04-14-2021, 05:48 PM | #727 |
557
Rep 582
nice. i really want a set of CE28 as well. Currently have two sets as well, one set on Audi and one set on Integra Type-R. One of my all-time favourites.
Current - 2011 E90 M3, Jet Black, 6MT ZCP. Recaro/Bilstein/BBS/StopTech/Haimus/Turner/Pinnacle/BE/Auto Solutions/Macht Schnell/GC/Whiteline/Slon/Alpine
Sold - 2008 E92 M3, AW x FR, 6MT. CF roof is oh-so-Sexy! IG @misterclutch888 Slow Build |
06-09-2021, 11:00 AM | #728 |
38
Rep 125
No rubbing or trimming.
Titan5 T-S5 18x10 +25 275/35/18 Sumitomo HTR Z III 12MM Spacers 2.5 degree camber zero toe 18x10.5 +25 Michelin PSS 295/35/18 No Spacers 2 degree camber 0.20 degree toe Lowered on BC Racing BR coilovers with it being pretty much flush. I do plan on replacing the Sumitomo's with PSS soon and possibly removing the spacers for fitment. |
04-04-2022, 01:29 PM | #729 |
55
Rep 236
I have stock suspension with PS4S tires on Titan T-S5 rims
19x9.5 +22 275/30s front rubs the inner edge of the painted bumper at the 10 o'clock position. 19x10.5 +25 305/30s rear rubs the painted metal bumper at the 10 and 2 o'clock positions as well as fender liner. I am thinking about going to a 265/30-19 front and a 295/30-19 rear to solve the rubbing but im not sure if downsizing by 10mm in the front and rear would be enough. Im wondering if I will have to go down to a 255/35-19 front and a 285/30-19 rear. Id be fine with the rear rubbing the liner tabs a little but I cant have it rub away the painted surface of the fender. Thoughts on if 295/30-19 will clear the actual fender in the rear? |
04-04-2022, 03:37 PM | #730 |
1573
Rep 2,871
295/30/19 clears the rear with 22 offset
The front 255/35/19 is better than 265/30/19. Both the 275/30 and 265/30 have too short sidewall, unless you only care about how it looks. |
07-08-2022, 11:37 PM | #732 | |
564
Rep 618
Rear will be very close, if you go 295 and PS4S. I had rubbing with 10.5ET22 with this size and tire and had to go down to 285. You have 3mm more clearance, but hard to guarantee you won't rub. |
07-19-2022, 05:54 PM | #734 |
75
Rep 109
Not sure about the et15 up front. What size tires? I think the 18x10.5 et20 should be ok in the rear. The reason why I say that is because I have 18x10.5 et25 in the rear with a 285/35/18 lowered on H&R springs and I am definitely going to add a 5-10mm spacer. My front is 18x9.5 et22 with 265/35/18 and it is a pretty good fit maaaaaaybe I could do a tiny little 5mm spacer but that would still put me at et17, really not sure about et15 but I suppose it depends on tire, how much camber, etc.
ZachE90M3144.50 |
07-19-2022, 06:00 PM | #735 | |
145
Rep 174
07-19-2022, 06:04 PM | #736 |
75
Rep 109
I recently purchased some Titan 7 TS5's. Overall I like the wheels however I think the rears need just a bit of love. I read a thread from years ago, extensively, talking about these wheels with 285/35/18 tires saying that it's a perfect fitment for this platform. I honestly don't think it's terrible however I think et20 (possibly even a bit lower) would be just right. I am considering adding a spacer to the rear. Based on what you all know, and the attached pictures, should I stick at a 5mm spacer or is there room to go just a bit more? It looks like Turner Motorsports has a couple 7.5mm options. What size would you all recommend in this situation? While I want it to be aggressive, I definitely don't want it to rub. I have been there and done that (with a previous car back in the day) and my fenders did not appreciate that...
DrFerry6734.50 |
09-10-2022, 01:20 AM | #737 |
145
Rep 174
Don't know if this setup is on here yet but here it goes haha.
Car: 08 E90 Wheels w/ Offsets: Rays TE37SL- (F) 18x9.5 +15, (R) 18x10.5 +20 Spacers: None Tires / Miles: Continental DWS06+ - (F) 265/35/18, (R) 285/35/18; New Tires Suspension: H&R lowering springs (no camber plates) EDC Setting: Normal/Sport Alignment: haven't officially done an alignment yet (will update when I do) Fender Modifications: (F) None (R) None Rubbing? Installed them earlier today and haven't rubbed on anything… yet (will update if I notice any) |
DrFerry6734.50 |
11-24-2023, 08:28 PM | #738 |
166
Rep 485
Just fitted square 18x10 ET25 with a 5mm spacer in the front. I also fitted Bridgestone RE71RS for my upcoming track day and do rub in the front on full lock on the front and back side of the fenders Is that expected? Do other guys run 275/30 with the RE71RSs?
11-28-2023, 11:26 AM | #739 |
1526
Rep 1,597
No one runs a 275/30R18, I don't think that size even exists.
Rubbing on the fender liner at full lock with a 275/35 is common. Mine rubbed completely through to the metal on the back side. Then I did some light massaging of the metal to provide some additional clearance |
05-16-2024, 03:24 PM | #740 |
624
Rep 582
Reviving this thread as I'm looking for confirmation on a setup I'm looking to run:
18x9.5 +22 square with 255/40 and 275/40. I'm confident rear is fine, but will the front rub at all? |
05-16-2024, 10:21 PM | #741 |
2483
Rep 5,955
No rubbing on the front with 18x9.5et22 with 265/40 and 275/35. You’ll have no problems front and rear with 255/275. However, you may need to run a 10 mm rear spacer to get similar frontspacing at the front and rear. Stock rear is 18x9.5et23 which is real conservative.
05-18-2024, 02:04 AM | #742 | |
624
Rep 582
05-18-2024, 02:13 AM | #743 | |
2483
Rep 5,955
The 275/35-18 also doesn’t rub with MCS suspension and -3.5 deg of camber. |
05-18-2024, 11:16 AM | #744 | |
624
Rep 582
Haven't researched the max camber you can run without camber plates, but I'm trying to stay within that. |
05-18-2024, 01:07 PM | #745 |
2483
Rep 5,955
Interesting. I had zero fender rubbing with MPSS 265/40 without any modifications made to the liner. 265/35 has a short sidewall and so does 275/35 come up a little bit short.
