Bimmerpost
4 Series
Technical Topics Wheels and Tires Wheel Spacers
      02-23-2024, 03:56 PM   #177
relentlessone
relentlessone's Avatar
289
Drives: 2024 BMW M340i xDrive
2024 M340i xDrive
792M 19x8" square wheels
H&R Springs 28662-2
13mm spacers front and rear
My opinion is that 15mm is better suited for the front for flush fitment. The rears are perfectly flush with 13mm.
Instagram: @lakeshorebimmers
      03-16-2024, 08:10 AM   #178
sim_330e
sim_330e's Avatar
Australia
88
Drives: BMW 330e Msport
Originally Posted by peelerec View Post
Forgot to share when I had spacers installed 3 weeks ago. Macht Schnell 15mm rear and 12mm in the front.
Is your car on stock springs or has lowered suspension?
      03-16-2024, 08:15 AM   #179
sim_330e
sim_330e's Avatar
Australia
88
Originally Posted by crpediem_2 View Post
10mm front and 12mm rear -alpine white.
Is your car on stock height and suspension?
      03-16-2024, 08:18 AM   #180
sim_330e
sim_330e's Avatar
Australia
88
Looking to add wheel spacers to my wheels on my 330e
Any suggestions on the mm? Leaning towards 12.5mm
      03-16-2024, 09:45 AM   #181
peelerec
peelerec's Avatar
1054
Drives: 2022 M340i Mineral Grey
2022 BMW M340i  [10.00]
At that time, lowered on dinan springs.
Present: 2022 M340i Mineral Grey
Past: 2019 330i, 2012 Evo X GSR
      03-16-2024, 09:46 AM   #182
peelerec
peelerec's Avatar
1054
EAS & IND recommends 12mm front, 15mm rear, however, it really is subjective to your preferred aesthetic.
      03-18-2024, 12:04 AM   #183
D0NVT
Drives: 330d
Originally Posted by squareforce View Post
Turner Motorsport 5mm spacer on the fronts. No spacer for the rears with powder coated satin bronze oem Supra wheels.
Running 255/35/19 fronts and 275/35/19 rears. Supra fitment to make for easier ordering at Discount tires.
Hey man, really good looking setup!
Please let me know did you use extended bolts?
I’m planning to do the same on black car, but a little bit confused about front adaptive struts and wheel clearance.
      03-31-2024, 03:00 PM   #184
alpine_g20
Installed Dinan 15mm spacers all around today. The rears are perfect at 15mmm - looks significantly more aggressive. If I could do it over again I'd probably go with 12mm in the front as they are just a touch wider than I'd like.
      05-09-2024, 07:28 AM   #185
Randy Johnson
M340i
Randy Johnson's Avatar
403
Drives: BMW M340i
2021 BMW M340i  [10.00]
Here is my 2021 M340i with 10mm front and 13mm rear. Stock springs and square 225 tires.
      05-09-2024, 09:35 AM   #186
MitchDog
MitchDog's Avatar
53
Drives: 25' BMW X5 40i, 23' BMW M340i
I recently purchased a MY23 M340i. Love the car!! I will say as many of you have, man...they sure tucked the wheels in there! I've considered spacers in the past on other vehicles, but have been worried about performance/safety, etc. It seems that they work just fine, making sure a good brand, fit, etc.
Here's my setup. 225/40 (8.9") front, 255/35 (10") back. Not wanting anything crazy, but would like a more aggressive stance. Suggestions on brand, size, who to have install.
Thanks for your input!
      05-09-2024, 10:07 AM   #187
Randy Johnson
M340i
403
Drives: BMW M340i
Any of the name brands should work. I was going to go with burger motorsports but found a great deal on CTS turbo so I bought them. Install is simple. Just remove each wheel to put them on. A tire shop may do it if you don't want to.
https://www.ctsturbo.com/product/cts...5x112-cb-66-5/
      05-09-2024, 10:50 AM   #188
MitchDog
MitchDog's Avatar
53
Thanks for the link! thought I had read awhile back that there was a certain amount of torque that needed to be applied when first installed...and then a week or so later, add more torque? Maybe different products require different techniques? I also heard that tire shops might not install due to liability issues.
What about sizing? 10 front 12 rear? Some have mentioned larger in front. Not sure if the staggered setup makes a difference.
      05-10-2024, 03:36 PM   #189
slm266
slm266's Avatar
32
Drives: 2020 M340 xdrive
I think the torque spec is ~105
Some corporate tire shops won’t install wheels with spacers.
Spacer size depends what wheel width you have. Scroll thru this thread and find someone with same wheels or similar specs (width and offset)
g20
