04-03-2014, 08:44 PM | #133 |
Rep 89
can some one pm some numbers for the best bang for you buck kit i am in the hunt and looking for best set up out 2014 f30 msport shipped to 02910 plzzzzzzzzzz
05-30-2014, 03:27 PM | #134 |
17
Rep 221
My V1s have the hex hole, I love the suspension but it makes a bit of noise and I am not the only one who has this problem.
06-26-2014, 02:42 PM | #135 | |
Rep 64
09-20-2014, 03:10 PM | #136 |
3492
Rep 9,708
Just chipping in to share my option.
I fitted Bilstein PSS10 B16 KOMFORT to my F30 (48-229012). These have a longer spring than the normal B16 PSS10. Lowering is in the -10-30mm range, not the -30-50mm range for the normal version. I didn't want to go that low. I fitted them because I don't rate the standard M Sport suspension ( I've had both Adaptive and passive, both suck!!!). Verdict, wow what a transformation, the car now rides like an M3/M4, no jokes it really does stick to the road. It is also far less crashy when going over potholes, etc. An amazing transformation |
10-14-2014, 03:37 AM | #137 |
Rep 45
mine is KW V2 installed on my 328i.
after a while i notice the bump stop was destroyed. had my car jacked one time at the local tyre shop for tyre swap and noticed the bump stop is like shredded foam and the dust cover wasnt in tact anymore. also the rear perch or height adjuster need longer threads, at the highest ride the clearance between fender and wheel is only one finger gap. hate to drive the in laws in my car cos fender scrub and malaysian roads has lots of potholes. emailed KW and asked if they have a longer perch than the one that came in the box, apparently they do but they dont post it under spare parts in their website had to order them and they came with coil spring as a set. in all, i guess KW makes good suspension but really should consider on the options of height, i didnt look at this as a problem in the beginning, but when you are running on 19's with 30 series tyres, hits you like a bitch!
02-10-2015, 09:41 AM | #138 | |
28
Rep 114
02-13-2015, 01:35 AM | #139 |
472
Rep 577
I just installed the BC Racing Coilovers on my 328 F30, and I'm seriously impressed. Great ride, great adjustability, great look (both car and suspension). All in all I'm pretty stoked.
I posted a review on the BC racing coilover discussion. Pictures to follow. |
02-13-2015, 03:55 AM | #140 |
17
Rep 221
Did you get camber plates as well?
02-13-2015, 10:02 PM | #141 | |
472
Rep 577
02-13-2015, 11:30 PM | #142 |
577
Rep 1,035
i thought the fronts come with the camber plates included, or are you referring to the rears? also, do you need to replace the oem camber arms (e.g. megan racing camber control arms) in order to adjust camber or is the bc camber plates along with oem arms enough?
02-14-2015, 11:23 AM | #143 | |
472
Rep 577
The rear, I haven't really looked into this. I though the rear camber/caster could be adjusted, but maybe I need to change the control arms to get those right. |
02-14-2015, 11:38 AM | #144 | ||
e92 - 335i
179
Rep 743
Fronts are more than adjustable. Dropped 3" my plates are almost centered giving me equal adjustment either negative or positive. This is with my alignment set more to the conservative side of BMW's spec. From factory only toe is adjustable. (slight adjustments can be made within the strut tower for camber/caster but very minimal) The rear I had to opt for the upper arms from Megan to get my camber within even the aggressive end of BMW spec. (again, I am set on the conservative side & dropped 3"). From factory it is fully adjustable but obviously only so much. Depending on how much you drop you can get away with the stock arms. You should be able to get away with dropping 2~2.5". I was slightly off the aggressive end at 3". |
03-06-2015, 08:53 AM | #145 |
45
Rep 345
Drives: Many BMW's & Porsche's
OP, would you be so kind as to update your OP with our kits as well?
Link to both the single and double adjutable http://www.tcklineracing.com/index.c...y&Category=796 Check out our youtube channel for our kits in action! https://www.youtube.com/channel/UC-1...4hRiTYqJ9JdEhw Thanks! Double Adjustable with Camber Plates Single Adjustable with Camber Plates |
03-15-2015, 04:33 PM | #146 | |
I plead the 5th.
527
Rep 1,519
-Matt
03-15-2015, 04:38 PM | #147 | |
I plead the 5th.
527
Rep 1,519
-Matt
03-15-2015, 04:39 PM | #148 |
I plead the 5th.
527
Rep 1,519
If anyone else has a kit not listed in OP send me a quick PM and I'll update the original post with pics provided!
-Matt
07-06-2016, 04:52 AM | #151 |
215
Rep 1,407
seems like a lot of people liked your review! i know i did! i plan on looking into these soon
thanks for the write up!
Diligentia Vis Celeritas
07-15-2016, 01:57 PM | #152 |
337
Rep 963
sorry for the mini thread hi jack...
Does anyone know if there's a DIY on how to get the trunk liners out to the point in this picture below? Someone posted it earlier in this thread when showing the KW suspension wiring. Trying to run some electrical wiring (for an exhaust cutout) from under the car and to the fuse box in the trunk. |
07-16-2016, 06:48 AM | #153 |
309
Rep 1,733
Drives: 2003 M3
Lift up the floor tray, it pulls right out. Same with the cubby on the right.
07-16-2016, 01:29 PM | #154 | |
337
Rep 963
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
