03-24-2022, 12:54 PM | #155 |
3956
Rep 3,997
not without enough gas.
NYG11051.50 Killed by Death13204.50 |
03-24-2022, 12:57 PM | #156 |
General
64709
Rep 24,949
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
03-24-2022, 01:04 PM | #157 |
11052
Rep 3,792
03-24-2022, 01:23 PM | #158 |
General
64709
Rep 24,949
03-24-2022, 01:31 PM | #159 |
General
64709
Rep 24,949
The fuel issue wasn't the fuel pump . They got a 'Vacuum in the fuel supply ...
The FIA said : There was enough fuel in the fuel tank . Red Bull confirmed : It's fixed ...
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. Last edited by ///M Power-Belgium; 03-24-2022 at 01:44 PM.. |
03-24-2022, 01:42 PM | #160 | |
7367
Rep 7,539
1) It would be gambling on 2 different fields, you would lose both down force from raising the car and top speed. That puts a huge unknown on if there is enough pace to keep up with the cars behind. 2) Porposing is a function of aero load (down force) which increases while speed increases. However porposing does not occur strictly at top speeds, it happens much earlier than that. If you look at on boards it happens maybe half way through a straight and by then the cars are probably 30ish km/hr below their top speed, and the mercs were only 10-15 km/hr slower than the fastest car. So it makes no sense to try and cut back on top speed by decreasing the power, because even now the cars are going faster than when porposing started. To stop porposing by speed reduction you would have to drop alot of speed to the point where the cars are uncompetitive - especially on a high power track. They also have to add enough height to deal with the extra 100kg of fuel they will run at the start of the race too, because the weight of the car acts in parallel with the down force to increase porposing. So this likely means they ran enough height to deal with aero load + weight of the car + the larger wings which also increases load. So it doesn't make sense they would try to sacrifice performance on both ends by also decreasing power output to such a large extent. So my take is they were probably running the pu on normal power output, and if they were cutting back on power it was not by much because solving porpoising by reducing power output is impossible unless you want to drop to low 200 kph top speeds.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
inTgr8r2434.50 |
03-24-2022, 01:47 PM | #161 | |
7367
Rep 7,539
Leclerc baited max by braking earlier than max enticing him to over take on the first DRS zone which allowed leclerc to take the second drs zone to retake 1st from max, and this happened more than once showing max didn't learn from his mistakes. Leclerc also demonstrated immensely high race iq on the safety car restart when max pulled up right along side of him and leclerc initiated the restart at that exact moment because max was so off the racing line right before the corner it prevented him from getting on the power right away. This allowed leclerc to make a clean get away and compromised max so much sainz was right on him from the moment max could get on the power. If anything max is still to agressive and emotional from not being able to push hard for the undercut, and that costed him in these key areas. If he thought more clearly he wouldn't have overtaken charles on the first drs zone, and he wouldn't have lined up right next to leclerc compromising his racing line for the restart.
03-24-2022, 02:07 PM | #162 |
General
61833
Rep 19,969
03-24-2022, 02:08 PM | #163 |
General
61833
Rep 19,969
NYG11051.50 ///M Power-Belgium64708.50 |
03-24-2022, 02:17 PM | #164 |
General
61833
Rep 19,969
03-24-2022, 02:23 PM | #165 | |
11052
Rep 3,792
03-24-2022, 02:38 PM | #166 | |
3956
Rep 3,997
Charles at the moment gives off a more skillful, intelligent and class act vibe. Max still sounds like a spoiled brat.
03-24-2022, 02:38 PM | #167 |
13205
Rep 3,671
03-24-2022, 02:50 PM | #168 |
1715
Rep 606
03-24-2022, 03:06 PM | #170 | |
11052
Rep 3,792
Did we forget Charles qualifying last season? Was he skillful and intelligent then too? They all screw up from time to time. It sounds like your anus is still sore from Max being the champion and I'm saying that as someone who is a McLaren fan above all else, even if I like both Max and Charles a lot. |
03-24-2022, 03:09 PM | #171 |
General
64709
Rep 24,949
03-24-2022, 03:14 PM | #172 |
General
64709
Rep 24,949
The 2022 'Jet-Mode PU will make all the others bleed !
03-24-2022, 03:20 PM | #173 |
General
64709
Rep 24,949
Ain't no good ... Yeddah is a rat-trap-track !
#CarGraveyard
03-24-2022, 03:51 PM | #174 |
3648
Rep 3,245
There are a couple good side by side comparisons of Leclerc vs Ham Q3 laps in Bahrain. Merc is good in slow and mid speed corners. I suspect with the high speed nature of Saudi GP, the gap to Ferrari could be worse.
03-24-2022, 04:00 PM | #176 |
General
64709
Rep 24,949
More words than MAX and HAM have said to each other in 5 seasons...
