09-30-2022, 06:26 PM | #134 |
78
Rep 66
Drives: BMW G30
10-30-2022, 11:29 AM | #135 |
Rep 15
I did some coding this weekend but could not find the code to disable the legal disclaimer. I have a 2018 530i (G30). I looked under the head unit and it was not there.
10-30-2022, 04:09 PM | #136 |
2376
Rep 8,364
12-12-2022, 05:04 AM | #137 |
Rep 1
Hello guys
I am new to this forum, though i've been watching for some time, resolving some problems with my cars with your help. I have a 2017 G31 and recently, with cold weather arriving, i got the ''SOS Call system failure'' message, that is annoyingly blocking the instrument cluster menu. I know that the normal solution to this problem is removing the headliner and replacing the battery in the unit below the shark-fin antenna. But i also know that for some previous models there was a coding alternative, that permanently removed the message from both displays. I have successfully applied the fix to an 2017 F45 , by Bimmercode and it was something like : Instrument Cluster/Expert Mode/3301 CC_ID_Sperre/CC_ACTIVIERUNG_5/Custom Value changing Byte 5 from FF to F7. I will rather code out that warning on my G31 instead of intervening to change the battery, and that's why I'm asking if someone knows the coding necessary for this model. Thanks |
12-25-2022, 05:55 AM | #138 |
14
Rep 35
Drives: G30
I believe you can still use the hotspot locally. You just would not have internet unless you order the service. But for Screen Mirroring you just need to be on the same network, and the network exists whether or not you have an internet service provider.
12-25-2022, 07:33 AM | #139 | |
7870
Rep 5,796
Drives: 2024 BMW XM Label
12-25-2022, 02:48 PM | #140 | |
62
Rep 61
01-01-2023, 10:28 PM | #141 | |
Rep 28
blueboxer0070.00 |
01-29-2023, 02:48 AM | #142 |
2376
Rep 8,364
Ad-hoc local connection is only good for Projected services like Carplay or Android Auto. You would need active data subscription if you want internet.
01-29-2023, 10:33 PM | #143 |
Rep 33
Info
Hello
i have led headlights on my G31,not full led,can i code anti dazzle? First I would like to understand what happens after coding, do they have the function of full led headlights? Thank you |
01-29-2023, 11:28 PM | #144 |
2376
Rep 8,364
Biliardiere5.50 Mike 54038.00 |
02-05-2023, 02:04 AM | #145 |
3942
Rep 4,243
under head unit, expert mode
search Attenuation Sport Plus => active it feels like now sport dampers are stiffer, can anyone confirm or is it just in my head |
02-05-2023, 02:05 AM | #146 |
3942
Rep 4,243
PS if anyone can figure out how to code the 4 options to comfort individual that would be amazing. i can activate comfort individual but can't select the options.
02-05-2023, 01:28 PM | #147 | |
1802
Rep 3,070
Europe has Anti-Dazzle from factory though.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
Biliardiere5.50 |
02-07-2023, 01:29 PM | #148 |
Rep 37
Hi,
Am happy owner of a G31 540d since 2 days and would like to have a few changes made, I was thinking of: - Window should be completely terminated when you open the door. - the small digital Km / h display in the speedometer should go. - Speedometer like to expand from 260 to 320 Km / h. - Sport display ( Kw/Nm ) expand. - Video while driving via USB. - Can you transfer the speedometer display from the Sport, also in the Comfort speedometer? I find the Comfort speedometer very.... boring - Alpina is too much blue for me ... That's all I can think of for now :-) I managed to establish a connection with E _ _ _ and wanted to ask if you could name the target folders and the values you have to change. |
02-07-2023, 02:54 PM | #149 |
2376
Rep 8,364
02-08-2023, 01:28 PM | #150 |
Rep 37
i have also S18, so i choose S15?
And that was not my question :-D I wanted to know in which area... whether it's BODY.... or somewhere else where I can change my wishes if anyone could share them |
02-08-2023, 05:00 PM | #151 |
2376
Rep 8,364
04-13-2023, 12:43 AM | #152 |
Rep 5
HUD music, radio wont scrol thru no more
Hi there,
I have changed into HUD expert some tweaks and right now i see that the music scroling and radios dont work no more. please give me some tips coz in HU_CIC 3000 HUD_ENTERTAINMENTLIST is on aktiv Thnks soo much!!! |
04-13-2023, 02:23 PM | #154 | |
4558
Rep 5,409
