BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Coding "ALPINA" Style Display
      02-08-2018, 06:06 AM   #67
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Originally Posted by csm7djs View Post
I was going to go back to coding using e-sys but searching the house it seems I've either thrown the old cable away or the wife has.
Just purchase another. It will be a lot less work to just VO code in EBT.
      02-08-2018, 08:14 AM   #68
bpbaud
Drives: 530i
What do VO and EBT stand for?
      02-08-2018, 08:51 AM   #69
bpbaud
Drives: 530i
Originally Posted by Flyingscotsman View Post
There's quite a good thread on the bimmercode app here:
http://f87.bimmerpost.com/forums/sho....php?t=1338157
There's a lot of pages to read, and some of the stuff isn't available/relevant to the G30.
I'm about halfway through that thread, and I'm learning a lot. Thanks for the link.
      02-08-2018, 09:02 AM   #70
csm7djs
70
Drives: G05 X5 3.0d M-Sport
Vehichle Order and Enhanced Bluetooth
      02-08-2018, 09:10 AM   #71
csm7djs
70
Yeah, I know you are right. Just annoyed that I've thrown it away.
Not even looked at updating e-sys - I've got an old Token solution. Will this still work or will I need to update? I know i'll need the new psdzdata - but they seem pretty easy to get.
      02-08-2018, 10:02 AM   #72
bpbaud
Drives: 530i
Thanks.
      02-08-2018, 11:14 AM   #73
Almaretto
Almaretto's Avatar
2376
VO coding does not require Token. But, if you you are doing FDL coding, you will need to upload launcher to 2.8.
      02-08-2018, 02:42 PM   #74
Flyingscotsman
Scotland
186
Drives: G30 520d se
no bother!
      02-08-2018, 02:58 PM   #75
Flyingscotsman
Scotland
186
Drives: G30 520d se
My car is still on order - Due Mid March but i'm happy to have a dig around and try to find this out. Obviously if you solve it before hand please let us know how? Maybe a How To Guide
I'll report back once I've had a play with it.. looks like there's 14 parameters that need changing to enable all the functions of enhanced Bluetooth.
Bimmercode is still a bit limited on G30, so e-Sys may be a better option depending on what you're looking to code.
One major plus of bimmercode for some is VIM at any speed, I believe e-sys can only do it up to a certain speed.
      02-09-2018, 04:04 AM   #76
csm7djs
70
I think I will go for both actually - going to try Bimmercode as its only £25 and will setup e-sys because i've used it before.
E-sys is fine to use, just takes awhile to ensure everything is setup correctly.
      02-09-2018, 09:26 PM   #77
Almaretto
Almaretto's Avatar
2376
Bimmercode is good for VIM. Otherwise, you will want E-sys for a G-series.
      02-12-2018, 09:21 AM   #78
csm7djs
70
So - how easy is it to swap back to the standard speedo if you don't like the Alpina style display?
      02-12-2018, 10:43 AM   #79
nsa100
187
Drives: G31 540i & G30 540i M Sport
Very easy just code the Alpina Display back to 'not active', as original.
      02-12-2018, 11:09 AM   #80
mozs11
14
Drives: Mercedes
If you code the alpina display, the speed range increases to 200mph right? If so, will it stil accurately display speed on a 530i
      02-12-2018, 11:14 AM   #81
nsa100
187
Yes it displays up to 200mph. I presume the speed is correct. See if you can reach 200mph
      02-12-2018, 11:18 AM   #82
Flyingscotsman
Scotland
186
Drives: G30 520d se
The speedo is accurate, I've checked it against gps and it's exactly the same as the standard speedo calibration. (Reads 82 for an actual 80mph)
      02-12-2018, 11:43 AM   #83
csm7djs
70
Is the rev counter still ok?
      02-12-2018, 12:00 PM   #84
Flyingscotsman
Scotland
186
Drives: G30 520d se
Yep, rev counter is fine on my 520 diesel
      02-13-2018, 03:54 AM   #85
DavidI
22
Drives: F90 M5C LCI
That's unusually accurate, 10% optimistic seems to have been the norm for decades. Need to remember that when it comes to setting cruise control.
      02-13-2018, 06:11 AM   #86
Flyingscotsman
Scotland
186
Drives: G30 520d se
Last couple of Mercedes I've had read 83 at actual 80, so fairly similar
      02-13-2018, 07:24 AM   #87
DavidI
22
Drives: F90 M5C LCI
Interesting, I'm pretty sure I'm 10% over in my F10 and can't remember the last time I was in a car that didn't read over by around that amount. I just figured there were too many advantages to being on the optimistic side and that it was an accepted practice. Thanks for the confirmation.
      02-13-2018, 07:34 AM   #88
Flyingscotsman
Scotland
186
Drives: G30 520d se
Just a thought.. Do you have a digital readout or are you using dial/needle?
A proper dial will be less accurate than digital readout and may well be 10% over.
I was talking about the digital readout.
5post
