BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      04-24-2024, 09:30 PM   #1805
BGM3
Drives: E92 M3
Originally Posted by drwankel View Post
There's a simpler method to allow you to root cause this, assuming the car was working correctly before hand.
Unplug the fiber optic connection on the mr12volt unit while the car is on. Do you see red light coming out of the cable? You should. If you don't, its not the unit. Assuming you don't, work your way backwards from the spliter. Is there light coming from fiber optic connection on the vehicle harness? There should be. Remember, MOST is a loop. Each device sends the signal to the next device in the loop. When the loop is broken, you just need to walk back to where you lose signal.
For the coding question, I think where this is possibly confusing some people is the previous mr12 volt boxes connected differently, by tapping into canbus at the idrive controller. People are able to code CIC with these versions installed.
The new oem microphone version uses a quadlock adapter with the cic unit quadlock plug. Something about connecting this way appears to break the ability to code the CIC unit.
Thank you for clarifying the coding situation, and for the details on how to root cause the open MOST loop. I did the coding, then re-connected the Mr12Volt system and still had the same issue. Unplugging the FO connection at the unit I did not see any light. Even though I thought the connections were correct I think I did have the FO splitter installed wrong. I noticed that the vehicle harness FO connection does not output light when the system is on, but the CIC unit does. I think that I installed the original FO connection into the quad-lock adapter harness and the FO splitter into the CIC unit.
I appreciate your help here,
drwankel1073.50
      04-25-2024, 08:50 AM   #1806
tdott
3956
Drives: M3
Remove the Mr12Volt harnesses and plug the stock harness back into the CIC and see if your CIC is working and has sound.
Keep trying, sometimes you think its right but it's not, you just have to find it.
      04-25-2024, 06:02 PM   #1807
marsmaher
Drives: 130i
Hello
I have bought p600 for my e87 130i with CCC
(rotating screen) with
S609 Navigation System Professional
S644 Preparation F Mobile Phone W Bluetooth
S672 CD Changer For 6 CDs
Problem: the p600 gets power and connects to my phone, but the “CD” is greyed out on my drive screen.
i have tried everything,
- Connecting directly to factory fitted CDC at trunk of car,
-Connecting use Y loop behind my CCC in the dash
and done the loop on the CDC
- Random Fiber optic cable under glovebox being looped.
- checked all FO connects and correct direction
- seeing red light outputting everywhere correctly
- cds work in drive and CDC when reverting and shows in idrive as normal
other information , i have a MULF2 fitted at boot for factory phone bluetooth. I have no idea what’s working and Mr12 Volt doesn’t reply to me anymore
      04-25-2024, 10:38 PM   #1808
BGM3
Drives: E92 M3
After messing around with the connections, I was able to get it to work. I think that I had the FO splitter routed incorrectly. Finished up the install yesterday and its working great.
derbo3612.50
      04-26-2024, 12:29 PM   #1809
greyspoke
greyspoke's Avatar
58
Drives: 2010 E92 M3 DCT - Space Grey
2010 BMW M3  [10.00]
drwankel So I just installed the mr12volt CIC in my car and did not catch the post about coding needs to be done prior to installing. I can't believe this is not included in the instructions from mr12volt. Using Bimmercode, I can confirm that I can no longer see the headunit module in Bimmercode. Do you know exactly what I must uninstall to do the coding? Is it just the quadlock or everything (quad lock, LVDS, MOST cable)?
      04-26-2024, 12:32 PM   #1810
drwankel
drwankel's Avatar
1074
Drives: 2012 E92 M3 ZCP, 2021 M340i
I dont own the new unit, but I would suspect that you would need to remove the quadlock adapter, put the most vehicle harness most connector back in the factory quadlock and reconnect to the CIC unit.
I dont think youd need to touch the LVDS stuff.
      04-26-2024, 12:34 PM   #1811
greyspoke
greyspoke's Avatar
58
2010 BMW M3  [10.00]
Thanks for the quick reply. I'll be working on this tonight or tomorrow and post an update for everyone once I'm finished.
      04-27-2024, 10:08 AM   #1812
greyspoke
greyspoke's Avatar
58
2010 BMW M3  [10.00]
Just to follow up as promised, got in the car today and mr12volt was recognized. No coding ended up being needed. I do not have a cd changer and the extra MOST loop cable was not used. I estimate that I started the car about 5 times since I did the hardware install before the car automatically recognized my “cd changer” aka the mr12volt.
