F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > _das_bae_ "Betty" Sparkling Brown Metallic Build/Gallery Thread
ARMA SPEED
      11-11-2021, 11:54 PM   #67
_das_bae_
_das_bae_'s Avatar
375
Drives: 2015 435i Coupe
New Splitter and Front Spacers Installed
For those of you wondering, here is the car at normal driving height after the spacers have been fitted.
IG:@_das_bae_
2015 435i Sparkling Brown Metallic (B53) OEM+
https://f30.bimmerpost.com/forums/sh....php?t=1705873
Appreciate 2
Tallest1321.50
_baz567.00
      11-22-2021, 02:00 PM   #68
_das_bae_
_das_bae_'s Avatar
375
Cosmic
Oh and here is a little teaser for what's next...
IG:@_das_bae_
      12-15-2021, 12:48 AM   #69
_das_bae_
_das_bae_'s Avatar
375
PS1 and Turbosmart Dual Port Installed
Just took the car on a 600mi road trip and got to test out the new turbo. I also had a turbo smart dual port installed alongside it. The Pure Stage 1 is definitely noticeable and the best way I can describe it is that the car is more confident and doesn't feel like its running out of breath from very early in the rpm range all the way to about 6000 -- where you will notice the difference over the stock turbo (1900-5500). In comfort mode and sport mode you feel the extra power on tap. I would say the difference is about as much as you feel from adding a stage 2 flash tune over stock. The car is more eager to go and every MPH increment you are used to, add 10 to that and that is what the car actually does now...and it still feels like it has more to pull in the higher rpms. The car climbs hills with ease as well as makes the acceleration of the car feel overall quicker. The turbo smart isn't obnoxiously loud but you can hear more of the whoosh than that of stock or the non dual port variant. If you really want to hear it, it is easily noticeable in sport mode if you let the computer do the shifting for you. Basically be at a cruising speed in 3rd or 4th, then press accelerator and just before the car fully starts to build boost let off.
I also DIY'd the airlift controller retrofit into my dash to get rid of the loose wires running near the driver seat. It also eliminates the cheap cellphone vent mount I was using before. Took about 2 days to complete but I would say it turned out pretty well. This isn't a direct fit so it does require modification (cutting) of the vent and dash trim to fit. It is a very snug fit that stays firmly in place by the tight clearances made and the wire runs behind the center console area for stealthiness.
IG:@_das_bae_
Appreciate 2
      01-02-2022, 07:41 PM   #70
_das_bae_
_das_bae_'s Avatar
375
New Year, New Changes
Just in time for the new year I decided to retire my previous wheel setup (19s) with a new set (20s) and live out my stance/fitment dreams.
Here is a close up of the front and rear wheels
Here is the car on the alignment rack
It's been raining most of the last two weeks so I haven't had the time to wash the car but here is a picture of the wheels in the sunlight as well as how the fitment looks from the rear.
For anyone interested in specs for the new set...these are 20x8.5F +20 and 20x10R +20. The front is running a Future Classic 10mm spacer effectively making it a +10 offset. The tire set up is 225/35F and 235/35R.
IG:@_das_bae_
Samir72434.00
      01-17-2022, 07:21 PM   #71
_das_bae_
_das_bae_'s Avatar
375
Had the fenders worked out in the rear so I don't have to worry about rubbing and the tires can properly tuck once aired out.
IG:@_das_bae_
      02-15-2022, 10:50 PM   #72
_das_bae_
_das_bae_'s Avatar
375
First proper shoot With the new wheels
IG:@_das_bae_
Appreciate 2
smak16899.00
M@kinen30.00
      02-16-2022, 03:19 AM   #73
_baz
_baz's Avatar
567
Drives: F30 330e
Got that fitment dialled mate ! Looks perfect
What are those wheels? They have a BBS LM vibe but a one piece ?
_das_bae_374.50
      02-22-2022, 11:40 AM   #74
_das_bae_
_das_bae_'s Avatar
375
Appreciate it! I’m glad I made the switch, I was worried about the ride feel on 20s but it’s not that much difference compared to my previous set of 19s.
Yes these wheels borrowed the design of the LMs and are one piece with a decent size flat lip (1.5” and 3” in the rear). I have the full specs posted on the 1st post as well as a couple posts ago. They’re 20” Beyern Mesh wheels, a subdivision of TSW that makes hub specific BMW wheels and offsets. A few forum members have ran them and they have all had positive results so I wanted to try out a new look.
