View Poll Results: Which PSS size for the OEM 19" wheel | |||
255/35R19 - 275/35R19 (F8X specific) | 75 | 17.01% | |
255/35R19 - 275/35R19 (Generic) | 26 | 5.90% | |
265/35R19 - 285/35R19 | 109 | 24.72% | |
275/30R19 - 295/30R19 | 62 | 14.06% | |
275/35R19 - 295/35R19 (F8X-F1X specific) | 169 | 38.32% | |
Voters: 441. You may not vote on this poll |
06-06-2015, 11:33 AM | #111 | ||
Sergeant
823
Rep 2,532
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels | |
06-06-2015, 11:36 AM | #112 |
1905
Rep 5,678
Yes... they will fit an 11" wheel well.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
06-07-2015, 04:50 AM | #113 |
1797
Rep 2,997
I'd like to hear more about hydroplaning on Michelin PSS or a similar street tire.
I'm considering going from stock PSS on 18" wheels to either 19" wheels and wider tires or staying on the 18" but going with a 275/295 front/rear in Michelin PSS. However, I've needed this car to bring me safely through some really hairy stuff in the rain. I don't want to significantly deteriorate that capability. |
06-07-2015, 04:23 PM | #114 | |
617
Rep 1,820
2016 Individual Silverlake/Amaro M3 Conceived by ///M
06-22-2015, 04:10 PM | #115 |
Like it a Lot
53
Rep 30
Drives: Hot Rod Red M4
Tire question
Thank you for all the info on your tire size thread. I recently finished a track weekend at Barber Motorsports and running a completely stock set up. My front tires and pads are toast. I'm still a novice driver but run blue group with an instructor with Chin Motorsports and ran mixed solo and instructed group 2 with PCA. My instructors have had me driving in partial MDM.
My m4 is my daily driver. I have the 19 inch rims. I'm going back with stock pads for now because I'm not convinced about the carbotech's or pagid rs29's, especially since I only do 3-4 events/year. My question is the tires. I definitely encountered a lot of push during hard cornering and felt like it scrubbed off a lot of my speed. It was also a very hot day and MDM made it hard to accelerate out of corners. My instructor and I definitely felt like tires were an issue. In your thread, you recommended going with the 275/35-295/35 combo; but then later I saw in another thread that CanAutM3 is now running a square setup with 275's. My instructor recommended running a square setup if I can, so I can rotate tires. Any updates or opinions? |
06-22-2015, 04:33 PM | #116 | |
General
21132
Rep 20,742
Drives: 2021 911 turbo
My track setup is the square one; with 275/35R18 NT01 shod on Apex EC-7 18x10ET25 wheels. I run a square setup at the track to better balance tire wear, but the S55 has so much torque, that I am waiting for Apex to release a proper fitting 18x11 EC-7 and considering going with 305/35R18 in the rear. If you encounter that much "push" that scrubs off too much of your speed, it gives me the feeling that you are overdriving the car. The F8X is pretty neutral from the factory (as opposed to the E92 and E46 M3s). Try the famous slow-in-fast-out approach, smooth is fast . Regarding brakes, while I was surprised how decently they performed at the track for street pads, the OEM pads are just that: street pads. You might want to consider going with a proper track pad. It will end up costing you less because they will last much longer at the track while giving you better brake performance. Even in MDM, the stability system is very intrusive. But again, if you struggle to accelerate out of corners at the beginner level, it tells me that you are overdriving the car. Try a little throttle modulation and don't forget to open the steering before applying more throttle. You may want to consider coding Euro-MDM, it is a huge improvement over the US-MDM. The PSS are just not a proper dry track tire for the F8X. When pushed just a little, the outer tread block start to melt and chunk away. IMO, going to a larger size will not change much of that. You should consider AD08R, RE71 or NT05 for example, which are pretty good non-r-compound tires for the track. Do note that if you go with a square setup, MDM (even Euro-MDM) well get seriously in the way with constant and useless interventions. Running DSC off will be the only real option, which does involve more risk (but way more fun ). My M4 wearing it's track clothes :
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-24-2015 at 03:22 PM.. |
GrayM42.50 |
06-23-2015, 05:00 AM | #117 |
Like it a Lot
53
Rep 30
Car looks great! Thanks for the info. Very helpful. You are totally right about overdriving. My instructor and I had a lot of conversation about that. By the end of the weekend, I was much smoother. But once those PSS's got hot on a hot track, it was like there was butter on them.