      05-01-2024, 03:00 PM   #1813
03BeastCharmer
03BeastCharmer's Avatar
260
Drives: '13 M3
Originally Posted by gh0stE92M3 View Post
Has there been an updated rear camera anyone recommends? Or is it still the one from before? I have the one that’s been posted before and haven’t installed it yet but I think I’m finally going to do it but wanted to see if there was a newer one that anyone recommends. I know people have claimed the camera low light vision sucks at night or during low light. So seeing if anyone is using one better?
Ditto this question. I have an old camera from my AlekShop box and trying to figure out if I can reuse, or need to get new camera (and rerun the new wires )
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      05-06-2024, 10:40 AM   #1814
bsant
Drives: e92 335i
Mr12volt Greenyi backup camera issue
Is anyone experiencing video signal issues using the recommended Greenyi backup camera? My video picture is grainy, black and white, and doubled (see picture). I have a CIC 6MT with a trigger wire connecting the mr12volt to the reverse lights. Power to the camera is supplied from mr12volt along the power line integrated within the included video cable. As recommended here, the camera is left ungrounded.
TIA
      05-06-2024, 10:12 PM   #1815
GORDON.M3
GORDON.M3's Avatar
1436
Drives: E92 M3 • F25 X3 M-Sport
TIA
you need to install a 12v rectifier to stabilize the power source to the rear camera.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
Thumbie103.00
      05-12-2024, 08:20 AM   #1816
S65Hunter
S65Hunter's Avatar
No_Country
1190
Drives: 2009 E92 M3
  [0.00]
I started having this issue a few days ago. When I start my car, it just goes to the cd changer screen. I can't get into the Mr.12volt menu. I got to the actual module and pressed the little reset button, even tried unplugging it. Still just get this screen. Any suggestions?
EDIT: I disconnected my car's battery for a few min. Once I reconnected it and powered everything on, the Mr 12volt fired right up. This has happened to me a few times recently, hopefully it's not a forever thing.
Double Edit/update: This problem is still happening. It basically just works when it wants to. I pulled my glove box and checked the unit and it's pretty warm, I wonder if it's getting too hot? It dosent seem like there's a fan inside to keep it cool.
2008 328i e93- 3SIM, StageFP tune, magna flow #12148 muffler + vibrant resonator, BMS filters, Bilstein B8s, H&R sport springs, ECS sway bars, whiteline rear subframe bushings, rouge engineering trans mounts, custco front strut bar, M3 front lower control arms. Cosmis R1 18x8.5 245/40 front 18x9.5 255/35 rear.
      05-12-2024, 06:16 PM   #1817
BalanBro
Drives: 2009 E93 335I
Originally Posted by mare92 View Post
EDIT: IT WORKS REALLY GOOD! I connected it to the wrong port (aux on mr12volt, not on quadlock) at first, so that is why the mic was terrible:
Installed it, microphone quality over OEM system is same as before, but if I switch to CarPlay mode which is connected via splitter to AUX port on Mr12Volt unit, the person on the other side can hardly understand me, so it seems it is not any better than on your old systems… any suggestions?
This is the System info, guess it is the latest…
Software: Box-260 V3.14.00.1010
Hardware: 02-0010-06-00-00-05-00-00
System:
Mr12volt 2022-06-18
BlueTooth : BT825B,V5.6.6 MCU:
bmwCIC_20230206B
Also, what is the proper way to ground and power chinese backup camera using Mr12Volt? I installed the included yellow video cable, which have 2 short wires on each side, but don’t know where to connect it or if I need to wire another power wire through entire car?
Little help for other people wanting to do the install:
a) Coding is possible using Protool from Bimmergeeks. You need to select Entertainment, Radio, Code, Edit, Advanced menu, use the search function to look for “CD Changer”. You change it to CD Changer with MP3, then click code.
b) For E93, microphone location is indeed behind steering wheel…
- skip to 20:40 and watch how to dissasemble it. Then you can use the splitter and run the cable to quadlock on Mr12Volt Unit
c) It took me and my friend 2 hours to do it and it was first time to do anything like that, using only
(it is too quick, set it to 0,25 speed in Youtube) and video that I linked under b) for E93 mic.
Just wanted to say thank you for posting all this info. I used your guidance to complete the installation on my E93 335i. The install went without a hitch. I tucked the quadlock on the lower right side, below and to the right of the cage. This allowed me to get the radio back in easily on my first try.
I also was able to code the CD changer successfully with ProTools using your suggestion. While I was there, I also installed the GreenYi 720p AHD rear view camera, and the picture is great. I did need to extend the video and power cables about 2 feet though. The E93 requires a longer cable to follow the routing for the convertible mechanism, and the GreenYi camera's cable was just a touch too short.
