07-21-2022, 08:28 PM | #90 |
212
Rep 577
I think you're referring to @kleaperm4 on Instagram.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
07-23-2022, 10:09 AM | #92 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
I ramp the torque up, so im not trying to make a ton of peak torque in the midrange. This helps reduce the stress on the rods because they are able to transmit the torque better when the engine is rotating faster.
Clevocapri18.50 |
07-23-2022, 07:57 PM | #93 |
212
Rep 577
At 900whp, that should take the record for highest horsepower on a stock block S55. It's cool to see this platform keep developing.
current
chetrickerman10446.50 |
07-28-2022, 03:12 PM | #94 |
773
Rep 961
Any updates??
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
07-28-2022, 06:25 PM | #95 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Yep, I installed the head, just have to put the rest of the parts on, then I will fire it up.
08-02-2022, 03:01 PM | #97 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Its running well now. Im going to put some miles on the new parts to let them get broken in.
I also installed a turbo speed gauge so I can see if I have any headroom with my turbo to push the boost even higher.
08-08-2022, 12:21 PM | #98 |
69
Rep 40
I love well documented threads like this, I wish they were more common! Keep posting updates, this is an epic build!
09-02-2022, 11:17 PM | #99 |
Rep 4
Wow awesome build
chetrickerman10446.50 Unheardmyth21.00 |
09-19-2022, 09:43 PM | #100 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
No big updates yet, the car is driving well and is pulling hard. Im going to wait until the winter to hit the dyno because I want to make another downpipe. This one will use a concentric expansion going from 3" to 4" which the small angle of expansion should increase turbine efficiency allowing faster spool up and easier breathing of the engine.
Here is how the engine bay looks as of September 2022. As another project, I also picked up another S55 block. This one had part of the connecting rod impaled into the oil galley, so I got out my Makita die grinder with some carbide bits and removed enough aluminum to get the piece out and leave a fresh surface that I can weld and repair. The block will be getting sleeved.
WordOnRoad313.00 McBobby Jr212.00 |
09-19-2022, 10:03 PM | #101 |
773
Rep 961
Looking good. Yikes, that rod definetly left its mark!!
M4CS Frozen Blue
09-19-2022, 10:07 PM | #102 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Here is how it looked before I got the piece out
11-01-2022, 09:01 PM | #103 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
The downpipe is done and it is glorious. I was able to use the long concentric expansion to maintain attached laminar flow uniformity better to further improve turbine efficiency. The first almost 3 feet of the downpipe is 4 inch stainless tube, which then necks down smoothly to 3.5 inch to accelerate the exhaust flow and reduce pressure drop. I then went through the rest of the downpipe and exhaust and cut out the tight radius bends and replaced them with smoother more gradual bends to help keep exhaust velocity as high as possible.
You can see in the side by sides how much smoother the new downpipe is. I took it for a test drive after finishing it and could immediately tell a difference in spool up and response. I will update later how much faster the turbo gets to full boost compared to the old 3.5 inch downpipe. If you have a single turbo setup, definitely get the 4 inch downpipe if there is the option! I also added an external wideband so I can see the true AFR average of both banks so I can be absolutely certain the AFR is within a safe range. I chose to use the Zeitronix ZT-3 which has the CAN Bus option so I will be able to see the ZT-3 AFR in my datalogs through the ECU.
Hxngs176.00 F30_320D_UK215.00 DaiLyCS166.50 WordOnRoad313.00 Wanted_M772.50 TopJimmy5537.50 McBobby Jr212.00 |
11-03-2022, 07:50 AM | #104 |
First Class
167
Rep 190
Always loved Chet build, you always put a lot of effort into the build, I followed you since the evox build and got it tuned by you also.
Im excited to see where this go |
11-03-2022, 05:34 PM | #105 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Thank you!
11-04-2022, 07:01 AM | #106 |
26
Rep 35
Question. As a non engineer, slightly ignorant individual, why go from a dual turbo system down to one? More turbos = more boost, yes? With your knowledge and availability with parts, why not just change the current twin turbo system, try for better airflow and move from there.
OR, was this a passion project to test your own limits? All very impressive stuff, great work.
Cheers!
11-04-2022, 04:16 PM | #107 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
With the advent of the Borg Warner EFR turbos, they utilize a Gamma-Ti turbine wheel which has half of the inertia compared the exact same size turbine wheel made out of Inconel or Mar-M. This dramatically affects transient response, and with their redesigned compressor wheel that flows a lot more, I chose to go this route. The sound, response, power and simplicity this setup produces is found no where else on the market, hence why I decided to make it myself.
cmcintosh33926.00 TopJimmy5537.50 |
11-04-2022, 05:11 PM | #108 |
215
Rep 190
Those pipes look great and will flow so much better than before.
Interesting about the Gamma-Ti turbine wheel! |
11-04-2022, 06:26 PM | #109 | ||
First Class
167
Rep 190
