BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Can't close hood
      06-15-2021, 08:39 PM   #1
Durag
Drives: Bmw x1
Can't close hood
Can't close my hood on my x1 I released it twice to open and I let it drop and and pushed down both sides it still won't close.
      06-16-2021, 07:31 AM   #2
Bill_P
95
Drives: X1 xDrive 20i xLine MW
You need to drop it from about 50cm and even put a little force behind it. It seems way overkill, but that is the way to close it. You do not need to push down at the sides - if it has not closed properly release it again and drop it from slightly higher.
It seems ridiculous to slam it from a height like this - but that is how it works.
ttimbo281.50
      06-17-2021, 09:40 AM   #3
BrianJ
25
Drives: BMW F48 X1 xDrive20i Sport B48
Ours was a pain to close on one side when new. There is a very simple one nut adjuster on the "U" shaped component on the underside of the hood (or bonnet for UK!). If you adjust the nut so that the "U" gets a bit longer, it makes the hood close much more easily. Just do it gradually until you get a secure close on both sides. I find the hood closes best with a sort of guided shove with both hands, each hand towards the front of the hood aligned with each of the clamps.
