-2022, 10:03 AM | #33 | |
General
17315
Rep 18,737
________4158.50 |
10-29-2022, 10:29 AM | #34 | ||
1240
Rep 1,446
Like all these tire places are torquing anything. They just gun them up and on to the next. From what I've seen |
10-29-2022, 10:52 AM | #35 |
379
Rep 1,002
Drives: 2007 Z4 M Coupe 2012 e93 M3
Not sure what electrici Impact Gun but sounded like the OP need a better Impact Gun.
I have a Milwaukee M18 Impact Gun and it has almost 1,500 ft-lbs of nut-busting torque. |
10-29-2022, 10:56 AM | #36 |
The Seeker
13863
Rep 3,325
This thread and the information in it is literally scaring the shit out of me.
Never ever ever ever ever ever ever put anti-seize on wheel studs, lug nuts, or lug bolts, ever. I have a Summer and Winter set for all 3 of my vehicles, change all the wheel/tire combo's myself and have been for many years. My daily does go to Honda for oil changes and tire rotations, but I always retorque the lug nuts to the proper spec as soon as I get it home. On the rare occasion the Lotus goes to the dealer and they have to take a wheel off I mark the lug bolts with a marker and take photo's, then educate them after they mess up the torque. Happens every time no matter what I tell them. Tire installs I leave to the professionals. |
10-29-2022, 10:56 AM | #37 | |
6560
Rep 2,311
Drives: 9Y0 Cayenne S
350ft-lb tightening torque probably means around 1000ft-lb breakaway, check the ratings. You also need a long 1/2" breaker bar. Standard tool for anyone who DIYs car stuff. Anti-seize = never ever Get a pneumatic impact wrench with and a small compressor. You will thank yourself. |
10-29-2022, 11:05 AM | #38 | |
1605
Rep 787
It leaves just the most faint amount of lubricant behind which prevents future rust, and lube for when you want that lug to come back off. WD-40 is a small chain hydrocarbon similar to paint thinner, with heavy grease (similar to petroleum jelly) diluted in it. The lighter "paint thinner" component evaporates off, leaving behind just the small amount of grease. |
________4158.50 |
10-29-2022, 11:11 AM | #39 |
General
17315
Rep 18,737
Agree 100%. If anything, I see shops use a torque stick but who knows if those stay in calibration. I use my gun to run the bolts/nuts down, but I don't let it hammer the fastener. I use a torque wrench; one day I'll get around to doing the at-home calibration test.. LOL
chris7197334.00 |
10-29-2022, 11:13 AM | #40 | |
1240
Rep 1,446
10-29-2022, 11:14 AM | #41 |
General
17315
Rep 18,737
10-29-2022, 11:25 AM | #42 | |
General
17315
Rep 18,737
We jacked it up, I tightened the lugs and were on our way. The day before the trip, Dr. D had new tires installed and an oil change. I guess the tech forgot to torque down 3 of the lugs at least. The other 2 weren't snug either. LOL.
10-29-2022, 12:36 PM | #43 | |
7334
Rep 7,299
10-29-2022, 01:27 PM | #44 |
1240
Rep 1,446
Here come the lube experts. Lol. Stating facts that are their opinion. Don't use lube at home either fellas. I'm sure they have reasons for that to. Now I must go/ grab my lube and well 💪🏼💪🏼🤪🤪