IG:@_das_bae_
      04-06-2022, 10:04 PM   #75
_das_bae_
_das_bae_'s Avatar
375
Warm Tint
Bonus pic of the car getting washed
IG:@_das_bae_
      05-03-2022, 11:00 PM   #76
_das_bae_
_das_bae_'s Avatar
375
Carwash
I love how much detail the 50mm captures, this is taken at F4 and you can really see the flake with speckles of gold
Some garage pics
IG:@_das_bae_
      06-02-2022, 12:02 AM   #77
_das_bae_
_das_bae_'s Avatar
375
Finally on BM3 Stage 2 and Tune Review Comparison
Recently made the jump to BM3 Stage 2. It's definitely a bigger and more rewarding upgrade having the Pure Stage 1 installed. The car is louder, has more pull from even lower rpms, you can hear the BOV and intake more... the car feels like it's a living breathing machine now. From cold starts to pulls in turbo weather, the car just goes. I can only imagine what this would be like with supporting fueling mods like meth or running an ethanol blend.
Okay... but besides the bedazzling feeling Stage 2 will give even with a stock turbo, there isn't that much more of a power bump from running the Dinan piggyback tuner. Butt dyno feels like its smoother power delivery when you catch the throttle of guard (i.e. high gear pull will downshift faster) and maybe a gain of like 20-30hp and another 30-40tq. The ZF now has a stronger clamping force with the transmission tune (makes the shifts a little harsher but in a sporty way) making sport mode seem like it pulls more aggressively than before. Overall if you get BM3 at a deal its definitely worth it. If you are the type to want to play things safe (turbo longevity) with a close to Stage 1 tune on stock turbo, the price of a piggy back used is definitely worth it and gives you enough of a taste to decide if you want more power. I think if I would have stayed on stock turbo I would not see as much of a gain as I did now having an upgraded turbo. The best way I can describe it as the car has more capacity to make power - with the stock turbo, the car feels like it is getting close to running out of air up top and could make more oomph down low. The PS1 turbo easily makes the same power as a stock turbo with less throttle input and has more room up top. For a daily street car, this is enough power for me to still have fun on the streets and back roads without having to feel like it is too much car for the road (especially living in a city).
IG:@_das_bae_
      06-02-2022, 10:26 PM   #78
M@kinen
M@kinen's Avatar
No_Country
30
Drives: e87
Wow 👌🏻👍🏻
_das_bae_374.50
      06-24-2022, 09:20 PM   #79
_das_bae_
_das_bae_'s Avatar
375
Originally Posted by M@kinen View Post
Wow ��������
Thank you!
IG:@_das_bae_
Last edited by _das_bae_; 06-24-2022 at 09:59 PM.. Reason: Added the most recent picture of the car
      05-15-2023, 10:22 PM   #80
_das_bae_
_das_bae_'s Avatar
375
Summer Setup
Once again, new year and just in time for Summer... the 20s are going in storage for a bit while I try another 19" wheel setup. The 20s have been nothing but great and really filled in the wheel wells. With this new set of 19s, they are more of a classic vibe but also sporty finished in grey. They also help put more power down to the ground.
Specs - 19x8.5 +20 225/40/19 and 19x9.5 +32 255/35/19, 10mil/12mil spacers F/R
IG:@_das_bae_
Appreciate 2
toxik2522.50
      05-16-2023, 07:38 PM   #81
eff32fl
eff32fl's Avatar
1086
Drives: 2019 440i M Sport THP MPPSK
Awesome build! That color is certainly unique. Have you thought about switching to an M Sport steering wheel? Maybe an aftermarket one if so? That would be the icing on the cake imo.
_das_bae_374.50
      05-18-2023, 01:00 PM   #82
_das_bae_
_das_bae_'s Avatar
375
Appreciate it! Yeah, I'm not a fan of the M Sport wheels... they're too thick for my liking, but besides that, I like the design. Coming from the E92 Chassis I felt the stock wheel was the right amount of thickness and looks fine to me.
IG:@_das_bae_
      01-25-2024, 12:08 AM   #83
_das_bae_
_das_bae_'s Avatar
375
Some more changes
Recently had some downtime between projects and decided to add a little bit of eyeshadow to the headlights. The LED driver for my brows decided to fail so I decided to just try out the ring only. The side marker/indicator lights are back to the factory position but just LEDs.
As a Christmas present to myself, I decided to pull the trigger on a full audio upgrade. I decided to go with the Focal Inside Premium 9.2 setup for the speakers, but run Rockford Fosgate T3 Subs instead of the focal option. Also wanted to upgrade the Amp as well to the MatchUP 7 DSP. You'll need a Windows computer to tune the amp, but the software isn't too hard to learn.