Wireless Android Auto worked perfectly on the first try simply by pairing Bluetooth. The car did all the rest to get AA running. So far the sound quality is much better than the AUX cable I had used before.
Finally, I installed the Inductiv wireless charger in place of the factory cigarette lighter tray, and it really completes the package to modernize the interior. It supports wireless fast charging as well, so no worries about losing power while running AA.
CamasM3e933224.00
      05-12-2024, 09:18 PM   #1818
anselmw
78
Drives: 2001 M Coupe
Originally Posted by Matt@Evolve View Post
1 - https://www.evolveautomotive.co.uk/collections/mr12volt
2 - GreenYi from Aliexpress
3 - You will need CD Changer to be coded in if you do not have one.
Which GreenYi, for E90 M3, seems, like there are multiple versions?
2011 M3 Sedan
2001 M Coupe
2020 Macan Turbo
2018 GT3
      05-13-2024, 01:01 PM   #1819
BalanBro
Make sure it's for an E9X chassis, and get the model that is 720P AHD. Do not get the 1080P AHD model.
Appreciate 2
Thumbie103.00
anselmw77.50
      05-13-2024, 01:21 PM   #1820
BalanBro
TIA
I recall someone else reporting this issue on the Mr12Volt Facebook group. If I remember right, that person had purchased the 1080P AHD camera, while the Mr12Volt only supports up to 720P AHD. If that is what you have, there are two options:
a) Replace the camera with 720P AHD version
b) Cut the white wire on your 1080P camera. That should downgrade the signal from 1080p AHD to 720P CVBS. The CVBS signal should work fine with the Mr12Volt, but the picture quality will not be as good as the dedicated 720P AHD camera.
If you do have the right 720P camera and it is doing this, I would try troubleshooting by hooking up the ground to a proper grounding point on the chassis and seeing if that fixes the picture.
      05-14-2024, 03:21 PM   #1821
03BeastCharmer
260
Drives: '13 M3
I noticed in your picture that your sound level is turned off. I had a similar situation of Mr12Volt not starting and thinking it was broken after turning the volume off when a song autoplayed and I didn't want to deal with finding which application was playing it to pause it. Once I turned the volume back on, the CarPlay screen came back. This may be your issue since it came back after disconnecting the battery which may have reset the volume knob to low. Hopefully that solves your issues.
S65Hunter1190.00
      05-15-2024, 03:39 AM   #1822
DavesZed
DavesZed's Avatar
156
Drives: BMW E89 23i, 2011
Absolutely, Volume on Mute does not allow the Mr12volt system to work
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)!
My Z4 E89 YouTube channel...
https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q
Thumbie103.00
      05-17-2024, 07:00 AM   #1823
anselmw
78
TIA
I am about to wire mine up but that does not sound like it is wired correctly. Thought the trigger wire goes to the trigger wire output of the mr 12volt and the other end goes to the reverse light.
The camera power goes to either the battery with maybe a relay. Otherwise you run a longer wire and you take the 12v from the mr 12volt power output. I am going to try this setup as I already have the power wire from my previous rear cam so I will use that for power and then pull the rca cable with trigger wire for that.
I will see if this works...
2011 M3 Sedan
2001 M Coupe
2020 Macan Turbo
2018 GT3
      05-17-2024, 07:01 AM   #1824
anselmw
78
Thanks, I purchased the 720 AHD one, will try without cutting the loop, then cutting it after. I wish they would integrate another power line into the cable, it would simplify the install as then you have access to the trigger wire and 12v power from the mr 12volt.
2011 M3 Sedan
2001 M Coupe
2020 Macan Turbo
2018 GT3
      05-17-2024, 08:34 AM   #1825
BalanBro
I don't think you would need both wires. Are you auto or manual?
If auto, then a trigger is not required as the mr12volt should be triggered through canbus. You'd only need to run the power to the camera from the mr12volt using the included power wire.
If manual, you would need a trigger, but all you should have to do is run 12V from your reverse light to your camera's power, as well as the power on the video cable for your camera. This wire would then be hooked up to the rear camera trigger input on the Mr12Volt so the unit knows when you are in reverse. You should not need to use the rear camera power output on the Mr12volt, as the camera should be powered directly by the wire coming from the reverse lights.
My E93 is an auto, so I didn't have to do the latter, but I did this on a different vehicle I used to own that was a manual transmission.
      05-17-2024, 08:42 AM   #1826
anselmw
78
thanks, mine is automatic, so if it is just power I will try that! Makes install even more simple, thanks
2011 M3 Sedan
2001 M Coupe
2020 Macan Turbo
2018 GT3
m3post
