BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      02-17-2022, 08:25 PM   #727
SDriver18i
SDriver18i's Avatar
No_Country
80
Drives: BMW X1 s18i 2019
Originally Posted by maspenk069 View Post
I performed mod on "M Performance logo startup" on my car and get a warning from Authorized Workshop that my car could loose warranty because that's the first sign of software modification.
Scare tactic.
They CAN refuse the warranty if the CHANGES you did affected the specific part the warranty is for. They have to prove that the changes you made caused an issue.
For example: A TUNE is a software modification to the DME/Gearbox that voids engine/gearbox warranty but just for those two parts.
They still have to prove that.
Changing a displayed logo is voiding a warranty for what exactly? The digital logo? The logo is going to void the warranty how exactly? Is it a magic spell logo that will make my car spit fire?
You can either ask them which warranty clause voids software modification relating to visual changes in a logo OR you could just ignore it and do what you want since this will not damage anything that they can prove, or that they can't fix with a simple software update/reset.
P.S: Your workshop might just refuse you because you challenged them and beat their scare tactic ?
      02-19-2022, 09:42 AM   #728
maspenk069
Drives: BMW F48
Yup because the workshop expects us to be just dummy and just give to them whenever something goes wrong...
      02-22-2022, 02:09 PM   #729
Xorbitman
47
Drives: 2018 BMW X1
My dealership here in Montreal, Quebec, Canada knows my car and I have an excellent relationship with my service manager and CSR. They have no reason to void my warranty. In fact I'm in to my last year of my lease and intend to keep the car an additional 2 years because of my low mileage (kms) due to the pandemic and lockdowns. I'm only at 33k Kms after 3 years which is half the expected kms. Many used vehicles especially the M sports cars with low mileage are selling for more used than ordering a new one which could take up to 6 months now too. I'll probably get an electric BMW when they're available in 3 years. I'll buy out my residual value as the my X1 with all my add ons and goodies will probably be worth more much more than the buy back next year in January. BTW my dealership service is always excellent.
      03-16-2022, 06:47 AM   #730
pepe1234
Drives: X5 G05, X1 F48
Originally Posted by Almaretto View Post
Just compare to ECE and code accordingly.
Actual changes depending on hardware.
Hi Almaretto How should I do this? How can I compare to eu version? Can you help me little bit? Im quite new with esys (just coded few options in my G05)
Thanks in advance
      03-16-2022, 12:17 PM   #731
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Thanks in advance
It is not a beginner skill.
You would have to generate ncd's using coding verification. Save them as fwl. And then use something like beyond compare to do side-by-side.
      03-16-2022, 12:42 PM   #732
kubax86
kubax86's Avatar
No_Country
1804
Drives: M2
Thanks in advance
Notepad+ is cool as a compare tool
      07-14-2022, 03:26 AM   #733
pepe1234
Hi guys, I didi some coding (rear fog lights, removed legal disclaimer, changed language of Idrive & cluster, close rear hatch from fob)
CAr is 2016 with premium package: full LED, folding mirrors (they working now with button on drivers side)
What I can't code - hope you know the answer:
Disable Welcome 3 Gongs:
3000>Initialwarnung_GWF_IW = nicht_aktiv
- cant See it in my ACSM
SeatBelt Reminders/Sound OFF on engine start
3000>SBR_PreWarning_Fahrer
3000>SBR_PreWarning_Beifahrer
Close Mirrors/Windows/SunRoof from FOB or CA – set all to: aktiv
3056>KOMFORTSCHLIESSUNG_FB
3056>KOMFORTSCHLIESSUNG_PA
Set Mirror Fold Delay Time to Instant upon locking
3056>KOMFORT_SCHLIESSEN = 00
here the only value is wert 01 even with edit
Also need help with disabling US sidemarkers:
Turn off Amber Side Markers next to Headlight:
3063  MAPPING_SIDEMARKER_L_OUTPUT set to: OFF
3063  MAPPING_SIDEMARKER_R_OUTPUT set to: OFF
Still can see little 3 (or 4) amber LED sidemarkers when light are on
when I changed like this:
3063 MAPPING_SIDEMARKER_L_OUTPUT off ->fra_v_l
3063 MAPPING_SIDEMARKER_R_OUTPUT off ->fra_v_l
turn signals also working as sidemarkers when lights on
Thank you in advance
Cheers
      07-14-2022, 12:38 PM   #734
Almaretto
Almaretto's Avatar
2376
Cheers
If you cannot read the values, you are using the wrong coding solution. Try Bimmer Utility.
