M2 Technical Topics > Track / Autocross / Dragstrip > DIY brake ducts
      08-30-2018, 04:56 PM   #67
DrKevM5
DrKevM5's Avatar
2281
Drives: G05 X5, F87 M2
And that actually isn't a bad price considering the advantage it gives on the track. Racin' ain't cheap.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
      08-30-2018, 07:51 PM   #68
Xchange43
61
Drives: 2018 F87 BMW M2 LCI
I just did a quick search on google and found this so with more research i could find other kits cheaper
2011 BMW X1 28 (sold)
2013 BMW 328 Sportline (sold)
2018 BMW M2 LCI (current)
      07-05-2019, 12:15 PM   #69
GasBurnlife(landapanda)
576
Drives: BMW M2
Hey everybody, I just did the Porsche GT3 air ducts in stall on my '18 F87, and wanted to leave the installation video and couple of pictures here in case anyone else is going to attempt a DYI in the future.
Buy the duct kit here:
https://www.ecstuning.com/b-genuine-...hoCpuMQAvD_BwE
Picture of the original air ducts as well as the modified ones,including tools needed for the install:
Appreciate 5
omasou2093.00
mcvaughan706.00
pbar1400.00
dcmac443.50
      07-05-2019, 01:00 PM   #70
booya_45
87
Drives: 2017 M2
Thanks for sharing!
      07-05-2019, 03:32 PM   #71
M2C AW
184
Drives: 2019 M2C Alpine White
+1 thanks for sharing !
does anyone know..does the Porsche have the backing shields similar to ours ??
How do they channel the air flow toward the center hub ?
On our cars, Its hard to imagine that sufficient air will actually get to the hub center with the shields in place and unmodified.
randyt224.50
      07-05-2019, 07:33 PM   #72
576
Drives: BMW M2
My buddy has a 911 S and he has them front and back. He had backing plates, but I don't recall how aggressive was the opening. Next time I am at his house, I'll take a picture. Or someone could pull the schematics for 911 brakes...
      07-16-2019, 09:48 AM   #73
dvas
dvas's Avatar
524
Drives: 2017 M2 - Mineral Gray, 6spd
Completed the long overdue brake duct diy over this weekend. Wasn't too bad, took about 3 hours taking my time. Had to buy a few new tools (oh no) including a drill, some bits and a hole saw and an assortment of parts. The parts totaled about $200, add another $100 for new backing plates if you ever want to return to stock.
I'll be at Limerock for the PCA event this Monday to see if this makes a material difference. I fear my testing will be anecdotal as I don't have a way to measure a difference and my calipers have long turned black. I hope that at least these ducts help prevent cracking of brake pads, which has become a problem recently.
I got guidance on everything from the following post, although I think his duct mounting points were better located:
https://f80.bimmerpost.com/forums/sh...=brake+cooling
bentom2335.50
      07-16-2019, 11:59 AM   #74
M2C AW
184
Looks good...nice job and.....Thanks for posting !
      07-19-2019, 06:34 PM   #75
backmotor
29
Drives: 2017 Mineral gray M2 DCT
I got tired of make-shifting some brake cooling ducting and finally dove in the rabbit hole! I found a set of M4-GT4 brake ducts from a racing friend of mine and decided to make it work on my M2. It took some work, taking off the front bumper cover and all related shields, etc. plus modifying a few areas to get the duct through, but I think I have some decent brake cooling now.
It consists of a 2.5" hose from the front of the nose with the M4 scoop, and a 3" hose from a scoop under the A-arm. The GT4 backing plate replaces the stock shield, is carbon fiber, and has provisions for both the 3" and the 2.5" hose. The scoop is plastic and is one I had lying around, not part of the GT4 setup. I did cut out the bumper cover to fit the GT4 small scoops for the 2.5" hose, but I'll get over it. The M4 nose is not exactly the same shape as the M2 nose, but I think it looks OK and it works.
All this is after I gave up on the stock M2 brakes and went to AP calipers and rotors.
Just thought it might be of interest to some of you guys.
Appreciate 8
      07-20-2019, 04:35 AM   #76
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
Nice place for the bumper air intake.
Do you have any pics of the GT4 backing plate? Curious how they aimed the two hoses on to the rotor
      07-20-2019, 12:24 PM   #77
backmotor
29
The CF backing plate replaces the stock backing plate, and the two hoses are directed into the eye of the rotor, not onto the rotor itself. I blew air into the front of the car and could feel it coming out of the vents in the rotor, so it works. I'll try and get a pic of the CF backing plate and post it.
      07-20-2019, 03:09 PM   #78
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
I have the cf backing plate from Lightweight for one hose which works very well. It also points the hose to the center. Curious about the double hose setup :-)
      08-31-2019, 07:42 AM   #79
FlyingLow78
The G8X is a disaster. 🤮
931
Drives: Not a BMW anymore
Originally Posted by Xchange43 View Post
I m resurecting this post but does anyone have tested this solution :
http://www.revozport.com/f8x/rzp-bra...it.html#popup1
looks great but not sure if compatible :
https://f80.bimmerpost.com/forums/showthread.php?t=1379690&highlight=Revozport
I tried it, and I’m picking up the front scoops again soon. I still have the rotor shields as well (including the one with a bit of burn through), but I plan on modifying the stock aluminum shields with duct connections.
      09-10-2019, 08:48 PM   #80
DrKevM5
DrKevM5's Avatar
2281
Installed the 997 Turbo Rear Brake Cooling Duct Kit. Figured the additional rear cooling couldn't hurt. Slight modification needed for clearance.
Appreciate 2
      09-10-2019, 10:14 PM   #81
M2C AW
184
Can’t tell..did you remove the shields ?
      09-11-2019, 04:34 AM   #82
DrKevM5
DrKevM5's Avatar
2281
Nothing was removed
      09-11-2019, 06:10 AM   #83
ZM2
2840
Drives: 2017 LBB M2
I added the Porsche air deflectors to the rear a while back, but also cut away a quadrant of the backing plate so cool air can make it into the hat.
It surprisingly made a noticeable improvement.
      09-11-2019, 11:17 AM   #84
ZM2
2840
Drives: 2017 LBB M2
I dont believe the deflectors can help much without removing some / all of the shield / plate.
If you cut the correct portion of the protection plate and align your deflector correctly, the air flows right into the hat where you want it—same as the fronts. You don’t have to remove the whole plate.
      09-12-2019, 05:09 PM   #85
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
Part numbers please?
      09-12-2019, 05:15 PM   #86
DrKevM5
DrKevM5's Avatar
2281
https://www.ecstuning.com/b-genuine-...99733148702kt/
      09-13-2019, 01:24 PM   #87
MagnusT
MagnusT's Avatar
Sweden
538
Drives: BMW M2
Thank you!
      09-26-2019, 02:03 PM   #88
FlyingLow78
931
This is the kind of cooling I want. I have AP fronts as well, but none of the cooling solutions seem effective enough to survive at Monza.
Any idea where I could at least find scoops like you have connected to your lower arms? I’m not willing to cut my bumper just yet. Snaking the cooling hose through the narrow gaps between the body brackets and the various radiators doesn’t sound like fun, either. I’ve already spent a lot of time looking around the area inside the wheel arches trying to find a path for the cooling hoses, and everything is a compromise.
Did the M4 rotor backing plates fit correctly on the 372mm rotors?
m2
