03-05-2024, 01:11 PM | #1343 | |
Rep 5
I have similar unit 825X_Pro with Android13 and run into the same dead end. Mine is Tried the PX6 way from the start of this thread as suggested by RedErik Upon connecting via adb attempting to root I get Code:
>adb root cxj said not suport, 88 Trying su in shell gives me "su:not allowed" will be a bit harder to gain root to these HUs I guess Any ideas appreciated! |
03-06-2024, 04:38 AM | #1344 | |
1052
Rep 2,371
Drives: E63 645Ci
03-14-2024, 09:13 PM | #1345 |
171
Rep 226
Hey guys, I bought this screen for my F90. It's great, resolution is crisp, and the OS is very snappy. Anyway, the default boot animation is the only weak point. The resolution claims to be 2560*720 which seems correct. I'm guessing i would have to create a custom animation. Otherwise, the process would be the same?
03-15-2024, 01:53 AM | #1346 | |
1052
Rep 2,371
Drives: E63 645Ci
03-22-2024, 06:23 AM | #1347 | |
Rep 5
Anyone who would like to give it a try, I suggest to read the RedErik post on the first page of this thread related to PX6 units. My 8259 unit was only playing "android" glowing logo at the boot start. Confusingly, I did not find this being a dedicated bootanimation, it appears the system has none, so this is Android OS default. You need to be able to establish adb connection to your HU. Follow the guide to the point where there is Code:
adb root Enter the following commands: Code:
adb shell Code:
su @#zxcvbnmasdfghjklqwertyuiop1234567890,. remount Insert the USB disk with your bootanimation.zip file and check how is this udentified under your HU (you can use ES Explorer or similar file epxlorer on your HU). Reconnect back after remount, you should now have RW access to your HU. Code:
adb shell Code:
cd /storage/ ls Code:
cp /storage/udisk1p1/bootanimation.zip /system/media/bootanimation.zip You can now reboot your unit and your effort be rewarded by desired bootanimation playing. thanks to RedErik for his work, I hope my bit will allow few more guys to enjoy it on their units too now. Last edited by pinkycz; 03-22-2024 at 06:28 AM.. |
RedErik1051.50 ypolyachenko1.50 |
03-23-2024, 07:49 AM | #1348 | |
1052
Rep 2,371
Drives: E63 645Ci
03-25-2024, 01:22 PM | #1349 | |
Rep 6
At first, I successfully changed the boot animation part. The rest of the attempts were with a "Success" message, but no real effect. Then I reset the current boot animation with bootanimation_clear.zip. Reboot and one more attempt with success for both bootlogo and bootanimation parts. The content of the OEM folder in my case was OEM\ imagefv.bmp <-- image created using MaPaint bootanimation.zip <-- archive created using BootAnimator tool voila you can check my bootlogo and bootanimation here |
03-25-2024, 01:28 PM | #1350 |
Rep 6
Possibly this recent guide will help in your case
04-28-2024, 05:11 AM | #1353 |
1052
Rep 2,371
Drives: E63 645Ci
If you have a native Android 10 unit (i.e. not updated from Android 9), then you can update to the latest A10 version and use the fully unlocked factory config file to enable all UIs. Everything is explained in the first few posts of Android 10 thread.
04-28-2024, 07:36 AM | #1354 |
Rep 4
Hi RedRrik, thank you for the info. I didnt see it sorry, i will have a look. And it is defintive a native android 10 head unit.
04-29-2024, 03:19 AM | #1355 |
Rep 4
Thanks, i have install it