Probably going with the staggered setup you recommended for DD/wet track. I'll have to price out an extra set of the apex square setup. Thanks again |
06-24-2015, 02:26 PM | #118 |
1860
Rep 2,104
Great to see this thread has gotten a lot of traction :P
I'm really surprised how good the 275/295's look. Fills out the wheel well nicely, pushes the tire out, and the extra rubber looks more race car IMO. Although, I got distracted a little by the MPE... OP, I was surprised to hear your observations about wet traction, especially given you had OE tires vs generic (with the wider water channels). I assume you've driven through similar puddles with the stock MPSS and not had this issue?? Also, as your wet track setup, have you had a chance to use the 275/295 setup on the wet track yet? Great thread. I'm thinking I'm gonna go with the 275/295/35 setup, and sooner rather than later by just moving the rears up front and getting the M5's tires for the rear. BTW, I think they paint SilverStone a different color for Canada; it looks so silver, and so good |
06-24-2015, 02:39 PM | #119 |
HALA MADRID!
941
Rep 2,879
CanAutM3, any updates on your hydroplaning issues?
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
06-26-2015, 01:55 PM | #120 |
788
Rep 962
Drives: G87 M2, G20 330d, Brabus Smart
That looks spot on. I think this setup plus the Eibach Pro Kit (when it becomes available) will look fantastic, plus actually be functional. How much room do you find left for spacers? I know you're not a fan of them, but in the name of science, inquiring minds want to know!
@DBV_
Current: '23 G87 M2 6MT / '21 G20 330d / '18 Brabus Smart Gone: '21 G05 X5 M50d / '18 MB C63s (632hp) / '16 F80 M3 6MT (570hp) / '09 F01 750i / '16 Abarth 595 Competizione (202hp) |
06-26-2015, 03:50 PM | #121 | |
General
21132
Rep 20,742
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-26-2015, 04:03 PM | #122 |
General
21132
Rep 20,742
I would not call it an "issue" per se. The car is still drivable and safe in the wet with the 275-295/35R19 setup. It is just more sensitive to standing water than the OE setup. It is all a question of compromise, this setup favors dry grip over wet (standing water) grip.
I am guessing it is a reason why BMW did not go with wider contact patches on the F8X, to ensure better wet performance. I am still very happy with this setup though .
06-26-2015, 06:01 PM | #123 | |
HALA MADRID!
941
Rep 2,879
07-03-2015, 02:01 PM | #124 |
HALA MADRID!
941
Rep 2,879
So guys, I just ordered the 295/35 PSS tires, and had a call from tirerack insisting the tire is not a good choice due to the big increase in diameter... I explained some of the points in this thread, etc, and kept the order anyway.
Having said that, does anyone have an idea on how the speedometer readings are affected by this 275/295 /35 setup? |
07-03-2015, 02:07 PM | #125 | |
General
21132
Rep 20,742
So that means that my speedometer is now 2% MORE accurate .
07-03-2015, 02:18 PM | #126 | |||||
General
21132
Rep 20,742
Really loving that MPE too, sounds great and looks good too. Loving the Ti tips Quote:
I'd do it again just for the improved steering feel . Quote:
I love Silverstone, it is such a dynamic color that changes depending on lighting and surroundings.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 08-24-2015 at 03:21 PM.. |
07-03-2015, 07:01 PM | #127 | |
Bored at work....
893
Rep 5,397
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
07-06-2015, 04:45 PM | #128 |
Like it a Lot
53
Rep 30
I just rotated my 275/35 PSS's to the front and put 295/35 on the rear. I can't believe how much more planted the car feels. I agree with others that this is how the car should have come stock. I should have done this months ago.
09-23-2015, 10:56 AM | #129 |
135
Rep 408
Great work CanAutM3 and everyone else! Thanks for the research and feedback! Anyone gone with OE 275/295 on ACS spring? Seems like it would would fill in the fenders nicely width and height but I worry about clearance.
Thanks! |
10-27-2015, 09:43 AM | #131 |
142
Rep 1,399
Just a quick thing I want to add. The official recommendation from BMW for F8X winter setup is square 255/35R19 96V. I have this setup and didn't notice any unusual DSC intervention. However, after getting a square track setup and having this small "problem" on my mind, I will pay more attention this winter
10-27-2015, 10:01 AM | #132 | |
General
21132
Rep 20,742
On the track it is a different story though. You want to drive as close to the limit as you comfortably can.
