BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
Mporium BMW
      09-28-2023, 07:16 PM   #727
mrvedit
48
Drives: 2013 M3
Hmmm, I also have persistent "car on lift" image when opening the drivers door. No codes from scanner. I assumed it was due to extensive VO code changes for my racing seats. (To disable seat airbags and adjustments.)
Didn't know the BC button would show a code. Also got the increased battery discharge warnings.
Having CarPlay working is more important than any minor inconveniences.
2017 M3 DTC * 2013 M3 Manual
2017 330i (Winter beater)
1981 Camaro Z28 - 427 LS3 - 10.94 @126mph
2006 Corvette (streetable track car)
1986 535i "24 Hours of Lemons" also streetable
PACarGuy686.50
      09-29-2023, 11:45 AM   #728
PACarGuy
PACarGuy's Avatar
687
Drives: 2012 E92 M3 DCT ZCP
Yeah, you can use the "Check Control" function to sometimes see the codes via the turn signal lever.
I presume it's from the Carplay unit, but I'm not 100% sure. I asked my indy to look at it earlier this year and they couldn't find any codes or trace it to anything else, though not sure how hard they really looked. Their opinion was that it had to do with the Carsara unit also.
2012 E92 M3 | ZCP | DCT | Space Grey Metallic | Black Novillo | BE/ARP | MPE V2 | AA green filter |BMW CF Rear Spoiler, RW Carbon Diffuser, CF Front Splitters | DTEC 160W Angel Eyes
      10-01-2023, 12:12 PM   #729
PACarGuy
PACarGuy's Avatar
687
Originally Posted by vilord View Post
Oh also, didn't see it in the thread.
To make it so that both the aux in for the armrest and the aux in on the back of the radio work at the same time, you want to code this:
RSE_3
rse_mid_rueko
Instead of this:
CDMM_AUX_HU
aktiv
CDMM_USB_AUDIO_SINGLE
nicht_aktiv
CDMM_USB_AUDIO_DOUBLE_0B
nicht_aktiv
(you'll want to change those three back to how they were, or default/factory code the CIC first)
(not my photo)
Is the RSE_3 parameter in the CIC module? Where do you find this one?
EDIT/UPDATE: Found it, and the CDMM parameters too, in the CIC module. Used NCS Expert to activate both AUX front and rear and now I have AUX audio working via the quad lock. Sounds so much better than AUX via 3.5mm plug. Thanks for this!
      01-07-2024, 04:49 PM   #730
mad_presley
Drives: E39 M5
Recently bought Carsara MMI, but I have some major issues with it.
First is I can not adjust it to use car`s bluetooth instead of AA. Option "Use the original Bluetooth phone" from factory mode menu is on, but it keeps using AA for phone calls. It is stupid, because if I listen to radio or USB and my phone rings, I have to jump to AUX to make conversation.
Second is steering buttons for next/previous song does not change Spotify songs it just behaves like up/down cursor.
It is non quad lock version, only jumper 5 is on as seller suggested. You can see FW version and options in service menu in attachment.
I`m on the way to trow this garbage out of my car, so any help will be appreciated!
P.S My factory mode code is 0301
      02-05-2024, 04:57 PM   #731
Rampiks
Drives: BMW 2010 325i E91 LCI 6MT
I can't seem to get the firmware update page on carsaras site to load. Does anyone have the newest firmware file? Hardware version is in the attached picture. I have the version from 2021 with quadlock audio
      03-07-2024, 09:15 PM   #732
S65V8M3E92
S65V8M3E92's Avatar
Drives: E92 M3
Thank you so much for this info!
      04-30-2024, 04:02 PM   #733
koolex
koolex's Avatar
Czech_Republic
Drives: 2010 N47 E90
This has worked for me. Thank you so much for saving me from the hurdle and I think sound is actually better than the one which is in the armrest.
RSE_3
rse_mid_rueko
Instead of this:
CDMM_AUX_HU
aktiv
nicht_aktiv
nicht_aktiv
(not my photo)
m3post
