10-05-2022, 05:05 PM | #23 | |
Professional Pisser-Offer
26
Rep 49
djmcbride1980112.50 s30z63.00 |
04-14-2023, 07:26 PM | #24 |
113
Rep 75
04-14-2023, 07:36 PM | #25 |
192
Rep 90
Drives: 2022 X3 M40i
04-14-2023, 07:51 PM | #26 |
114
Rep 89
Drives: G02 X4 M40i - Dark Graphite
I'll post up in a few weeks. Waiting for KW3 coilovers. But had similar questions on this thread. I'll see how KW3s go see about adding the under braces.
04-19-2023, 09:22 PM | #27 |
713
Rep 564
RealOEM is your friend.... Front sway bar: 31308093412 Source: https://www.realoem.com/bmw/enUS/sho...diagId=31_1666 Rear Sway Bar: 33508746456 Source: https://www.realoem.com/bmw/enUS/sho...diagId=33_2461 Also...the rear swat bar for the X3M is a very different shape than the rear sway bar for the M40i. It also mounts on the end links to a different location on the suspension. I would be surprised if it fit. The front bar looks to have a very similar shape and might swap over.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
5LEEPR_G01487.00 EDWYER1676.00 |
04-19-2023, 09:37 PM | #28 |
713
Rep 564
I replaced the rear sway bar bushings on my M40i. Why? Well I looked at the bushings when the car was flat (see picture 1) and then I looked at them when I simulated a little body lean by jacking one side of the car up slightly (see second picture).
Notice how soft the bushings are, and how much the sway bar moves in the bushing. I made some measurements of the deflection and they showed that if you could reduce the deflection to 0, the effective stiffness of the bar would increase about 15%. Poly bushings it is as an experiment. So I measured the sway bar - it is a 22mm sway bar. I ordered a new set of universal links from Whiteline - P/Ns w21301 and w21047g. I also got some M8 fender washers. See third picture for a comparison of the old and new. Used a E14 wrench to work in the tight space to remove the old bushings. Note - this is a really tight job without dropping the subframe, but totally doable. You'll learn some tricks about reach around the sub frame with two hands etc to get it done. I did bend the wrench a bit to help fit. Picture 4 shows the finished product. You will notice that I put a small piece of sheet metal between the bushing and the sub frame. This was to take up the space caused by the nut insert in the sub frame, and ensure no play. On drive, you can definitely feel the back end is more responsive, and the car is more balanced on hard corner (rather than being slightly biased towards understeer). It's not a night and day difference, but its definitely noticeable and was worth it to me. Plan is to do the same to the front, and then alter the rear sway bar to have a shorter lever arm to restore the nice balance. Let's see how far I get...this is all experimentation for the sake of experiments.
Burr0013334.00 5LEEPR_G01487.00 KowalskiBMW1331.50 earlgsxbusa114.00 Alias1431796.50 dmicah781.00 X3rd Time Is a Charm2839.50 |
04-19-2023, 10:11 PM | #29 |
2183
Rep 1,357
Join your local SCCA sanctioned Autocross and learn from people that have been doing it for years. There is more to it than one would believe, watch your course times improve and find out from seasoned drivers what mods will help improve lap times. Word of caution: this is highly addictive and more fun than just about anything you can do with a car.
This past weekend I witnessed lightly tuned Miatas (with a great driver) destroy new corvettes and a 22 Porsche 911 GT3 by 3 to 4 seconds, it was brilliant. |
earlgsxbusa114.00 |
04-21-2023, 07:14 PM | #30 |
713
Rep 564
Got all the parts to do a front sway bar bushings change out. Should be quick and easy because the front bushings are way easier to access.
Wrong! The front bushings are bonded to the sway bar. Did some experimentation to figure out the stiffness of the bushing (how much torque they apply) vs the stiffness of the bar. Makes it a tough choice because the bonded nature means they also make the sway bar act like a torsion arm spring...but seems to be relatively low force as compared to the springs/bar. Anyone have any experience with bonded sway bar bushings?
04-21-2023, 08:19 PM | #31 | |
Internet Weasel
781
Rep 767
Drives: 2023 X3 M40i
In any case, maybe this is the universe telling you to do both the bushings and switch to the X3M bars? |
04-21-2023, 08:35 PM | #32 | |
713
Rep 564
Going X3M bars is a good idea, but I really don't want to drop the subframe...I don't think there is any other way to get the bar out. Anyone who knows please chime in.
04-21-2023, 08:47 PM | #33 | |
Internet Weasel
781
Rep 767
earlgsxbusa114.00 |
05-04-2023, 04:01 PM | #34 |
Rep 6
Suspension of 2023 X3 m40i
In Sport mode setting, the SAV feels very bouncy on smooth highways at 70 mph or more with body-roll when changing lanes at this high speed. Can exchanging out the X3 m40i OEM front and rear anti-sway bars for the X3M OEM version reduce the bouncy and body-roll ???