      07-22-2022, 02:01 AM   #735
pepe1234
I found solution all coded with Esys and launcher pro:
sidemarkers off:
FLE43/3006/LM_ID_LT5: Change Werte=05 to Werte=00
FLE43/3006/LM5_Name: Change Werte=0C to Werte=00
FLE44/3006/LM_ID_LT5: Change Werte=05 to Werte=00
FLE44/3006/LM5_Name: Change Werte=0C to Werte=00
Folding mirrors: all set to activ (this was located in body module as I remember)
KOMFORTOEFFNUNG_FB
KOMFORTSCHILESSUNG_FB
KOMFORTOEFFNUNG
KOMFORTSCHILESSUNG
KOMFORTSCHILESSUNG_PA
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
ASP_ausklappen_nach_komfortschliessen
Also was able to disable welcome gongs and seatbelt pre reminder with EsysNeXt but I don't remember which lines were modified (I have to check other computer where .ncd is saved)
      10-15-2022, 09:51 PM   #736
fala
Drives: f48 lci
Does anyone know can the surface pro x w/ SQ2 cpu able to run e-sys?
      10-15-2022, 09:58 PM   #737
Homersbud
204
Drives: BMW X1
yes - don't need much to run esys
      10-15-2022, 10:05 PM   #738
fala
Drives: f48 lci
finally, i tested w/o any connection but only 32 bits version can be run on SQ2.
Is this old version still can edit FDL?
      10-26-2022, 07:16 AM   #739
kchayeh
Tunisia
Drives: X1 F48 2017
Originally Posted by bmtespar View Post
It' s a set of files for all the models. You just want to make sure you have the most up t date ones you can get. When you launch the E-sys software, you tell the system which set of files to use depending on the car you are coding. There isn't a F048 file set listed yet but you can use the f56 files to code. I am using version 57.2 PSdZData lite.
Hello,
Could you please send me the links for the latest PsdZData lite please.
Many thanks,
      11-13-2022, 04:38 AM   #740
Nabzo
Drives: bmw x1 f48
how to code for the m performance boot logo ?
      11-29-2022, 02:50 AM   #741
Nabzo
Drives: bmw x1 f48
how do i activate front pdc or how do i code it
      01-14-2023, 10:01 PM   #742
Julz90
Germany
Drives: F48 LCI, E87 LCI, E36 Coupé
You remove the SA 507 and activate the SA 508 after successful retrofitting.
Then code the control units according to SA.
      01-15-2023, 09:17 AM   #743
t4ure4n
35
Drives: 2016 BMW X3 xdrive 20d
Hi
I have 2016 BMW X1 xdrive 18D.
I am planning to change front 2 wheels which have bad curb damage with wheels+alloys that I bought from eBay. The new set came off another BMW X1 so they are exactly same spec.
My car has the following options
S2VB Tyre Pressure Display
S28A BMW LA Wheel, Y-Spoke 569
When I put the new set on, do I have to code the RDC sensors via ESys or ISATA to work with my cars Tyre pressure display system or they are plug and play.
Failing that, can just swap the RDC sensors from old to new wheels?
Kind Regards
      01-18-2023, 09:11 PM   #744
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Originally Posted by t4ure4n View Post
Hi
Kind Regards
Should just be able to go into idrive and reset tpms and be good to go.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      03-24-2023, 09:42 AM   #745
F48_MJG
Drives: F48 xDrive25D M Sport
Hi everyone,
I've recently picked up a 2017 xDrive25D, it's a fairly unexciting spec, so I'm keen to retrofit a couple of bits, some of which needs coding.
So far I've added the auto-dimming rear view mirror, but believe I need to code option 431 to the vehicle order.
I've also fitted the 390mm M Performance brakes to the front, which I gather needs coding too, I think from what I can see with 'SPBR', albeit that may not be in the vehicle order and may be elsewhere.
I've been doing some looking around for several weeks now, but can't find any diffinitive guides on coding these with eSys for F48, so is anyone here able to help, either with knowing how to code these, or alternatively having an up to date guide for an F48.
From following other guides for different Fxx cars, I can get to the last step where I've made changes to the V/O, but then (as I understand it) need to code it to various modules/ECUs and this is the bit I seem to fail at.
Any help would be much appreciated, cheers!
      06-23-2023, 07:03 AM   #746
isiarj20
Drives: X1 F48 LCI 2020
Hi, I’m coming from other thread that point me to this one, about to code something for enable the passenger central lock buttons, I’m from Spain (left hand drive) I bought a buttons from uk, ínstalled, connected, but not works, I can see the light from the button but not acts, can anyone help me to enable? I have bimmer code but not e-sys…
      12-09-2023, 03:53 AM   #747
kuba171
Drives: BMW G30
Hello. I have an x1 f48 from the USA and I need to encode the language into Polish. I have esys ultra. Just change the "3007 language polnisch" to "list" or "master"? Or do I need to change the coding somewhere else?
      01-07-2024, 10:33 AM   #748
Ronnyt27
Drives: BMW X1
hi all, i'm new to coding. i'm getting the psdz error 433, when tried to read the SVT. any work around please?
i have the 2019 F48