Full Speaker Setup
Install
Rear Tweeter Bracket Mounting After Cutting a Hole
Final Mount Speakers Rear Seats
Amp Mounting
Front Woofer and Boom Mat Install
Front Tweeter Swap and Wiring
Under Seat Subwoofer and Boom Mat Install
Loading up a tune and testing the software... and no the output gain isn't really set that high, that was just testing what sliders were modifiable.
After 20hrs of break-in and playing with the DSP tune file, I finally achieved the sound I was looking for. It's a much-needed improvement over the Stock Hi-fi speakers... and dare I even say it might sound better/clearer/punchier than the HK system. I would definitely recommend the upgrade, you won't regret it.
IG:@_das_bae_
      01-25-2024, 01:14 AM   #84
Onizukachan
Great Teacher
Onizukachan's Avatar
1139
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Make sure you hang on to your hifi speakers, those hifi 4” mids are actually better than the vast majority of aftermarket’s. Amd I like the tweeters better on the hifi.
Tip: the HK center grill is different, the metal mesh and more acoustically transparent than the plastic hifi grill and makes a difference all on its own.
If you want to try playing with time alignment, checkout my last tune I posted when I had my f31. I think you will be very pleasantly surprised. At the very least you can load it, write down the T/A values, and apply them to your own eq/over tune. Should save you a few hours tuning on that part alone.
I also recommend playing the same track on mono and stereo to help dial in t/a and the minor eq and gain differences between left and right.
For anyone who reads this in the future you don’t need to swap ota coax on the center, if you really want the tweeter, they are on sale all over eBay for $20. Amd jsut plug right into the factory mid.
I added the HK tweeter to center, and wound up tuning it back out with a low pass xover because it will F your imaging.
If you are stock amp, just put the HK grill on and no tweeter.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
      03-28-2024, 12:50 AM   #85
_das_bae_
_das_bae_'s Avatar
375
I appreciate the response. I didn't plan to do anything with the stock speakers, the main goal of this was to do a full amp/speaker/sub upgrade at the same time and match a similar sound I have in my other project car. Also since I was going to upgrade one thing and already had the interior apart, I wanted to go all the way. The center speaker came for free since I bought them from another forum member and I don't have it currently plugged in as most don't run the center speaker. I swapped it just for fun (focals site has their different layouts - center coax/no rear tweeters) and also cause the center speaker had sun fade on the cone which you could see from the windshield - that bothered me. I wasn't recommending others to do their installation the same way as me, just said that the benefits from the sub/amp/rear tweeter upgrade and using the speakers at their fullest potential were worth it to me.
It may have been misunderstood but the 20 hours was for the speaker break-in time and the messing with the software was another few hours. I am running a tune from the forum thread for MATCHUP7 files. What I also noticed is how some files were set up for F31 and F30 but not much for F32. The speaker placement for the front seats in the coupes puts you closer to the rear set, so the file I ended up using still needed tweaking to finalize it. I figured that these pics would at least help others see that you do not need to use the MATCHUP7BMW specific amp - as long as you get the correct harness; you can also make your own bracket. I also did not want to bother swapping the grilles since mine is fine in terms of aesthetics and in the end, I'm not even using that speaker.
IG:@_das_bae_
      03-28-2024, 11:35 PM   #86
Onizukachan
Great Teacher
1139
No worries, I might have miinterpreted, as I had well over 20 hours in tuning time on my f31 final tune, just trying to pay forward some of what I learned from tuning it and trying various changes.
I was so impressed with the f30 factory hifi speakers I bought a set for my Logic 7 e91 and did the f30 hifi center to replace the logic 7 center, (much much better performance on stock L7 amp) and will later be using the hifi f30 front tweeters on it as well.
been told by someone who tried recently that the flanges are different f30/e90 though so the door mids won’t correctly fit the e90 door cards.
A few OEM+ mods:
      05-02-2024, 09:50 AM   #87
Bezerk
Bezerk's Avatar
Netherlands
391
Drives: BMW 328i GT
Just stumbled upon this thread, and normally i'm just browsing/lurking, but this time i just had to make a comment: great looking car, especially with the 20's!
Love the fact that it is so 'clean'. By that i mean no excessive spoilers, no M3-like mirrorcaps, etc.
Really a beauty!
_das_bae_374.50
      05-03-2024, 06:00 AM   #88
GulozbossM
Enthusiast
Drives: M240i, 3281
Beautifully done and a good work of art, indeed a very unique color.
Love it. 👍
_das_bae_374.50
f30post