Also, is the exchange a simple "plug & play" transplant or not? |
05-04-2023, 04:48 PM | #35 | |
Captain (Retired)
4033
Rep 1,771
05-04-2023, 05:58 PM | #36 | |
6659
Rep 15,858
earlgsxbusa114.00 |
06-13-2023, 02:56 PM | #37 |
713
Rep 564
TLDR:
Code your VDC module fields AusgabeSollstromVA_Zug_VDC2, AusgabeSollstromVA_Druck_VDC2, AusgabeSollstromHA_Zug_VDC2, AusgabeSollstromHA_Druck_VDC2 to a value of 1100 (from 900), or even higher if you want, to stiffen the sport setting of your adaptive suspension. Long Version: After Dinan released the springs for our car, I was curious if they would be working on a Shockwave software upgrade. This upgrade essentially tunes the adaptive damping algorithm. Turns out they aren't, so naturally I tried to figure out what I could do myself. I did some logging on the adaptive damper valve in our car, and found that it seemed that higher currents led to a stiffer shock. Look at the "comfort" mode and "sport mode 900ma target" plots below. That is the same road driven with the same aggressiveness. It's clear visually as well as from the average current that sport mode has more current. I did some research, and found that historically the BMW EDC system was the opposite - no current was stiff and more current was softer. Hmmm...so I found a press release saying that Tenneco is the supplier for BMW X3: https://www.businesswire.com/news/ho...hicle-Platform It is their CVSAe platform, so I scoured around for an explanation on how they work. Found this video: Check out the 2 minute mark - 1.6amps for sports driving and 0.29 amps for comfort. Brilliant - exactly what I was seeing in the data. So I looked at the VDC module, and it turns out you can increase the current target (but it is still capped at 1.6 amps) for the EDC system with the following coding parameters: AusgabeSollstromVA_VDC1 AusgabeSollstromVA_Zug_VDC2 AusgabeSollstromVA_Druck_VDC2 AusgabeSollstromHA_VDC1 AusgabeSollstromHA_Zug_VDC2 AusgabeSollstromHA_Druck_VDC2 All of the 'VDC1' parameters are set at 400, whereas the VDC2 are set at 900. So VDC2 = Sport and VDC1 = Comfort. I changed all the VDC2 values to 1100. Then I went for a drive, and you can see the last plot with the 1100ma target current. Much more dampening applied from the data, and felt firmer as well. Felt flatter in corners, and like it had less understeer. I used Bimmergeeks ProTool for all the logging, investigation and coding: https://www.bimmergeeks.net/protool I found a specific engineering reference in German wrt Druck and Zug, seems to be compression/rebound, respectively. Which might make sense: https://www.proz.com/kudoz/german-to...zug-druck.html VA seems to be front, where HA seems to be rear: https://www.air-suspension-parts.de/...-1-F20-M-140-i Anyone else want to try and comment on what it does for them?
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 Last edited by abbike18; 06-14-2023 at 04:05 PM.. |
10
06-13-2023, 03:16 PM | #38 | |
266
Rep 294
I dont have time today but I will post back later this week |
06-13-2023, 04:21 PM | #40 |
713
Rep 564
I'm not sure Bimmercode can do this - I'm pretty sure they don't give access to the VDC module.
You might need a more advanced, feature rich tool like Bimmergeeks ProTool for this type of thing.
Rottweiler4033.00 |
07-05-2023, 03:33 PM | #41 | |
266
Rep 294
Bimmercode is a no go
I have the "chassis function limited message" popping up again so I should probably address that before tweaking things. If I ever get around to this I will let ya's know how it works out. Thanks for the info! |
abbike18713.00 |
07-05-2023, 05:20 PM | #42 | |
713
Rep 564
I found that with a hybrid turbo in comfort if you nailed it to pass someone on the highway the suspension was just a tad soft and the car would really get unsettled from the quick torque hit. Upping the comfort setting helped with that a bit while maintaining the soft nature.
07-05-2023, 06:02 PM | #43 |
1190
Rep 994
Drives: 2023 X4 M40i (G02)
Have you considered spending those budgets to buy the car that you fit your style and taste better instead?
I used to spend $$$$ on mods to turn my X3 as sporty as it can be, but then eventually I traded in and get the Supra as my fun car. Just my experience, and look forward to seeing you expand all the potential of this beast!
2004 Toyota Vios | 2004 BMW X3 | 2007 Chrysler Town and Country | 2007 Ford Escape | 2008 Honda CRV | 2017 Nissan Versa Note | 2017 Toyota RAV4 | 2017 Toyota Yaris iA | 2019 Porsche 911 | 2023 BMW X4 M40i
07-05-2023, 09:36 PM | #44 | |
713
Rep 564
Good question, and yes I thought about it. It really comes down to this...we needed a family car and I wanted a car that was fun to drive/satisfy my urge to have fun driving. That leaves two options given a fixed total budget of about 50k, give or take: 1.) Buy a boring crossover/minivan and an older sedan 2.) Get only a X3 M40i We chose #2 because when we go on family trips (often in the mountains) that means we have a car that is fun to drive. If you look at what you can get for option 1 at $25k each, the family car is really not very inspiring. When it came to X3 M40i vs X3M, it came down to gas mileage and the fact that my wife really hates busy rides, so the comfort adaptive setting of the M40i was much better. Not the right choice for everyone, but it was right for us. I've also learned that no matter what car I get, I will always mod it. I just like learning about the car I have and experimenting with it. At this point the mods are for the enjoyment of it, not to make the car in to some goal.
