11-04-2020, 10:04 PM | #89 |
392
Rep 2,367
Drives: 2011 335i
11-05-2020, 05:53 AM | #90 |
15
Rep 67
Yes for the Inpa.rar, there are files that you must place in the sgdat and remember to add the rfk_70 entry under e9x. You can also use ISTA/D and the trsvc should also appear.
SaNGRia996.50 johnnyorange58.50 |
11-16-2020, 09:46 PM | #91 |
10
Rep 31
11-17-2020, 01:16 PM | #92 |
392
Rep 2,367
Drives: 2011 335i
11-26-2020, 12:58 AM | #93 |
Rep 10
SaNGRia Did you manage to default code the TRSVC if so how did you do it ?
I can communicate to TRSVC with INPA and ISTA+ but not with NCS Expert, in NCS Expert the TRSVC module does not show up in the ECU list, only RFK is there and it will not communicate if I choose that. Calibration was carried out successfully with ISTA and its all working but I want to edit some coding in the TRSVC with NCS. |
11-26-2020, 07:41 PM | #94 | |
997
Rep 1,353
Yes I did. Only way to default code the TRSVC is to have ICOM. TRSVC is not as easy as other modules. It does complicated calibration and regular OBDII cable is not capable of doing it.
Best Regards from the DIYKing Quote:
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
SYT_Shadow11517.00 |
12-08-2020, 02:08 AM | #95 | |
Rep 32
So even if I use newer JBE3 module marked KL (stands for Kline) it is not going to work? |
12-08-2020, 06:12 PM | #96 | |
997
Rep 1,353
SYT_Shadow11517.00 johnnyorange58.50 |
12-09-2020, 01:07 AM | #97 |
Rep 32
Checked the wiring differences between Kline and DCAN, so if I understand correctly, I need only 1 additional wire to OBD port pin6, from DCAN JBE?
12-09-2020, 06:32 PM | #98 |
997
Rep 1,353
Seems like it. You need Orange/Green and Green
01-11-2021, 11:52 PM | #100 |
997
Rep 1,353
Pleasure buddy, Enjoy
01-26-2021, 04:16 PM | #102 |
997
Rep 1,353
Thank you! MUST! Only E84 going to work!
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 01-26-2021 at 05:21 PM.. |
01-26-2021, 10:41 PM | #103 |
Rep 10
01-27-2021, 11:02 AM | #104 |
997
Rep 1,353
Correct!
04-06-2021, 07:02 AM | #105 |
273
Rep 298
I am attempting to add the backup camera but I have a 6mt no pdc. From what i have researched, it appears that i cannot install the backup camera without retrofitting pdc. If i retrofit the e84 pdc box, do i have to plug in the sensors too?
04-06-2021, 07:24 PM | #106 |
997
Rep 1,353
Yes sir. You need to have an active PDC sensors running. so you should at least do the rear PDC retrofit. After that you can PM me and i can do the remote coding for you.
05-07-2021, 02:10 PM | #107 |
Rep 2
Un Genio
después de buscar y buscar por miles de pagina llegue a esta super interesante.
os cuento mi problema para ver si podéis ayudarme. Yo tengo un x5 e70 del año 2007 que venia con ccc , hace unos días reequipe con CIC pero mi desagradable sorpresa es que he perdido la cámara y el pdc . el pdc solo suena cuando pones reversa pero sin gráficos . Creéis que es un problema de coding? Mil gracias y enhorabuena @SANGRIA por este post Last edited by josetev2; 05-07-2021 at 02:13 PM.. Reason: ortografia |
05-08-2021, 12:20 AM | #108 | |
997
Rep 1,353
07-19-2021, 11:37 PM | #110 |
23
Rep 113
Have you or anyone else done the side or top view yet? Considering doing so as I have a local JY with an X5 for cheap.
Also, thought this might interest you. Did an M5 steering wheel and F80 seat in my E84. Can also do it on an E93 without a doubt. https://photos.app.goo.gl/Jt2rxhA2fhVYZ47c8 Full function, including heat, lumbar, and the //M light. https://photos.app.goo.gl/UG4rGRmwmYpCzXxV9
=||=2011 BMW 335D MSport =||= - gone but not forgotten
2008 BMW 335i FBO 2015 BMW x1 35i DD, mhd stg1 2005 MX-5 LS swap |
