10-07-2023, 06:14 PM | #1 |
Rep 1
Tire pressure on display
hi, anyone owns X1 2018? can I ask if you guys have this pressure with numbers indicated on the screen? mine are just green tires but no numbers for the pressure
10-07-2023, 11:57 PM | #2 | |
57
Rep 154
Drives: 2018, F48 28i
You will find more information in the post below. https://www.bimmerpost.com/forums/sh...php?p=24195645 |
wcs2229170.50 |
10-18-2023, 05:11 PM | #4 | |
4470
Rep 7,510
TPM/RDC is the direct system that has sensors mounted in each wheel that sends tire pressure & temperature info. FTM/RPA is the indirect system that uses wheel rotation to determine loss of air. This system will only show green or amber indication for correct air pressure or low air pressure.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
