02-11-2018, 03:17 PM | #486 |
2374
Rep 8,364
02-13-2018, 11:41 AM | #487 |
19
Rep 33
02-13-2018, 12:43 PM | #488 |
19
Rep 33
I'm also looking to install LED head lights for low and high beams, my '18 X1 just has lame halogen bulbs in it now. I don't see anything in the cheat sheets or any direct mention of settings that need to be change via coding for the headlights, just fog lights and turn signals? Is that a fair assumption? If I just swap out the bulbs would there be any other issues to be worried about (other than fit in the housing)?
02-14-2018, 03:19 AM | #489 |
Rep 3
Junior 88 i did a 6 changes with Bimmercode and that already was more then enough to get my 29€ back so even with 2 options you have youre money back m8
02-24-2018, 02:09 AM | #492 | |
142
Rep 491
Panicked (wife's car lol), I used "Detect CAFD for SWE" to re-code the module. Everything seems back to normal, but now I can't seem to FDL code the module anymore. Any ideas what went wrong? I followed the following instructions to VO code: http://bmw-f-coding.blogspot.sg/2017/12/how-to-enable-f30-enhanced-bluetooth.html?m=1 |
02-24-2018, 11:25 AM | #493 | |
2374
Rep 8,364
I would need more info to know what is wrong. |
02-24-2018, 05:54 PM | #494 | |
142
Rep 491
1/ VCM. Load the edited FA file. 2/ Calculate FP. 3/ Click VCM master tab and write FA FP 4/ Read FA FP to check FA has been saved to car. Thanks Last edited by Douggie; 02-24-2018 at 06:08 PM.. |
02-24-2018, 06:48 PM | #495 |
2374
Rep 8,364
02-24-2018, 08:25 PM | #496 |
142
Rep 491
02-24-2018, 08:33 PM | #497 |
2374
Rep 8,364
02-24-2018, 08:44 PM | #498 |
142
Rep 491
I'm not sure. But it seems like it is a straightforward thing. Just add the 6NS to FA and code the HU_ENTRYNAV Module. Can't figure out what went wrong. I've FDL coded quite a few features without much hiccups.
02-24-2018, 10:54 PM | #499 |
2374
Rep 8,364
Not sure. Without screenshots or error codes, I cannot be sure what occurred. Did you lose connection during coding?
02-24-2018, 11:43 PM | #500 | |
142
Rep 491
Edit: I looked through the logs and saw that my car actually has HU_ENTRYNAV2. Maybe can't use 6NS? Last edited by Douggie; 02-25-2018 at 07:36 AM.. |
03-16-2018, 09:29 PM | #502 | |
2374
Rep 8,364
03-18-2018, 12:18 PM | #503 |
Rep 2
Does anybody know how to deactivate the popup on the Navi screen that tells you what mode you are in when you change between eco, comfort and sport?
Thanks for all the great info. on this forum, coding is awesome! |
03-18-2018, 10:18 PM | #504 |
2374
Rep 8,364
It should be an option in IDrive settings to uncheck. Check around the display settings.
