03-06-2014, 01:24 PM | #45 |
2312
Rep 13,026
For quite some time BMW lists in its ETK (parts database in German) a "Bowers & Wilkins High End Sound System (S6F1A)" as an option in the F30 but I have never seen it being actually installed in any F30.
So maybe that will be the equivalent to the Individual Audio in the E9X M3 and the Bang & Olufsen in the F10 M5 for the F8X in next year builds. Last edited by Technic; 04-21-2014 at 12:31 PM.. |
03-06-2014, 02:52 PM | #46 |
Commander-In-Chief
2206
Rep 8,950
HK
Here's the HK system info, assuming the M will have the same as standard F30/32, which I posted in another thread:
http://www.bmw.harmankardon.com/en/v...technical.aspx Speakers for the BMW 4 Series Coupe 16 high-performance loudspeakers with optimum position in the car. 17 x 26 mm metal-matrix dome tweeters, dashboard, front, side & rear 22 x 217 mm woofers (central bass), below the front seats 37 x 100 mm ALumaprene midrange speakers, dashboard, front, side & rear Amplifier - Harman Kardon® Logic 7® DSP amplifier in Class-D technology with a total output of 600 watts
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-08-2014, 09:18 AM | #48 |
128
Rep 1,144
The HK in my E46 was not only shit, when I removed it to install something better (dynaudio, etc), what struck me was how crappy the drivers were. They could not have found cheaper quality components. The directive to the engineer was probably to find a way to make 98% profit from the upgrade.
The EPS system in the E90 (which I have now) is exactly the opposite. The drivers are very very high quality, more so than you would find in most high-end aftermarket halo products. What lets the EPS system down is the tuning - they tried to get too cute with it. Dirac is a EQ system, not an audio equipment company. It changes time/phase by frequency and attempts to play games to compensate for the cabin (for all passengers) at different ambient noise levels and speeds. It ends up being muddy sometimes (like when the HVAC system is on high), and the bass is tuned to be too neutral for any head thumpers out there. At the best of times it has a fantastic soundstage, amazing dynamics, and neutral sound. I added a couple Earthquake SVS drivers, outboard amp and crossover, and it massively improved things, though killed off some of the 120hz-200hz area. The EPS bass drivers were extremely robust (basically all magnet), making me think that they would would work better if you could override the tuning and given them more power. I think the ultimate solve would be to bypass the DIRAC tuning and use the EPS drivers with an outboard amp & traditional time domain EQ. The F30 HK system is the same junk that is in the E46. The drivers are cheap (I've seen the front tweeter and mid from a recent install) and it sounds pretty bad relative to what someone who cares would hope that it is. I found it fatiguing and overly bright. So this time around in the F80M3, I will be ordering the base US audio and installing upgrades from Musicar. It's going to suck driving around europe during ED with base audio, but I'll get over it. I don't understand why BMW went this route, I would have preferred that they offer a $2500 option that was pretty good so that I don't have to hack up the car and do it myself. Last edited by jml; 03-08-2014 at 09:26 AM.. |
03-08-2014, 10:38 AM | #49 | |
555
Rep 2,633
03-08-2014, 10:41 AM | #50 |
555
Rep 2,633
Musicars web site
"The BMW Premium Sound system is BMWs best offering – it was branded “Logic 7″ until the 2010 model year, when the branding was changed to “harman/kardon”. It sounds better than the HiFi system – its most glaring deficiency is that the low bass is lacking. The speakers are better made than in the HiFi system, but the power level and the crossover filtering are still insufficent for high-fidelity sound, and the speakers also seem to be less durable than the HiFi speakers based on owner reports. Some feel that the E82 version sounds notably better than the E9x Premium Sound, since the center speakers and additional rear/side effects speakers in the E9x Premium Sound system are not present in the E82 version. The amplifier doesn’t have an analog input – the signal is derived from the MOST fiber-optic network in the car. This is what has made upgrades to this system more difficult than in other systems." |
03-08-2014, 05:13 PM | #51 | |
128
Rep 1,144
04-14-2014, 10:49 AM | #52 |
366
Rep 1,517
Does anyone know the number of speakers the M3 HK surround sound will have in comparison to the 16- shown in the 4 series coupe (if in fact the M4 is the same)?
04-14-2014, 10:57 AM | #53 | |
593
Rep 5,396
ive heard both and there is zero comparison at all. the e46 system was legendarily bad, while to my ears, the HK in the new m3 sounds pretty good. regardless of whether you like the new HK system or not, it doesn't sound anything like the old e46 setup in any way. that system was straight trash
04-14-2014, 11:30 AM | #54 | ||
555
Rep 2,633
04-14-2014, 03:38 PM | #55 |
1118
Rep 1,809
A little off topic but whats interesting is that the HK standard sound in M6 and B/O upgraded sound use the same amplifier. I had a car audio guy show me. He said the drivers are cheap. They use B/O speakers but same driver, he was upgrading someones sound system in M6 GC who already had the upgraded B/O sound system
2024 Porsche 911 GTS Cabriolet
04-19-2014, 03:08 PM | #57 |
249
Rep 2,202
I got to spend some time in the HK on an m5 and I can definitely tell a difference from my B&O but still not 4700 worth... I too think 2500 would be a sweet spot but honestly to get a non vibrating shit sounding m4/m3 I'd pay 4700 again lol.
04-20-2014, 02:06 PM | #59 |
2312
Rep 13,026
04-20-2014, 07:23 PM | #60 |
249
Rep 2,202
04-20-2014, 08:48 PM | #61 | |
2312
Rep 13,026
All that for less than 50% of the old price. I cannot label that as "disappointing"... |
04-20-2014, 09:03 PM | #62 |
IG@i.am.wah
2780
Rep 3,815
Drives: M2 CS
Do you think the F8x standard sound will be similar to the E9x standard sound? I didn't get EPS in my e92 M3, and I never really regretted not getting it for the $1900 they wanted for it. Not sure about the F8x HK, though, since its much cheaper.
04-20-2014, 11:24 PM | #63 | |
249
Rep 2,202
lol Then you'd probably be impressed by either the base setup and probably drooling over the HK... The base speakers in the e90s were absolute garbage (no offense as you clearly don't put the same level of emphasis on this as others, like myself). |
04-21-2014, 01:27 AM | #64 |
192
Rep 1,317
my standard sound system on the E90 M3 was the biggest piece of shit radio i've ever owned on any vehicle. i could carry on a conversation w/ passengers at full volume, on almost every song i played.. lets say all songs
i felt like there was an issue somewhere in my sound system.. like it was missing a left or right testicle, but every time i took it in to get inspected they came back w/ "its the quality of your audio recording", or everything seems fine. when i compared it w/ my friends standard 335i audio, there was clearly something wrong w/ my system/speakers the S65 made up for it. going forward, i will GLADY pay that extra price for any upgraded sound. |
04-21-2014, 03:41 AM | #65 |
72
Rep 741
Drives: F80 M3 in Sakhir Orange
I'm still curious about whether the Harmon Kardon in the F80 will be better than the Individual sound system I had in my E90. Oh well, I will know in 8 weeks and 4 days.
F80 M3 Sakhir Orange with DCT and TV collected 21 June 2014.
04-21-2014, 04:58 AM | #66 | |
2312
Rep 13,026
As stated before, a B&W system will be available in the F3x/F8x one of these days. |
